BT Tool questions
06-20-2009, 08:55 PM | #1 |
twinborific
118
Rep 4,836
BT Tool questions
Hi all,
Just got a BT tool, and I've two questions about it... 1. When I go to Engine > Actual Values, no values actually work. I can check the box of any of them, but none of them display values: for example, if I choose "miles since last service", it almost freezes the app but only shows 0. If I select "intake air temp", it shows -48 degrees, and again, never updates but almost entirely slows down the PC. Do I need to update the firmware of the tool or something? 2. When I click Stability Control > Fault Codes, the car beeps, a "4x4" error light comes on on the dashboard and the CEL comes on. Then everything turns off, and I get the following fault codes: 6F57: Error will cause a warning light Error is not currently present Test conditions have been completed Timeout ________________________________________ D356: PT-CAN: Message TORQUE_3 (ID 0xAA) not received or wrong message length (DLC). [transmitter: DME] Error will cause a warning light Error is not currently present Test conditions have been completed Timeout ________________________________________ D355: PT-CAN: Message TORQUE_2 (ID 0x0A9) not received or wrong message length (DLC). [transmitter: DME] Error will cause a warning light Error is not currently present Test conditions have been completed Timeout ________________________________________ D354: PT-CAN: Message TORQUE_1 (ID 0xA8) not received or wrong message length (DLC). [transmitter: DME] Error will cause a warning light Error is not currently present Test conditions have been completed Timeout ... why does this happen? Thanks very much for any help. -pN
Doko ni itemo, hito wa tsunagatte iru...
