More Unknown BT Tool Codes
06-18-2009, 12:08 AM | #1 |
24
Rep 1,310
Here are three that I searched on and could not find explanations:
N54 Codes 2F4C 2F4C Message EWS-DME digital motor electronics electronic vehicle immobilization-digital electronics failure Error will not cause a warning light Error is not currently present Test conditions have been completed Signal or value below threshold 2F4A 2F4A Interface EWS-DME electronic vehicle immobilization / digital motor electronics Error will not cause a warning light Error is not currently present Test conditions have been completed Signal or value below threshold Car Access System (CAS) Codes A10A EWS4 timing challenge / response error Error will not cause a warning light Error is not currently present Test conditions have been completed Signal or value below threshold There are two unresolved posts about the A10A code. I've passed these on to Mr. 5 for addition to the master list. Car is running great, no issues.
Torque - The One You Love...
06-18-2009, 02:17 PM | #2 |
only in it for the torque - awuleth'umshini wami
50
Rep 425
Drives: sapphire black 335i
Unknown and weird to me also.
But glad car is running well!
06-26-2009, 03:32 AM | #3 |
24
Rep 1,310
****UPDATE****
I scanned the car after driving for a bit and I get no codes whatsoever. This leads me to believe that the codes I listed above are related to disconnecting the ECU connectors accidentally before disconnecting the battery.
06-26-2009, 01:13 PM | #4 | |
50
Rep 425
I got the car access code (A1OA) a day ago. Just try something...keep the door/s or window/s or sunroof open while doing the BT scan and you will get the funny access code. But not when everything is shut. Anyway interesting. I think you might be right about the other two DME/ECU codes.
06-27-2009, 02:26 PM | #5 | |
24
Rep 1,310
Interesting!! That's the great thing about E90Post, everybody working through these weird problems. Strange though, I always have the door open when I use the BT Tool and I didn't get the A10A code...
06-27-2009, 02:56 PM | #6 | |
81
Rep 1,510
Every single time I've scanned with the BT cable is with the windows and sunroof open, cable usually going through the window or through the sunroof on laptop on top of the car. Never seen that code. You're scanning with ignition on/engine off, right? |
06-27-2009, 03:11 PM | #7 |
50
Rep 425
Yes. Ignition on/engine off.
Perhaps just one of those things.
