Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > ***No More Rusty hubs DIY***
      08-05-2006, 10:09 PM   #1
diesel007
Not Stock
diesel007's Avatar
Drives: 325I
2006 325  [0.00]
Every two weeks I jack my car up and pull off the wheels to clean the suspension, wheels wells, and the inner wheels. I also do this to inspect the inner-wheels, inner-tires, and suspension components. The hubs on BMWs love to corrode and rust. Cosmetically it's really not a big deal because the wheel covers the rust but the hub-centric ring builds rust and makes it difficult to remove the wheels. Once the wheels are off the hubs look horrible as you can see in this pic.
As you can see the inner hub is the worst. I could not deal with this any more so I decided to fix it. I went to AutoZone and spent $13.00 on some sand paper, anti-seize, and brake cleaner.
With the brake cleaner and some WD40 I found in my tool kit I started to tackle the rust. You could use a wire brush in place of the sand paper.
1.Sand the rusted areas until you are down to smooth metal.
2.Apply the anti-seize with the brush included. You only have to apply anti-seize to the areas that were rusted but I did the entire face of the hub.
3.Wipe the excess with a towel.
…and you are done!
Here is the result:
Rear hub (After)
Front Hub (After)
Nothing too fancy but it looks a million times better then the rusted ones and you wont have hell every time you remove the wheels. BTW this only took me about a hour with one jack.
***Wallpaper of the month***
1/1/072/1/07
      08-05-2006, 10:11 PM   #2
oneshare325
oneshare325's Avatar
Drives: E90 325i, E82 135i
2018 BMW M3  [0.00]
2006 325i  [0.00]
Way to go, I don't think I would care that much, but great work man! Looks alot better!
      08-05-2006, 10:17 PM   #3
Collanrf
Collanrf's Avatar
Philippines
86
Drives: BMW 335i, Alpine White M Sport
2011 BMW 335i  [0.00]
Nice DIY Ryan. I guess i'll find out if i can take my wheels off in a couple of days when i change my wheels.
/// 2011 E90 335i M SPORT, ALPINE WHITE/// STEPTRONIC /// ZENON HEADLIGHTS/// 35% TINTS ALL AROUND /// 19 INCH BBS LM REPS ///BLACKED OUT ROUNDELS /// BLACK OUT GRILLS/// ACS ROOF SPOILER /// M3 REAR SPOILER /// LTMW INSTALLED (VOLLKOMMEN) M SPORT FRONT LIP /// BMS INTAKE///
      08-06-2006, 06:23 AM   #4
tron1043
85
Drives: G30 540i xDrive
2013 328i M-Sport  [0.00]
2012 F30 335i  [0.00]
Mr. Clean magic eraser works wonders
I have done something similar, however I used a Mr. Clean magic eraser being careful to avoid the rotor surface. I can't say if it works better than your approach, but it is a bonus that you don't need chemicals.
I am going to try the brake cleaner based on your post.
Nice post.
      08-06-2006, 12:25 PM   #5
irowharderthanyou
irowharderthanyou's Avatar
25
Drives: 330i TiAg
diesel, one thing you could try to put on there is corrosion block. I live right on the intercoastal (salty air) and use the stuff on everything i can think of. It is supposed to prevent corrosion for up to 6 months, but i would say more like 3-4. You can buy it at most hardware stores or boating stores. Hope this helps.
2006 330i TiAg - Beige, Step, ZPP, ZCP, Sat. Prep.
      08-06-2006, 01:52 PM   #6
ADHD
ADHD's Avatar
Drives: F30 328i
21 M540i  [0.00]
07 e90 335  [0.00]
Wow someone else thats as anal as me! lol....I thought i was the only one that took my wheels off when i washed my car! guess not! Good for u Ryan! I always get wierd looks when people drive by im out in the front lawn with a wheell scrubbing it...My neighbor calls me crazy every time he sees me doing it!
Ive always used the brake cleaner to remove the rust and a wire brush I never thought of the anti sieze compound! Have u pulled your wheels off after u did this?? can u take a pic of it in a week or so! how does the anti-sieze prevent rusting??//
      08-06-2006, 02:15 PM   #7
diesel007
Not Stock
diesel007's Avatar
Drives: 325I
2006 325  [0.00]
lol, it's the only way to get your wheels 100% clean, and don't worry I get weird looks too.
I will do a follow up in a couple of weeks and snap some pics to see if the anti-seize is doing it's job. The dried anti-seize should act as a layer of protection to prevent rusting and corrosion of the hubs so we shall see.
1/1/072/1/07
      08-06-2006, 02:25 PM   #8
diesel007
Not Stock
diesel007's Avatar
Drives: 325I
2006 325  [0.00]
Originally Posted by NaTuReB0Y
hey ryan.....bring your jack and anti-seize kit to the APM....
and do a DIY with my car as an example for the 40+ folks to see.........
hells no
1/1/072/1/07
      08-06-2006, 03:09 PM   #9
Asiann
Got Seoul?
Drives: 2012 535i MSport
2012 BMW 535i  [0.00]
2008 750Li  [0.00]
2006 BMW  [0.00]
Good post! Now I have another thing to add to the DIY list. I imagine this is only worse in areas of heavy rain.
Can you say Alooooha?
[SIGPIC][/SIGPIC]
      08-07-2006, 09:49 AM   #10
txusa03
548
Drives: TS330iPPSP6MT
you missed a few spots. I guess you have to do it again next weekend. Other than that excellent diy for those who are clean freaks your car is very lucky to have you as its owner...
      09-28-2006, 08:54 PM   #11
canucklion
pull my finger to get your kinder® surprise
canucklion's Avatar
148
Drives: circles around you
Thank you Ryan, this is GREAT
      10-04-2006, 03:27 PM   #12
therealm3
630
Drives: F30 340 MSport
nice work. I have a freind who paints his rotor hats with an anti corosive paint (silver) and it keeps them looking great. Bonus with that is you only have to do it once. From what I recall, the paint is similar to what they paint calipers with from the factory.
      10-04-2006, 03:50 PM   #13
E90Fleet
South Africa
1312
Drives: BMW
Do you guys get this more in the winter? Possibly from salt on the roads ?
Because here the rusting hardly happens ( we dont get snow)
My E36 is 10 years old, and hardly a spec of rust on the hubs
None on my old E39 either
BMW if you are reading, I need a job, Please.
      10-04-2006, 03:59 PM   #14
ward
155
Drives: F
good call diesel
it can be a PAIN to remove or attempt to remove stuck wheels!
      10-04-2006, 04:07 PM   #15
diesel007
Not Stock
diesel007's Avatar
Drives: 325I
2006 325  [0.00]
It does not snow here but the salty coastal air next to the coast is a contributing factor, also when washing the wheels water can seep though the wheel caps.
1/1/072/1/07
      10-14-2006, 12:59 AM   #16
magmd
magmd's Avatar
Drives: '06 330i
2006 330i  [0.00]
Man..that looks great. I need to do this soon on my car!
2006 330i | Black Sapphire Metallic | Step Auto | Navi with iDr | Sports Pkg |OEM Rear Spoiler | 3M CS35 Tint | H&R Sport Springs | Koni Yellows | Advan RS Racing Hypersilver: 19x9 et22 19x10 et20
      10-14-2006, 12:42 PM   #17
longtran
longtran's Avatar
1429
Drives: E90 M3
2006 325i  [0.00]
ryan, come up and do mine.. my shit have a lotta rust.
      10-14-2006, 01:27 PM   #18
diesel007
Not Stock
diesel007's Avatar
Drives: 325I
2006 325  [0.00]
***Rusty hub meet***
1/1/072/1/07
      10-14-2006, 11:47 PM   #19
just4kickz
boku no namae ha...
Drives: 2006 BS 330i
Location: S. Bay Area, CA + Newark, NJ + ChiCity + True Blue
2006 E90 330i  [0.00]
no jack... using spit and tissues will have to do.
looking for a PreLCI Black Sapphire e90 front bumper without license plate holes
"Akimbo shotguns. Broken wrists anyone? And don't give me that 'it's just a game' bull****. Where the **** are my akimbo interventions then?! One scope on each eye mother****er!!"
      10-15-2006, 06:40 PM   #20
longtran
longtran's Avatar
1429
Drives: E90 M3
2006 325i  [0.00]
we dont get snow in LA. is something wrong then??? i think we just wash our car too damn much.
      10-15-2006, 07:43 PM   #21
magmd
magmd's Avatar
Drives: '06 330i
2006 330i  [0.00]
I'm down for rusty meet
This weeK? LOL!
      10-15-2006, 10:24 PM   #22
longtran
longtran's Avatar
1429
Drives: E90 M3
2006 325i  [0.00]
i definitely need do mine. i'm down.
Tags
rusty hubs, rusty hubs fix
