DMTL pump bad
05-08-2009, 08:13 AM | #1 |
189
Rep 609
DMTL pump bad
Service engine soon light came on last week, Dealer had to replace the DMTL pump (Diagnostic Module Tank Leakage) . I had the High pressure Fuel pump replaced two months ago??
Have many folks had the DMTL pump replaced?? Did some Google searches, looks like BMW has had problems with the DMTL pump going back to 2001.
2019 Z4 sDrive 30i Msport,
Previously owned BMWs, 2014 428i Msport, 2008 335i Coupe, 2007 328xi sedan, 2002 325i sedan 1996 318ti (loved this little car) Last edited by Christos; 05-08-2009 at 09:29 AM.. |
05-08-2009, 08:30 AM | #2 |
One cam is enough
132
Rep 6,801
Wow that's the first time I've heard of that.... I wonder exactly what happens when this goes bad...?
05-08-2009, 08:38 AM | #3 |
90
Rep 2,707
It's on this pic http://www.realoem.com/bmw/showparts...19&hg=16&fg=10
I am assuming the pump is used to detect fuel leaks. So all in all does nothing until you do in fact have a leak.
zhpregistry.net - ZHP stats and free classifieds.
05-08-2009, 10:27 AM | #4 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
I had it replaced, its just emissions diagnostic pump. Its what you hear running in the left side of the trunk after you turn the car off.
05-08-2009, 10:32 AM | #5 |
814
Rep 3,953
05-08-2009, 02:48 PM | #6 |
king of the hills
92
Rep 2,915
Interesting, I was told by the service guys that the noise you hear back there is the DMTL pump. I know the amp is on that side too though, so it makes sense as well.
05-08-2009, 02:58 PM | #7 |
814
Rep 3,953
You door here the pump for about a second when you unlock the door (or open the drivers door) or the car wakes up.
05-11-2009, 05:29 PM | #8 |
76
Rep 1,292
Just got mine replaced today on 2007 335i coupe with 23k miles. Service engine soon light came on and dealer diagnosed as DMTL pump. Had never heard of it until today and I came home to search and found this thread.
05-11-2009, 05:57 PM | #9 |
60
Rep 965
Drives: '14 328xi sport line
Garage List 1981 Fiat 124 Spider [0.00]
2014 F30 BMW 328xi [0.00] 2006 E90 BMW 325i ( ... [0.00] 1988 Audi 90 Quattr ... [0.00] |
I had it replaced last week, after the car had a check engine light a week after buying it. At first they just reset the code, but it came back and so they replaced the pump. The code hasn't come back *crosses fingers*
Biginboca3763.50 |
06-11-2009, 08:03 PM | #10 |
129
Rep 276
Woah... I just had my car for two weeks, and the check engine light came on. Same thing - they replaced my DMTL pump.
12-14-2010, 08:24 PM | #11 |
Rep 2
DMTL Pump Repair
2006 330i
After overfilling the gas tank once, the check-engine-light came on within a day or two. The OBD code reader led me to the DMTL pump, which I think is a vacuum pump that sucks the fumes from the top of the gas tank near the filler cap. With the help of the diagram earlier on this thread, I found it and removed it. Partial disassembly (unsprung the 6 or so plastic clips around the plastic housing) revealed a small 12V DC motor. Applying 12V to the motor terminals resulted in turning the motor, but the action was not smooth. I was able to get it apart further, eventually taking apart the tiny vane pump - a circular rotor with 4 sliding inserts, all made of black plastic. I lightly lubed the rotating parts with some motor oil, and reassembled. Testing it with 12V DC gave a better action and sound. I then reinstalled to the car, reset the OBD codes with the code reader/resetter and it's been fault free for the last week or so! My guess is that when I overfilled the gas tank, liquid gasoline was ingested by the pump, which would have had the effect of washing away any lubricant from the internal surfaces of the vacuum pump parts, causing it to run slowly or seize once it dried. Will let you know if the lube job holds or not! Jan.13.2011. Update: Still no check engine light, no faults, for a month now. June.29.2011 Update: Kept throwing P1447 codes for last few months, so bought a new replacement DMTL pump online, installed it today, reset OBD. Fingers crossed. Last edited by 330icanadian; 06-29-2011 at 08:39 PM.. Reason: update 13-Jan-2011 |
12-15-2010, 05:28 PM | #12 |
22
Rep 220
What codes are you guys getting? I'm getting p2402 and people are saying it's this pump. Does anyone know how to test this pump first before i go and replace it?
12-15-2010, 07:03 PM | #13 | ||
253
Rep 7,089
Drives: '06 AW 330xi
The CEL may have just been a coincidence. Quote:
I also believe that P code points to a faulty pump but it could also be a leak. Faulty o-rings or a hole in one of the vent tubes. You really have to get your EVAP system smoked to check for leaks. BTW, how do you guys over fill a gas tank? I've never had that happen to me. |
12-16-2010, 10:53 PM | #15 |
253
Rep 7,089
03-09-2011, 02:37 PM | #16 |
23
Rep 188
Just got back from my local shop, I had my my check engine light come on two days ago.
He ran a scan on my car and it came back saying i had an error with my DMTL pump. He cleared the error & told me to drive it around for a week. If it came back, he can replace the part for $291.00 installed (i am out of warranty). I will keep you guys posted. |
03-09-2011, 02:40 PM | #17 |
12
Rep 219
03-09-2011, 08:36 PM | #18 | |
Very Important
20
Rep 450
Drives: 335xi (e92)
Garage List 2008 BMW 335xi (e92) [9.00]
2008 Pontiac G8 GT [4.00] 2002 Pontiac Grand ... [0.00] 2001 Cadillac, Eldo ... [0.00] |
04-29-2011, 07:11 PM | #19 |
41
Rep 487
Over the past 3 days I started getting 3 different codes, all related to the DMTL. Is this something that can be replaced on your own, or does the dealership have to do it?
BTW, my codes are: P1434 - DMTL malfuntion P1447 - DMTL pump current too high during solenoid test P1449 - DMTL pump current too high
04-29-2011, 07:21 PM | #20 |
253
Rep 7,089
DMTL pump is easy to replace. Just remove the panel under the passenger side rear, remove the 3 or 4 screws for the carbon canister, then you can drop that down and see the pump on the front side of the canister.
01-13-2012, 05:00 PM | #21 |
Rep 69
I just bought a 2002 325i and of course 2 days after the CEL came on and it is throwing the DMTL Pump. Where can I buy a DMTL pump for my 2002 325i? I have looked but cannot find any..I guess I am looking in the wrong place :/
01-13-2012, 06:49 PM | #22 |
138
Rep 2,731
