BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > cc id 24/35
      05-11-2009, 06:54 AM   #1
chr9984
Drives: 320d
cc id 24/35
Hi,
Can anyone knows what these error codes means?
cc id 24
cc id 35
i got also the DTC not working beacuse of these error codes.
thanks for all the help.
      05-11-2009, 02:04 PM   #2
fnc
Drives: 540
See if this is any help.
Check Control Message Definitions BMW 3-Series E90 E91 E92 E93 https://wiki.bentleypublishers.com/x/MACT
      05-20-2009, 02:20 AM   #3
chr9984
Drives: 320d
thanks m8
this helps me, Its telling DSC Failed.
Can anyone knows whats this fault.
Can it be the DSC MODULE
      05-20-2009, 06:28 AM   #4
fnc
Drives: 540
Originally Posted by chr9984 View Post
thanks m8
You'll have to read fault codes to know exactly why the light is on.
      05-27-2009, 01:16 PM   #5
daviep.sco
United Kingdom
16
Drives: 2012 X3 2.0d SE
My car has just come up with the same codes CC-ID 35 and CC-ID 24. Has anyone any ideas what is up?
      02-26-2010, 05:36 PM   #6
BilLYtheKiD325i
smashin panties...
BilLYtheKiD325i's Avatar
Australia
21
Drives: 2008 BMW 325i E90
i had same error codes. i left battery disconnected overnight and the errors were gone in the morning.
      07-19-2010, 05:03 AM   #7
johnlaki
Drives: E90 320d
2005 320d  [0.00]
Here is my story:
I had the error coming up one day. All came as a surprise as I left my car parking for 3 hours and when I came back the light came on.
Here is what I tried:
1. Disconnected the battery for one night: No change
2. Disconnected the battery for one week: No change
3. Hook the car up to a brand new diagnostics computer at a non BMW dealer and reset the error: No change, warning came back
4. Took the car to a BMW in Germany(!) and diagnosed a sensor failure in the DSC/ABS unit. Tried resetting the error: No change, warning came back
Here is what I had to do:
Have the unit replaced at a final cost of 1700 Euros (bargained from 1900 Euros). The unit alone cost 1500 Euros. I tried every possible way to get one second hand or other sources on the internet. Also looked at the possibility of having it repaired (only a few companies do it in Germany) but got a nearly 500 Euros quote plus the cherry on the cake meaning reprogramming the unit at a BMW service.
Briefly about the unit:
BMW decided to put everything in one unit including the brain, sensors, hydro pumps and all the rest needed for stability, traction, anti brake and anti spin control. This makes this unit extremely expensive and apparently when one gets replaced it needs to be re-taught/programmed for the car taking about 2 hours. For this reason if you get a second hand one or get your one fixed it still costs a lot to have it fitted and programmed. And there is no guarantee that it won’t break again in 10 miles. If you get one from BMW you get 1 year guarantee at least.
Goodwill?
Having had 90k miles, 5-year old car I was refused any support from BMW, even in Germany. Although this is a relatively high mileage I am very disappointed with BMW not providing any support as this is a common problem to the e90 models. They do know about this problem, at least they should try not to make enormous profit on this unit. If they at least had a reasonable price on this unit, I’d have accepted the problem, but after this the message to everyone is this: If you haven’t had this problem with your e90 you can expect it to happen anytime!
It is a fantastic car, but a terrible rip-off when you need to fix such a small problem. At the end of the day, it was only a sensor...
      07-27-2010, 04:34 PM   #8
hotnikks
hotnikks's Avatar
Drives: F30 335i-Msport
I have all these errors right now. Just happened 20 minutes ago...I'm worried
06 E90 330i 6-spd (Retired)
14 F30 335i M Sport ZF
      11-10-2011, 06:41 AM   #9
Reichert
Drives: 2007 328i
I have had my 328i for all of 6 months. Sitting on the side of the road now with cc-ids 24,35,29,354. This happened once before, about a month ago. It seems completely random. Got a lot of brake related service due, hoping the module isn't a part of it...
      01-22-2012, 08:28 PM   #10
ocomas
Drives: 2020 M4 Convertible
Reichert. Any updates. Mine just came up too.
