BMW M3 Forum (E90 E92)
      06-16-2009, 07:05 PM   #1
eclipsisNA
Drives: 2013 Estoril 328i M Sport
2014 BMW 428i  [7.76]
Euro (Matte Black) Side Mirror Swap
I always liked the matte black side mirrors that came on the E93 M3 in the US and the E9* M3 lineup in Europe. I felt the gloss black housings that came on the American E92 M3 picked up water spots and scratches too easily, so I went ahead and ordered the left and right European housings from ecstuning.com: part numbers 51168041911 and 51168041912. They cost a little more than $600, but I sold my old gloss black housings to an E90Post member for $450, so I'm not losing too much. The following is a DIY to swap out your current mirrors for the Euro versions.
New matte black housing as it came from the factory:
My door trim is already removed in this picture. You need to position a flat head screwdriver behind the outer end of the trim, gently ply up w/ the screwdriver, then pull the rest of the trim off with your hand. The white parts shown are anchors that hold the trim in place. It's a wise idea to put a towel or business card underneath the screwdriver so you don't damage your door panel.
There are 4 hex head screws that help hold the door panel in place that you need to remove w/ a screwdriver.
With a towel or business card behind your screwdriver, insert a flat head screwdriver between the door panel and the door itself. You should insert the screwdriver near the outer bottom part of the door as there are white door plugs there that need to pop out. Once you hear one plug pop out, put both your hands behind the door panel and pull the entire panel off the door. The door panel has wires connecting it to the door, so make sure you don't pull the door panel too far away from the door, because your wires will rip.
In the next picture, the speaker column has already been removed by gently lifting it upward, NOT OUTWARD. If you pull it outward, it will snap the holding joints. Once its removed, unplug the wiring harness from the mirror housing, which is the black circle in the picture below. There are 3 hex head screws that need to be removed in order to take out the mirror housing. Be careful: when removing the last of the 3 screws, make sure you're holding the mirror housing on the outside, or it will fall and break. Remove the old mirror housing and replace it with the new one.
Reverse the previous steps:
1. Screw in the mirror housing's 3 hex head screws
2. Secure the speaker column back into place
3. Put the door panel back in place by punching the white plugs back into their respective holes
4. Screw in the door panel's 4 hex head screws
5. Punch door trim back into anchors
Now you need to remove the glass from your old mirror housings. Take a flat head screwdriver and put the head behind the glass, gently prying it off one side at a time. Be very careful or the glass may crack. Once its off, remove the two black wires attached to its backside, connect those wires to the new mirror housing, and then simply snap the glass onto the new mirror housings.
Wallah! Enjoy your new Euro housings:
      06-16-2009, 07:41 PM   #2
JCtx
258
Drives: No BMW yet
Good write-up. But have a question for you: Don't the matte mirror housings look kind of odd around the rest of the glossy shadowline trim?
      06-16-2009, 07:41 PM   #3
eclipsisNA
It does look odd, which is why I'm having EAS wrap the window trim in matte black vinyl.
      06-16-2009, 08:11 PM   #4
tunawi7cheese
tunawi7cheese's Avatar
Drives: Power by dead dinosaurs
Eric,
Did you get the euro split mirrors too or just the housing? If you got the euro split mirrors/heated/auto-dim, please take pics. I'm considering getting them, but would like to see them first. Thanks.
Kevin
Melborne Red 08' E90 M3 6spd
Hockenheim Silver 20' F87 M2 CS MDCT
White 21' Jeep Gladiator Rubicon
      06-16-2009, 10:10 PM   #5
aremmell
aremmell's Avatar
105
Drives: '24 M4 Comp xDrive
Who made the carbon mirror covers on your car? Are they the ones from EAS?
      06-19-2009, 11:52 AM   #6
swamp2
swamp2's Avatar
Drives: E92 M3
Looks great. I am doing this immediately. I can't stand the gloss finish.
Thanks.
P.S. I also sold by OEM mirrors in a single day to a regular 3 series guy. Got $450 just like you did. Based on how fast they seem to be selling it looks like $475-$500 for a used set might be the market price.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK |
| Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors |
| Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels |
| XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit |
      07-18-2009, 08:31 PM   #7
swamp2
swamp2's Avatar
Drives: E92 M3
BIG CAVEAT:
The part numbers supplied here are absolutely matte black and fit perfect. However, they are NOT motorized and are NOT auto dimming. I'm really surprised the OP failed to mention this. The connector inside the mirror from the body to the glass is not even compatible with the one from the glass. Perhaps the two black wires that are now loose can somehow be hooked up to the glass for auto dimming? I probably would not have bothered with this mod if I knew that before hand.
So the big question is my opinion is the following: Are there matte black, auto dimming motorized housings available, what are the part numbers and who sells them?
Anyway, if you are willing to live without motors and auto dimming this is a great write up, I would have screwed this up without it. Getting stuff apart in modern automobiles is often so darn tricky. My added comments/corrections:
  1. Screws attaching door are torx (star), not phillips, T20. T30 are the ones holding the mirrors on. Don't bother starting this job without the right bits.
  2. You have to pop the cover on the passengers side door handle and remove the torx screw underneath it at the top of the handle to remove the door panel.
  3. I had to pull quite a but more than "gently" on the speaker housing to remove it. But yes, pull up as described, not out.
  4. The third torx screw attaching the mirror to the door is hidden under the rubber seal.
  5. The mirror glass literally pops right off as described, just use a small screw driver and some cardboard, you can force the mirrors motor into a better position for prying on the left and then on the right.
  6. To swap mirror covers start by prying/popping the bottom of the cover off first then the top. You will almost for sure break a couple of the really small guide tabs but they are not a big deal. They don't actually hold the cover on. If you remove the mirror glass first you may be able to release the four serrated clamps from the glass side instead of prying.
  7. The green speaker wires fit in the rear most slot. They can be easily confused with the blue wires (and the connector fits) that go in the slot right next to it. You'll know what I mean when you see it.
  8. The alignment between the base and top post/wing of the mirror body is substantially better (looks pretty much perfect) than the OEM unit. This was a complaint quite a few of us noted about our mirrors.
Hope these things help.
      07-20-2009, 05:52 PM   #8
swamp2
swamp2's Avatar
Drives: E92 M3
OK here is the deal. As I mentioned the part numbers in the OP are matte, non power folding and non auto dimming. The matte, power folding and auto dimming part numbers are:
51168041921
51168041922
and the OEM (US E92, gloss, power folding, auto dimming) are:
51168044795
51168044796
Hope this prevents confusion for anyone else.
      07-28-2009, 09:06 PM   #9
eclipsisNA
They are motorized. On my 6MT, when I put the car in reverse, the mirrors automatically tilt to show the ground.
When you said "two black wires," I only have one and it fits perfectly into the glass from the mirror housing. I don't have auto dimming so maybe that's the only thing that's missing? Otherwise the one black wire fits into the rear of the glass perfectly and provides motor movements.
      07-28-2009, 11:51 PM   #10
swamp2
swamp2's Avatar
Drives: E92 M3
My language was not quite accurate enough. They are power mirrors, meaning you can adjust the angles of the mirror. They are also auto tilting since that just uses the power adjustment feature. They are not, however, power folding (using the small button near the adjustment buttons) and are not auto dimming.
The wires that are not used are the ones you can clearly see in your very first picture - the one with the blade/socket connection.
      07-28-2009, 11:59 PM   #11
eclipsisNA
I didn't mention this in my OP because I do not have the power folding mirror option on my car, thus it wasn't apparent to me that the part numbers I listed didn't include the power folding option.
      07-29-2009, 01:20 PM   #12
swamp2
swamp2's Avatar
Drives: E92 M3
Ahhh ha, I thought power folding was standard in the US! This explains everything. This option is part of ZPP, the Premium Package. Thanks.
      09-16-2009, 10:11 PM   #13
Definitive
definitivecars.com
Definitive's Avatar
Drives: Elsa - 2015 F80 M3 - YMB/SS
Hmmm, so are there Matte mirrors with "Power Folding"???
D
      09-16-2009, 11:06 PM   #14
KonigsTiger
Racying Dynamics
KonigsTiger's Avatar
118
Drives: E92M3 RS46 Club Sport, others
Gotta see some better pics before I can tell if they look odd or not.
      09-30-2009, 02:08 AM   #15
swamp2
swamp2's Avatar
Drives: E92 M3
D
Hmmm, can you read (or perhaps more friendly - did you read)? See my post #8 just above.
      09-30-2009, 12:10 PM   #16
Definitive
definitivecars.com
Definitive's Avatar
Thanks for the nicer version swamp. I must be blind cause I missed it.
D
      09-30-2009, 12:15 PM   #17
SlammedR8
SlammedR8's Avatar
521
Drives: 2019 X5 40i/2020 R8 V10 Spyder
Ive always loved that my E93 came with the matte black mirrors. the only thing that sucked was it also came with aluminum/chrome trim around the windows (unlike the E90 and E92). But I had that painted matte black to match the oem matte black mirrors.
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather
2020 Range Rover HSE - Black/Black
2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black
Search this Thread:
Advanced Search
m3post
