Need some help from you guys with EE bg
05-28-2009, 12:03 PM | #1 |
16
Rep 458
Hi, I'm trying to install a license plate review camera. The camera works, the problem is my monitor. The monitor I have is the Alpine TME-770 (pretty old but works perfectly), and it will switch to video input 2 when I put into reverse, under the condition that I provide a 12v (reverse light +) to one of the wires. Anyway, I did that and it all works when power is on (engine off), but as soon as I turn on the engine, the reverse light + drops to 10v, that cause my monitor NOT to auto switch to video input 2 (camera).
So my question is, is there any way I can maintain that 12v my monitor needs after engine starts? is there something I can buy to make 12v from a 10v source? Help!!! |
05-28-2009, 12:15 PM | #2 | |
2304
Rep 13,008
05-28-2009, 12:43 PM | #3 |
16
Rep 458
Really? a relay would work? Please excuse my ignorance in electronics, but I thought a relay is like a mechanical switch, if the power I provide to the red lead is 10v, wouldn't I get 10v also in the additional accessories? Or I really need a 12v to the red in order for this to work? I'm not sure if I can provide that 12v, I only did a measure to the reverse light + after engine start and it is 10v, so I was assuming that all other "12v" (cigarette etc) will give me 10v also after engine starts. I'll do some measuring to see if I can get 12v somewhere else, if so, this might be my solution.
05-28-2009, 12:54 PM | #4 | |
2304
Rep 13,008
05-28-2009, 08:37 PM | #5 |
12
Rep 656
A possible reason it might be at 10V is that you are drawing too much current with your tap that the circuit can't keep it at 12V. I have to agree that a relay is your best bet.
05-29-2009, 09:39 AM | #6 |
289
Rep 3,201
The problem is that you don't know the current capability of the "10V" wire... you would be better served with a low-voltage trigger device that doesn't require the factory wire to energize a relay coil. I think the PAC # for that is TR7, and I have used the Directed RTO widget for that too.
05-29-2009, 11:39 AM | #7 | ||
16
Rep 458
05-30-2009, 12:57 AM | #8 |
12
Rep 656
Here's a TR-7 that I found. I think a relay is cheap enough to be worth a shot before trying this though...
http://www.rainbowappliance.com/TR7....PID=9638995910 |
05-30-2009, 01:15 AM | #9 | |
12
Rep 656
05-30-2009, 09:25 AM | #10 | ||
289
Rep 3,201
Technic advised correctly, and YOU are telling him how to kill his battery after a couple of days of parking... |
05-30-2009, 10:28 AM | #11 | |
12
Rep 656
05-30-2009, 11:19 AM | #12 |
289
Rep 3,201
A relay is energized when one side of the coil is grounded and the other side of the coil sees 12V. At that point it starts drawing current.
Technic told the OP how to use the relay (which energizes with less than 12V but pulls about 80-100mA of current at 12V to energize (assuming a standard VF4 form-factor relay - "Bosch" relay to many installers)). If the transistor in question cannot supply 12V and 100mA to the coil, and it blows, that would be bad. A. If the guy ties it to constant from the FB, the relay stays energized. You did not specify using switched or constant from the FB. This will eventually kill the battery. B. You don't want the relay on if the amp should be off. If you tie the coil to to switched from the FB, in situations where the amp should be off, the relay stays on and so does the amp. This does not kill the battery, but is still the wrong way to run a railroad. |
05-30-2009, 01:50 PM | #13 | |
12
Rep 656
This is what I'm looking at: http://www.the12volt.com/relays/relays.asp Anyways, it says the relay pulls less than 200mA, which maybe too much as well... |
05-30-2009, 07:00 PM | #14 | |
16
Rep 458
It's good to know that!!! |
05-30-2009, 07:04 PM | #15 | |||
16
Rep 458
05-30-2009, 07:19 PM | #16 |
16
Rep 458
Guys, thanks for all you replies, but I'm really confused now after reading all the posts. So my ultimate question is, can I still try what Technic originally suggested without frying anything (assuming I follow his diagram correctly)?
05-31-2009, 08:11 AM | #17 | |
2304
Rep 13,008
If this is too complicated then go and get the PAC device for your peace of mind. |
05-31-2009, 11:01 AM | #19 | |
16
Rep 458
After looking at the TR7's description, seems like it's a very useful device, so I'm going to get it as a backup plan. |
06-12-2009, 03:18 PM | #20 |
16
Rep 458
Just in case someone else has the same problem, the relay method works perfectly. Bought a 12VDC 10A relay and wired it yesterday night, works great.
