05-03-2009, 11:28 AM | #1 |
7
Rep 87
Wheel Torque settings
Hi
I've got the OEM 19s on my car and will be getting a set of OEM 18s for use as track tyres. I assume that when I swap these over I should use a torque wrench to tighten them up. Is the correct torque listed anywhere in the manual? I assume it'll be the same for both sets of wheels. Thanks
Car blog: http://mr04drs.giles.roadnight.name/
05-03-2009, 11:43 AM | #3 |
11817
Rep 23,187
what he said.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
05-04-2009, 04:07 AM | #4 |
7
Rep 87
Thanks guys, is that out of the manual? I couldn't see it.
05-04-2009, 10:02 AM | #5 |
11817
Rep 23,187
didnt look for it in the manual. this is just what i have been told my numerous people when i asked. Stricly BMW, les schwab, BMW service. its 88.
05-04-2009, 10:12 AM | #6 |
shop smart, shop s-mart
8
Rep 84
yeah, 88 is what my old E46 manual recommended, so I too have been using that setting for the E90 M3 as a 'good enough' guess.
2015 X5 xdrive35i
2008 E90 M3 2002 325Ci Convertible |
06-01-2009, 03:02 AM | #10 |
1570
Rep 8,075
Drives: 11 E90 M3 Individual
IIRC there was a TSB that changed the wheel torque spec from 88 ft/lb to 92 ft/lb for E46s. I know I changed from using 88 to 92 for a reason.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
06-08-2009, 11:15 AM | #11 |
7
Rep 87
Thanks for your replies guys.
I just phoned up BMW service and he said that the torque setting is 120 ft lbs for the E92 M3. Is this different as you guys are talking about E46?
06-08-2009, 11:23 AM | #12 |
374
Rep 8,033
This is good info. Thanks. But it contradicts the info posted above by Thinker23. I wonder if his jack set was M3 specific. I've been going with the E46 spec after asking around BMW CCA folks as I couldn't find any specs in the manual for the E92 M3. I now feel the need to call my service guy since we have too many different numbers floating around. Does anyone have a "published" spec on this?
06-08-2009, 12:03 PM | #13 |
48
Rep 1,664
120 seems extremely high? Anyone verify this? 50% increase? I would be shocked if it differs greatly from 88, thats what I had torqued for 3 consecutive track days, none of them budged.
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options 2007 Montego Blue 335i (retired) Last edited by Dascamel; 06-08-2009 at 12:52 PM.. |
06-10-2009, 01:56 AM | #14 |
7
Rep 87
I'd rather have it too tight than too loose!
06-10-2009, 03:00 AM | #15 | |
1570
Rep 8,075
120lb/ft? That seems pretty high. I guess a tech or service advisor would have the right answer for sure.
06-10-2009, 03:34 AM | #16 |
7
Rep 87
Can someone else phone up their service department and ask the same question? If we get the same answer I think we can believe it.
What's the downside for having it too tight? Damaging the wheels?
06-10-2009, 09:15 AM | #17 | |
285
Rep 6,007
Got mine at 90 ft. lbs and my wheels haven't fallen off yet think I'll leave it.
06-10-2009, 12:36 PM | #19 | |
374
Rep 8,033
http://www.rogueengineering.com/Merc...t_Code=WSPACER They also state that the BMW spec for M12 bolts is 88 ft lbs. I don't have access to my car, so I can't check to see what kind of bolts are on it. Someone should check this, and call their SA. RE says spec is higher for M14 bolts.
06-10-2009, 01:20 PM | #20 | |
8300
19
Rep 573
Shortly after delivery my lug nuts where <90lbft so no way 120 is the way to go. I keep them at 90 lbft. I don't trust random SAs but I will ask the good independent shop I use for my track inspections and misc work. |
06-10-2009, 03:21 PM | #22 |
30
Rep 915
I agree with 120 being too tight. 88 to 90 sounds correct. Mine were in the 90 lbs range on delivery however I have no confirmation this is the correct setting. Over tight can cause failure. I have seen it happen at the track. Lugs will expand as they heat up.
vz
Previous Track Toy |
