Help Dead Clutch
04-24-2009, 02:45 PM | #1 |
49
Rep 494
Help Dead Clutch
Searched the forum and still have a dead clutch due to my CDV removal.
I removed the CDV and did the clutch bleeding procedure. press pedal open bleeder, close bleeder pull pedal up, then pump. Still dead Then I got a bleeder and sucked out about 30 ml of fluid and now now more fluid is coming out. I then used the bleeder to push air into the reservoir and I am not getting any fluid coming out. The car only has 5000 miles on it. I can not engage it into first gear. help Pittsburgh,pa |
04-25-2009, 05:54 PM | #3 |
9
Rep 250
You need to make sure you bleed the clutch properly. I've bled many clutches on many cars, and when I did it to my E90, it needed way more pumping.
Check out this DIY that I posted. http://www.e90post.com/forums/showthread.php?t=226714 |
04-27-2009, 08:13 AM | #4 |
49
Rep 494
thanks
Thank you for all your advice, I am going to try it again...I am trying to avoid flatbedding the car to a mechanic when I can hopefully do it myself.
If this bleeding technique dosent work, I may just buy a motive pressure bleeder and just pump the fluid through the reservoir. thanks again |
04-27-2009, 09:32 PM | #5 | |
9
Rep 250
