TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > coolant LOW LEVEL WARNING
      06-21-2009, 01:31 PM   #1
Elie335
ايلي ٣٣٥ هاهاها
Elie335's Avatar
St Pierre and Miquelon
88
Drives: Vorsteiner e92
i got an issue with coolant water, the car needed daily like 1 litter of water, i took it to the bmw dealer, they changed the RADIATOR it was leaking water, i changed it, and the leaking is gone, car worked properly, after 3 days i checked the water attitude was on maximum, then again after 2 weeks, it was gone on half, in the same day of checking, i was driving and i got the coolant level warning popping, ugh it may be the radiator cap maybe? when its getting alot of pressure is it leaking maybe? any one experienced the same ?
      06-21-2009, 01:43 PM   #2
vase330
vase330's Avatar
Drives: 19 E63S; 15.5 RangeRover ATB
Check the pipes under the car (have to take off underpan - plastic shield under car) and look at the pipes that run next to and against the intercooler plumbing. Those little pipes are vulnerable, and if one leaks or burts or comes a bit loose, you will be surprised by how much water they gush. They are under pressure.
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
      06-21-2009, 01:46 PM   #3
Elie335
ايلي ٣٣٥ هاهاها
Elie335's Avatar
88
good idea, i will check this thanks alot, any other furthers?
      06-21-2009, 08:47 PM   #4
badass335
badass335's Avatar
109
Drives: 2017 540i Xdrive
I'd have the car checked out again! I have a friend here that had the same issues. His car went in for coolant low issues. He was putting in coolant every 3 weeks. The Rad was replaced but the dealership used the old clamps. a few weeks later, he was driving it hard and the clamps snapped and he drained the entire coolant while driving! That can't be good for his car! You could have a slow leak from one of the connecting hoses.
