BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      05-07-2009, 11:18 AM   #1
nkweisberg
Drives: E92 M3 Le Mans Blue / Bamboo
The offset that works with an 18X10 Square setup
Fitted my new track rims yesterday. CCW C10's. I'm happy to report that 18X10 with a 25 offset works perfectly all around. No rubbing at full lock, good clearance with Dinan Springs installed (1/2 inch drop). Fills out wheel wells nicely. Now will be able to rotate tires for better wear between track sessions. There is monster clearance in these rims for BBK's.
Removed the back plates behind the brake rotors, hopefully that will help with brake cooling. Was able to get 2.2 degrees negative camber with the dinan camber plates installed. Drove on highway and not too squirrelly even with the extra camber. Will see how my street tires wear with this setup.
Going to PBIR (formerly Moroso), the gumball rally participants are going to be there after their cross country run. Next weekend going to Sebring. I think I am getting everything dialed in, my weakest link is now my brakes (stock rotors and calipers, Castrol SRF, SS lines, Ferodo pads, back plate behind rotors removed). Looking forward to trying out the new springs, camberplates, rims, slicks tomorrow.
      05-07-2009, 11:51 AM   #2
lucid
lucid's Avatar
Drives: E30 M3; Expedition
Nice. How long did it take you to remove the backing plate/shield? I don't know how fast PBIR is, but I suggest that you monitor your rotor temps, and turn it down a notch if they approach 600C at the paddock. I use an infrared thermometer. I'm getting my Dinan springs and camber plates installed Monday. Looking forward to your track impressions.
      05-08-2009, 09:39 PM   #3
nkweisberg
Very happy with the Dinan springs/camber plates. The car corners much flatter with minimal roll. Less dive on hard braking. The ride feels no harsher, just more controlled. I believe the camber plate changes the geometry of the front suspension such that it negates the 1/2 inch drop the dinan springs provide. The rear is definitely lower, the front is not.
The brakes definitely ran cooler with the rotor back plate cut off. The fronts unbolt when the suspension is taken down to put the camber plates in. The rears have to be cut off.
The biggest difference was the hoosiers. Such a difference running track rubber vs the PS2's.
After seeing my car on the black track rims I think I'll need to powder coat my OEM 19's.
      05-08-2009, 11:18 PM   #4
lucid
lucid's Avatar
Thanks for the update, and enjoy the car...
      05-09-2009, 12:51 AM   #5
bigjae1976
bigjae1976's Avatar
1570
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
Looks awesome! Is that the painted satin black finish?
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      05-09-2009, 01:10 AM   #6
jml
jml's Avatar
128
Drives: X5M, GT3RS, GT4
What width tire are you running? Can you measure the clearance on the front strut? I am looking to see if we can fit 285/295s on this beast.
      05-09-2009, 10:34 PM   #7
nkweisberg
Lucid, let me know your impressions after you track the dinan springs. Noticed that Dinan recently added a front sway bar to their offerings. Are you doing this as well? Car really is pretty flat through corners.
Wheels are shotpeened black anodized, not painted. Supposed to be more durable.
Tires are 275/35's. Don't know if 285's would fit the front, likely a bit ambitious...
      05-10-2009, 10:17 AM   #8
bigjae1976
bigjae1976's Avatar
1570
2004 BMW M3  [4.50]
Cool. It is hard to tell from the pics but does it look different from the typical painted matte black?
      05-10-2009, 10:55 AM   #9
lucid
lucid's Avatar
Will do. I'm supposed to be at Limerock next weekend with BMW CCA if I can sort some pad issues out. I saw the sway bar on the Dinan website. It wasn't available when I ordered the springs and the plates. I think I'll hold off on that to see some reviews, etc.
      05-13-2009, 01:33 PM   #10
attbimmer
attbimmer's Avatar
13
Drives: '08 E90 M3, '88 E30 M3
Here are some pics of 18x10s mounted with 285/30/18 V710s. These are for my E36, but I figured I'd mount them up just to check. The wheel offset is 40 and I have a 12mm spacer in front and 15mm spacer in the rear. The front fits just right with only 1 degree of negative camber (suspension is stock). There is a lot more room in the rear.
This should make for a pretty good autox setup. The smaller overall diameter helps quite a bit (increasing the effective rear gear ratio), which should help in the tighter sections.
m3post
