Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Any thought on the lifespan of the 335s Twin Turbo Engine?
      08-04-2006, 06:06 PM   #1
BimmerDreamerFL
9
Drives: 328i or 335i (soon - i hope)
I hope to own my car for a very long time.
Yet I recall reading somewhere that turbo engines don't tend to last for as many miles as non-turbos.
Thoughts and opinions on the 335i's potential lifespan vs. that of the non-turbo 328i are most welcome...
Thanks,
BimmerDreamerFL
      08-04-2006, 06:33 PM   #2
kuthair
11
Drives: 07 335i Sedan 6MT
My guess is forever. I can't see this engine under normal usage dying in just a couple of years. It's like anything else... take care of the car and it'll take care of you.
Edit: I owned a chipped 1.8T A4 and I drove it hard. I never had a problem with the engine. It never burned oil, never. I put 60k miles on it before I lost it.
      08-04-2006, 06:34 PM   #3
ALPINE6SPD
ALPINE6SPD's Avatar
Drives: 2010 BMW 328i Sport
minimum 150k if properly maintained
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills
2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone
2008 AW X3 3.0si: 6 speed Returned
2006 AW e90 330i: 6 speed Dinan Stage 1 Returned
      08-04-2006, 11:04 PM   #4
revlimit
13
Drives: E92 335i Le Mans Blue
2015 BMW F10  [0.00]
turbo timer?
Is it possible to install a turbo timer on this? Is this turbo even oil cooled?
      08-04-2006, 11:10 PM   #5
meruyailir
meruyailir's Avatar
Indonesia
40
Drives: E90 325, E70 X5 3.0
Is following the BMW service routines considered properly maintained?
      08-05-2006, 12:02 AM   #6
Blue330i2006
Blue330i2006's Avatar
Drives: Blue330i2006
Thanks,
BimmerDreamerFL
If you let the turbos cool for at least 90 seconds before shutting off engine, this means letting the car idle, the turbos will last about 150,000 miles. the engine itself will last like any other, but you must be nice to the turbos and let them cool before just stopping them.
The 335 turbo engine has run the dyno for 250,000 miles nonstop.
But there was no ,, on off on off for the turbo.
I will let mine cool when shutting down.
You would think with all this technology that BMW would let the car run for 90 sec after key is remove to shut down turbos correctly.
      08-05-2006, 01:27 AM   #7
windnsea00
447
Drives: M2 CS
In most cases the turbos have come down to a safe temperature by the time a person parks. For example they go driving thru a garage, parking lot, around a few neighborhoods etc. If you just happen to pull over immediately after running the car hard than that would be a good idea but in most cases that doesn't happen.
2020 M2 CS AW 6-spd
Previous M Cars: M2C, M2, F80 M3, E46 M3, Z3M Coupe, E36 M3...and some other fun rides.
      08-05-2006, 08:18 AM   #8
kuthair
11
Agreed. This was evident in the A4, by the glow of the turbo. At night and after a hard run, you open the hood and low and behold the turbo is glowing RED. After normal driving however it didn't do this. I don't know if the 335i's turbos glow or even if you'll beable to see them. We'll find out soon.
      08-05-2006, 10:49 AM   #9
Paul330d
Torque junky
Paul330d's Avatar
France
115
Drives: Remapped e90 330d
2006 330d  [0.00]
2005 Fiat Panda 4x4  [0.00]
The vast majority of cars on the road in this part of the world are turbo diesels and, while there were a few reported cases of turbos failing a decade or so ago, I know of many TDs that go beyond 200,000km with no problem. In fact, I personally don't know of anybody that's had turbo problems.
www.greenkeepers.fr - spécialiste des tondeuses à gazon hélicoïdales atco qualcast ransomes lawnflite
      08-05-2006, 11:00 AM   #10
e90fanatic
Absolute0
e90fanatic's Avatar
168
Drives: Has a Roundel
turbos last a long time with proper care. Which means that if you drive it hard, make sure u give it 1-2 minutes idle of cooling when parking. Otherwise, synthetic oil is good enough for normal driving and helps prolong the life of the turbos
To procede or not to procede......
      08-05-2006, 11:20 AM   #11
Gripster
Gripster's Avatar
Drives: E93 M3
2013 BMW M3  [0.00]
Longer than the the CPO warranty.
Turbo engines get a bad rep, because they tend to be easy to mod to mucho hp and people overstress the engine. I remember talking to the Subaru service rep about the WRX engine. In the main, he had seen nothing to indicate shorter life span. What pissed him off, were 'the kids' that kept modding the cars, then bringing them back with melted pistons that they wanted replacing under warranty.
The engine should be fine. At least for 6 years / 100k miles. Time will tell.
2013 M3 (E93) - ZPP/ZCW/DCT
http://www.bimmerfest.com/forums/image.php?u=26275&type=sigpic&dateline=1208140506
      08-05-2006, 11:36 AM   #12
ALPINE6SPD
ALPINE6SPD's Avatar
YES and never skipping anything at all no matter what the cost.
      08-05-2006, 01:19 PM   #13
chonko
10
Drives: X6 50i/2008 X5 4.8i
The tubine blades configuration used in the N54 engine will have the following advantages over the turbines that are currently being used by some of the auto makers.
1. They are heat resistant within the operational window defined:1,050 °C or 1,920 °F.
2. They are small, thus the heat generated is far less than most of the configurations out there.
3. The implication of (1) and (2) is that the turbines will not require extra cooling to prevent metalurgical heat stress.
The driver just have to treat it like a regular engine.
      08-05-2006, 01:31 PM   #14
trurace
Drives: 335i ON THE WAY
Why do people think that turbo engines do not last long?
      08-05-2006, 03:36 PM   #15
chonko
10
Experience with Turbos of the past-maybe.
      08-05-2006, 04:06 PM   #16
lawdude
lawdude's Avatar
Drives: 335i ZPP ZSP TiAg MT
Turbochargers will need to be replaced way before the engine wears out. You'll trade the car way before the engine wears out.
      07-18-2013, 02:19 PM   #17
USAF Rick
USAF Rick's Avatar
Drives: Montego Blue 08 335i e92
5 years and 82k miles, still good to go! Lol.
FBO
Instagram: RickyyyyyH
      07-18-2013, 03:09 PM   #18
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
No reason you can't get this engine to 200K like any other 4 stroke that is properly maintained. Turbo's will always wear sooner then the engine. No need for a turbo timer this car automatically feeds coolant through the turbo's. They are water and oil cooled.
      07-18-2013, 03:15 PM   #19
135Pats
135Pats's Avatar
Drives: A few BMWs
At first I thought someone was asking this question in 2013…then I just realized it was merely a 6 year old thread bump
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII
      07-18-2013, 03:18 PM   #20
      07-18-2013, 03:24 PM   #21
USAF Rick
USAF Rick's Avatar
Lol, sorry.
FBO
      07-18-2013, 04:20 PM   #22
BMV///M3
BMV///M3's Avatar
419
Drives: BMW f80 M3
If I'm not mistaken doesn't the water pump continue to run for a bit once the car is off?
