break in oil change - recommended ?
06-09-2009, 09:02 PM | #1 |
7
Rep 75
Hi
I have just gotten to 1900 miles on my 335i coupe. I have heard that some guys do their break-in oil change so i went and talked to my service-adviser who said that this is not part of BMW recommendation for regular maintenance. How solid is your observation/recommendation to do this, shall i insist on doing this ? is there anything wrong if I don't ? just wanna do the right thing for this car !!!! Thanks BP |
06-09-2009, 10:22 PM | #2 | |
13
Rep 1,187
For what it is worth, which is nothing since this is the Internet, I did mine at 2,000 miles. But then I am planning to keep the car for 10 years/ 200k. |
06-10-2009, 03:27 AM | #4 |
Rep 17
im at 12k KM. right now and still havent changed yet.
the computer says to change at 24K km i think but i wanna do it earlier... will bmw do it free? i have that v6 service package or something |
06-10-2009, 03:34 AM | #5 |
7478
Rep 10,120
It depends, you are technically entitled to one free oil change a year. Honestly, you can change the oil yourself and it only take about 15min to do. Change your oil every 5,000 miles and then go in for your free oil change at 15,000 miles.
06-14-2009, 03:15 PM | #6 |
172
Rep 2,373
id suggest doing it. it making a difference is debatable...but id personally never go 15k between oil changes..but what do i know? i just work on em every day...
06-16-2009, 04:14 PM | #7 | |
BMW CCA Member #420698
17
Rep 720
I'll only do about 7K if that a year and don't want to wait till 15K miles. I called my dealer's service and was told I can get a free oil change and filter once a year which works for me. Although,I'm not crazy about Castrol BMW synthetic oil. I'm going to change the oil myself at 1000-1200 miles and use the BMW oil. |
06-21-2009, 05:18 PM | #9 |
Powered By 36DD
337
Rep 7,369
FIXED!
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
06-22-2009, 03:00 AM | #10 |
77
Rep 1,208
Do the oil change. The argument for doing one is that during the break-in period, the parts are being worn down to their proper fits so there will be small pieces of metal in the oil which needs to be flushed out. After a certain number of km's, the car's parts will be worn down sufficiently and so the oil will be clean after the change.
Those who argue against the oil change say that modern engineering has gotten so precise that everything will be a perfect fit and so there won't be much of anything worn down at all. In my opinion, from my background as an engineer and quality control, modern engineering may be that good but no one ever gets it 100% perfect. We can come close but we'll never get that good. On an assembly line, random sampling is done to determine if the batch is good or not. There's still a chance that we pick one good one out of the batch and the rest are actually bad. Just think of it this way. Doing an oil change is faster and cheaper than having to fix something that goes wrong later. |
06-22-2009, 06:39 PM | #11 |
415
Rep 2,475
If you don't care about the car or are just leasing and plan on turning it in, then it's up to you. If I owned it I wouldn't skip. Oil analysis proves these engines show high aluminum content during break in. You think it's good to let that junk sit in there for 7000 to 15000 mile, depending on when the next oil/filter change is?? BMW used to do a 1200 mile service on all new cars...now miraculously these new engines don't need it. Any car will benefit from a break in oil change.
2020 /// M2 Competition
Past: 2016 435i ZHP Edition | 2013 335i | 2011 135i | 2008 328i | 2006 325i |
06-25-2009, 12:41 AM | #12 | |
104
Rep 934
I'm thinking we should replace all fluids (except coolant) at 1500 miles. I know in my 2003 M5, BMW recommended diff fluid change at 1200 mi. I plan to change them all, from the manual tranny to all the diffs and transfer case. |
