91 Octane Dynos ONLY *POST HERE*
06-20-2009, 02:49 PM | #1 |
25
Rep 264
We've all seen the 100 octane 400whp+ dynos...
I think this will be helpful for all the CA guys who want to see what people put down on daily driven 91 octane pump gas. I think this will also help compare different mods by taking the octane variable out. I'll start it off... Location: Dyno was done at MD automotive in Westminster. Conditions: 68 degrees with 85% humidity (slight drizzle). Couldn't ask for a better day to dyno. Mods: 91 Octane, JB3 1.3 Map 3, BMS DCI, Active Autowerke IC, AR catless DPs Last edited by riceygts; 06-20-2009 at 03:25 PM.. |
06-20-2009, 03:08 PM | #3 |
Modder Raider
753
Rep 8,633
Drives: M3
AA catless DPs??
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
06-20-2009, 03:20 PM | #5 |
Uhcoug2011
37
Rep 757
Bro you know there is no such thing as AA catless downpipes
Sparkling Graphite E90 / JUICEBOX 3 / BMS DUAL CONE FILTERS
06-20-2009, 03:26 PM | #6 |
25
Rep 264
06-20-2009, 03:35 PM | #7 |
Joint Chiefs of Staff
4918
Rep 115,980
Overall looks good, but next time start the runs around 1800rpm. Loading it up at 1000rpm in 4th gear with lagfix can induce that torque spike. Also it seems the tach signal is dropping out, plot power by MPH instead of RPM to see.
Mike |
06-20-2009, 03:55 PM | #10 |
Rep 46
I dyno'd w/ riceygts
similar conditions 82-85 humidity AR designs dp Injen DCI HKS exhaust ETS FMIC JB 3 map #3 (91 octane) Heavy 19's too Last edited by kryzeofkrayzie; 06-20-2009 at 04:10 PM.. |
06-20-2009, 03:59 PM | #12 |
327
Rep 4,484
Even starting the dyno at 1500 rpms you (the OP) still got that big torque spike (that kind of skews the true torque results).
I think Terry should check your map or something, it should not spike up like that at 2500 rpms only to drop quickly afterward. Thats the results we got with the original tunes when we used to do the solenoid bypass. Your torque should build and be more flat in the 370 rwtq range where it is after that big boost spike. You can clearly seen the gains of the aftermarket FMIC above 5000 rpms where the stock one is already getting hot and pulling power. |
06-20-2009, 04:02 PM | #13 |
327
Rep 4,484
Kryz, your dynos look better to me and your torque numbers are better overall, but you are also still getting a bit of a boost spike around 2500 rpms (maybe that's why the a/f ratio goes off the charts there).
But your power delivery is much better/smoother. |
06-20-2009, 04:08 PM | #14 | |
25
Rep 264
Our graphs actually look pretty similar when scaled the same in winPEP. |
06-20-2009, 06:26 PM | #16 | |
109
Rep 3,334
Mods list got too long, lets just say more than enough.
06-21-2009, 01:42 PM | #21 | |
4918
Rep 115,980
Mike |
