Oil Type ?
06-20-2009, 01:12 PM | #1 |
35
Rep 376
Drives: 2011 Blue Onyx 335is
Oil Type ?
I need to add a quart to the 335. What brand and weight does BMW use in my car? I just can't remember! Thanks.
06-20-2009, 02:15 PM | #4 |
56
Rep 974
06-20-2009, 02:22 PM | #5 |
137
Rep 1,914
Are you aware that some dealerships will not do a FREE top off. Not sure if ALL will give you a qt of oil either. IMHO, its pretty lame if they don't especially since thay are advertising FREE maintenance. But BMWs shouldn't really burn oil should they? But that is another issue for another thread.
06-20-2009, 02:26 PM | #6 | |
Rep 244
You might know me from E46Fanatics.com |
06-20-2009, 02:26 PM | #7 | |
1110
Rep 2,327
06-20-2009, 03:34 PM | #8 | |
13
Rep 1,187
But to approach it from another angle, "brand and weight" does not matter. What does matter is that the oil is approved under the BMW LongLife 01 specification (BMW LL01 or BMW LL-01). Such oils will say so in small print on the back of the bottle. European cars need oils that meet the manufacturer’s specifications. Examples are BMW's LL01, VW's 502 and Mercedes Benz's 229.5. In general, in the United States, each oil brand will offer one very good oil that meets these standards. And you may have to go to a real auto parts store, or the dealer, to get them. |
06-20-2009, 03:59 PM | #9 | |
Rep 244
06-20-2009, 10:27 PM | #10 | |
Rep 9
06-20-2009, 10:50 PM | #11 |
Powered By 36DD
337
Rep 7,369
Castrol 0W30 and Mobil 1 0W40 are both BMW LL-01
I have used both for my oil change at every 5k miles.............
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
06-21-2009, 04:19 AM | #12 |
Rep 244
European Formula
06-21-2009, 06:54 AM | #13 |
205
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
oil change
i've got 12,000 mi w/ 2 oil changes, and never had to add a drop. might that be attributed to not getting hard on the gas pedal to often ?
06-21-2009, 07:01 AM | #14 | |
1705
Rep 14,829
I question whether it's "normal" to have the oil level go down. On a new car maybe it's leaking, not being burned. |
06-21-2009, 08:33 AM | #15 |
7
Rep 241
Drives: 2008 BMW 335i Coupe
I have never had to top-off before. My car has always registered at the 'max' marker.
I drained my factory oil @ 1,200 miles and replaced with Red Line 5W40 due to my location - south Florida is HOT year round. The results have been awesome - my peak oil temperature with Red Line is 230-degrees F while the factory oil was 240-degrees F. Disclaimer - Red Line is not a BMW Long Life oil; in fact Red Line is not 'recommended' by any manufacturer, but do your own research and you will see Red Line is one of the most respected synthetic motor oils (and transmission oils) on the planet. Also, Red Line is around $9.00/quart so be prepared for a little sticker shock with the needed 7 quarts for the N54.
Montego Blue / Saddle Brown / Gray Poplar
6-speed Manual (CDV-free) / BMW Performance Exhaust / Dinan Intercooler / Dinan Stage 2 / Dinan Cold Air Intake BMW Performance Suspension / Dinan LSD / 19" Forgestar F14s / Front and Rear M3 Bushings & Arms / Rear Sway / Dinan Monoballs |
06-21-2009, 09:40 AM | #16 |
Powered By 36DD
337
Rep 7,369
My local Autozone carries them...........
