06-04-2009, 03:35 PM | #1 |
BimmerPost Supporting Vendor
8109
Rep 18,799
Drives: BMW
▀▄ eas | Macht Schnell - Competition Liteweight Floor Mounts for Racing Seats
Race seats can offer a an immediate improvement in driver feedback keeping you planted to the seat and concentrated on driving, while offering a significant weight savings. However, most race seat companies leave it up to the driver for a mounting solution.
Macht Schnell Floor Mounts are designed for the serious track enthusiast in mind. CAD designed and machined from 6061-T6 aerospace aluminum, these mounts are as strong as they are light. Multiple mounting positions allow driver to dial in an exact seat position that is most comfortable and perfectly centered to the steering wheel. Competition Liteweight Floor Mount Features: - CAD designed and CNC machined from 6061-T6 aerospace aluminum - Allows fitment for Recaro and most other race seats on the market - Fully compatible with slider brackets - Low profile allows for sliders or taller drivers allowing helmet clearance - Black anodized finish for additional strength and corrosion/wear resistance - Side provisions allows brackets (sold separately) for OEM seatbelt receptacle mounting or race harnesses - Available in Black Anodized or Raw Aluminum finish - Can be used on Driver or Passenger's side - Sold as a set (one seat) Macht Schnell recommends RECARO racing seats for the highest in quality and craftsmanship. Macht Schnell - Competition Liteweight Floor Mounts for Racing Seats - Black Anodized http://www.europeanautosource.com/pr...oducts_id=2325 Macht Schnell - Competition Liteweight Floor Mounts for Racing Seats - Clear Anodized http://www.europeanautosource.com/pr...oducts_id=2326 Models Supported: 2006+ 3-series and M3 (excluding convertible models) 2008+ e8x 1-series
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 06-04-2009 at 03:58 PM.. |
06-04-2009, 03:35 PM | #2 |
8109
Rep 18,799
Drives: BMW
Macht Schnell - Harness Receptacles for Competition Liteweight Floor Mounts (pair)
Allows a safe mounting point for race harnesses. For use with Macht Schnell Competition Liteweight Floor Mounts.
Crafted from high-grade steel, set comes complete with 2 mounting harness tabs and mounting hardware. Available in black powdercoat only. Macht Schnell - Harness Receptacles for Competition Liteweight Floor Mounts (pair) http://www.europeanautosource.com/pr...oducts_id=2327
06-04-2009, 03:36 PM | #3 |
8109
Rep 18,799
Drives: BMW
Macht Schnell - Seat Belt Receptacle for Competition Liteweight Floor Mounts
Stop drilling into your seat side mounts. Our Seat Belt Receptacles allows for safe, secure point for OEM seatbelt receptacles. For use with Macht Schnell Competition Liteweight Floor Mounts.
Crafted from high-grade steel, set comes complete with 1 left-side mounting bracket and mounting hardware. Available in black powdercoat only. Macht Schnell - Seat Belt Receptacle for Competition Liteweight Floor Mounts (Left Side) http://www.europeanautosource.com/pr...oducts_id=2328 Macht Schnell - Seat Belt Receptacle for Competition Liteweight Floor Mounts (Right Side) http://www.europeanautosource.com/pr...oducts_id=2329
06-04-2009, 03:36 PM | #4 |
8109
Rep 18,799
Drives: BMW
Macht Schnell - OC3 Seat Occupancy Sensor Emulation Module
For those running race seats, the Passenger Occupancy Sensor Mat (OC3) is now an integral part of the OEM seat leather and cannot be ordered separately - triggering a “Passenger Restraint Error” message that hijacks the iDrive/OBC, rendering it useless.
Macht Schnell has come up with a solution for those running fixed-back shells and want to retain their iDrive/OBC displays with an OC3 emulator module that easily ties into your BMWs wiring with no cutting or splicing needed and can be removed at any time. For those running race harnesses, the Macht Schnell OC3 module will properly emulate seatbelts in the fixed position - eliminating any errors caused to allow you to focus on on the track and win. The Macht Schnell OC3 Seat Occupancy Sensor Emulation Module is possible of the following features: - The ability to run racing seats with no system errors, allowing full integration - Elimination of “Passenger Restraint Error” messages on both iDrive and OBC cluster displays while in use - Proper emulation of passenger OC3 Seat Occupancy Sensor - Optional emulation of seatbelt receptacles (fastened position for both driver & passenger) for those running race harnesses - Allows the use of BMW Performance Seats, which are not compatible with US models - Completely removable at any time Note: The Macht Schnell OC3 Seat Occupancy Sensor Emulation Module will disable the passenger dash airbag to prevent unsafe deployment. For this reason, this module is not intended for street vehicles and can result in possible injury or death if proper restraint conditions are not followed. Not compatible with euro models Macht Schnell - OC3 Seat Occupancy Sensor Emulation Module http://www.europeanautosource.com/pr...oducts_id=2330 Models Supported: 2006+ e9x 3-series, including M3 (US models only) 2008+ 1-series (US models only)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 06-04-2009 at 03:57 PM.. |
06-04-2009, 03:37 PM | #5 |
8109
Rep 18,799
Drives: BMW
Recaro Pole Positions and MS Flormounts in 2008 M3 - OC3 module and OEM seatbelts
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 06-04-2009 at 04:04 PM.. |
06-04-2009, 03:37 PM | #6 |
8109
Rep 18,799
Drives: BMW
reserved space
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 06-04-2009 at 04:03 PM.. |
06-04-2009, 04:16 PM | #7 |
8109
Rep 18,799
Drives: BMW
reserved space #2
06-04-2009, 08:02 PM | #9 |
Moderator
94
Rep 1,920
Those are fricken sweet Tom!
Tim <--- apparently likes "3" cars
2014 E63S -- The Rocket 2014 F30 328i -- Kids car 2008 E90 M3 -- Sold 2004 GT3 -- Sold 1997 M3/4 -- Sold 1995 M3 -- Sold |
06-05-2009, 03:49 AM | #10 |
11
Rep 365
Drives: M3 E92 AW
Will installing these recaro seats and competition mounts lower the driver position regarding the car ?
Best Regards, Maika
M3 E92 M-DKG and all the options available.
Forum BMW Portugal: http://www.forumbmwportugal.com |
06-05-2009, 11:33 AM | #11 |
8109
Rep 18,799
Drives: BMW
Yes, in order to offer additional helmet clearance, even for those using slider assemblies.
06-07-2009, 03:42 AM | #13 |
2474
Rep 2,807
So if I plan to do BMW Performance seats, then I need your seat sensor to avoid errors, correct? Yet if I use your seat sensor, then my passenger airbag is now inoperable?? If so, why and can this be corrected in future releases?? Kind of a deal killer for me if I have to sacrifice passenger safety to have cools seats.
06-08-2009, 07:13 AM | #14 |
MY 4TH M
10
Rep 204
how about doing a complete kit price including mounts seats and OC3, one or a set of 2 I'm planning on changing mine. Also would the OC3 module work on Canadian cars? out cars are a bit different that the US model.
06-08-2009, 02:52 PM | #16 | |
8109
Rep 18,799
Drives: BMW
It's possible, but not as easy as it would be with reclining seats.
FWIW: BMW does offer a similiar deactivation retrofit kit (airbag only) for those wanting to turn off passenger airbag deployment, but this has no affect on the occupancy sensor.
06-16-2009, 02:37 PM | #17 |
8109
Rep 18,799
Drives: BMW
2009 BMW 135i Recaro install
2009 135i equipped with Recaro Pole Positions, Macht Schnell Competition Floormounts and Macht Schnell OC3 module:
09-12-2009, 03:45 PM | #20 |
8109
Rep 18,799
Drives: BMW
All inquiries replied - floormounts are in stock along with many Recaro setups.
