DIY - Clown nose blinking LED
07-21-2006, 04:50 PM | #1 |
28
Rep 375
If you like me is annoyed by clown nose doing nothing but do not need/want to spend $400 on real BMW alarm than read on.
The following process is not complicated and can be done by almost anybody in a couple hours or so. You’ll need to put together a very simple electronic device. You can buy all parts from Radioshack for under $10. Here is what you need: TLC 555 Timer Item: 2761718 Description: LinCMOS Timer Quantity: 1 @ $1.69 Item: 2760159 Description: General-Purpose IC PC Board Quantity: 1 @ $2.29 The rest of the parts I already had but if you need to buy them they are also available at www.radioshack.com. For R1, R2 and R3 I used pot (adjustable) resistors. For C1 I end up using 1000mF capacitor. The electrical diagram with pictures is bellow (the LED on a photo was for ease of adjustment since I had to go back and force from my car. I removed LED on board and replaced it with connections to LED in clown nose in a last step). Next you will need to connect to the LED insight the clown nose. There are at least two ways that I found to connect to it. First (the way I end up doing it): The LED (12V) insight the clown nose located on the rear view mirror. Mirror is attached to a black cover of rain sensor. The cover holds in place by springs which hold on to a hex bolt head permanently attached to the windshield (please see pictures and diagram bellow). To detach just twist (I did not have to apply a lot of force) the black cover with rear view mirror about 15-30 degree or so and it comes right off. The plastic cover is made of two separate inter-locking pieces. Insight you will find rain sensor plug at the bottom and LED plug were mirror is attached. I end up removing the LED plug and running two wires to LED directly thru wiring hose from light/sun-roof panel. Than I put everything back by twisting cover with mirror back in place. Second way is to use existing LED wires which already go to the light/sun-roof panel. I think they were black and brown color but I did not want to spend time tracing them. Last step: we'll need a 12V power that will be on when car is locked/not running and off when car is unlocked/running. Proceed to remove light/sun roof panel (you can find instructions on "how to" on this forum under DIY alarm installation). Insight you will see large white plug (1-20 connections), large black plug (1-20 connections) and a smaller black plug (1-14 connections) -- you need 1-14 connections black plug (see pictures bellow). There is a couple more smaller plugs (1-4 and less) that you don't need. On 1-14 connections black plug (wires are labeled 1-7, 8-14) the connection with number 1 behaves the way we need. It has 4.6V when car is running and after the car is turned off and locked in a minute or so the voltage changes to 12V. Interestingly enough if car is not running and you unlock it and wait about 3-5 minutes it also changes from 4.6V to 12V. Connect positive (+) wire from the timer you built in step One to number one connection on 1-14 black plug and negative (-) wire to ground (I used bolt near motor). Now, if you have a multimeter it helps. You can connect it in parallel to the timer and if you don’t it is not a big deal either. Adjust R3 so when there is 4.6V (car is running) the timer is off (LED is off) and when there is 12V (car is locked for more than a minute) timer is ON (LED is blinking). Adjust R1 and R2 to get desired timing/delay (how long the LED is On and Off). Note: the timer allows you to set up almost any percentage/delay you want. What I chose to do is to pull my car next to another BMW with factory alarm installed and matched the LED to that car. Enjoy! PS Please note there is a typo on a diagram - C1 is 100-1000uF Last edited by msinfo_us; 05-06-2007 at 08:42 PM.. |
07-22-2006, 03:51 PM | #3 |
15
Rep 292
wow.pretty sure a lot of memeber will try this.... i spend the 400 on the alarm ...great DIY..
330i Jet Black on Black, ZSP, ZPP, Steptronic, Clear Bra, Comfort Acess, Sirius, OEM Alarm
Mods:20% Tint F/R, Xenon Interior Lights, Xenenis Tru-match Fog Lights, , V1 (hardwire), Black and White Roundels, Blackline Tailights, White Angel Eyes (PMB), (2) 12'' Kicker L7,TvandNav2go, Playstation 2, ACS Roof Spoiler, 5 Series iDrive Leather Knob, Brex kit |
07-22-2006, 04:32 PM | #4 |
Got Seoul?
116
Rep 2,862
Drives: 2012 535i MSport
Wow I might have to try this if I can understand all the techincal jargon.
Can you say Alooooha?
[SIGPIC][/SIGPIC] |
07-22-2006, 05:29 PM | #5 | |
28
Rep 375
07-22-2006, 05:34 PM | #6 |
364
Rep 5,842
Drives: 2006 325xi
very nice job... impressive and creative
07-22-2006, 05:52 PM | #8 |
Administrator
40807
Rep 21,240
Excellent DIY, added to Master DIY List
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
07-23-2006, 07:21 AM | #9 |
34
Rep 519
msinfo - this is awesome. do you think you can translate this, when you have time, into step-by-step instructions for a complete novice, including what exact tools to buy? Links to the tools and components on radio shack's website would be helpful too.
nice work.
'14 535i (ED)
Retired: '08 M5, '08 550i (ED), '06 330i |
07-23-2006, 10:57 AM | #10 |
28
Rep 375
Here ya go:
R1 and R2 http://www.radioshack.com/product/in...entPage=family 10K-Ohm Horizontal-Style Trimmer $1.29 Model: 271-282 Catalog #: 271-282 for R3 you can try this bundle (unfortunetly they don't mention specifications of what is inluded but I am sure 20 or 30K will be part of the bundle. They are very common) http://www.radioshack.com/product/in...53&tab=summary or use R1 10K pot in line with 10K resitor from this bundle http://www.radioshack.com/product/in...entPage=search 100-Piece ½-Watt Carbon-Film Resistor Assortment $6.29 Model: 271-306 Catalog #: 271-306 Another option all together is to use regular resistors from this bundle. the only disadvantage when you have to calibrate timer you will end up replacing resistors until you get desired results insead of simply adjusting it. C1 http://www.radioshack.com/product/in...entPage=search 1000µF 50V 20% Axial-Lead Electrolytic Capacitor $2.59 Model: 272-1047 Catalog #: 272-1047 D1 http://www.radioshack.com/product/in...entPage=family $2.59 Model: 1N914/1N4148 Catalog #: 276-1620 If you don't have soldering tools you can try this one but choices are many http://www.radioshack.com/product/in...entPage=family 5-Piece Basic Soldering Set $7.99 Model: 64-2802 Catalog #: 64-2802 You can buy decent and chip multimeter from http://www.homedepot.com/prel80/HDUS...gjj.0&MID=9876 Gardner Bender 19-Range Digital Multimeter Model GDT-190A Price: $19.99/ea |
07-24-2006, 07:34 AM | #11 |
548
Rep 6,563
dude this is great that you took the time to write up and share. Unfortunately, I am a dummy when it comes to electrical (I took electrical engineering 101 and I got fried in a 101 lab when I was a freshmen-that was enought to make me change my career ).
sure beat paying $300-$400 for the alarm. Too bad, I am no where near NY. |
07-24-2006, 08:24 AM | #12 |
Commander in Chief
37
Rep 1,034
Thats an amazing DIY. I seriously hope you are working as an electrical engineer. If not, you need to change your career!
I haven't looked at an electrical circuit since my college physics class. This is the type of stuff that confirmed that engineering was not for me. Considering the complexity of this modification, I almost feel like I got off easy by paying for the alarm installation.
2008 BMW 535i Space Gray, Black Leather, Dark Bamboo Trim| Sport Automatic with Paddles | Sport Package
2008 BMW M5 (gone, but not forgotten) Space Gray, Silverstone Merino Leather, Madeira Walnut Wood Trim | 7speed SMG | All options Mods: Corsa Exhaust | RPI Ram Air Intake | H&R Sport Springs | Rogue Engineering 12mm spacers |
07-24-2006, 08:55 AM | #13 |
277
Rep 3,924
damn, aren't you an engineer! thanks for the write-up!
2011 E92 M3 - IB/Beige/Sycamore Wood/6MT/EDC/ZPP2/Nav/PDC/Heated Seats/iPod-USB/Enh. Audio
2008 E92 335i - Montego Blue/Black/Gray Poplar/6MT/ZPP/ZSP/Nav/PDC/Heated Seats/HDRadio/iPod-USB - Sold 2006 E90 330i - Mystic Blue/Black/Aluminum/6MT/ZPP/iDrive/PDC/Heated Seats/Sat. Prep - Sold 1994 E36 325i - Boston Green/Beige/Automatic/ZPP/Heated Seats/Premium Sound - Sold |
07-24-2006, 09:16 AM | #15 | |
548
Rep 6,563
can you publish a "Dummies for blinking e90 clown nose". I could use the book
07-24-2006, 09:50 AM | #16 | |
46
Rep 1,445
07-24-2006, 10:14 AM | #17 | |
548
Rep 6,563
07-24-2006, 02:02 PM | #18 | |
46
Rep 1,445
I don't need him to install; I would just like for him to gather the parts and make the device. |
07-24-2006, 02:04 PM | #19 |
28
Rep 375
Guys. This really does not require a MS in EE. Everything is already integrated in a chip. The chip is only eight legs that you have to connect -- how difficult can that be? The chip has a sign for where the first leg is and it is four legs per site (1-4 and 5-8 on two sites). The all thing is a couple resistors and a capacitor, look at the picture. Does it look complicated? ....
PS I do have a MS in Robotic Systems but I am working as a manager for over 10 years -- if I can do it, anybody can. |
07-24-2006, 02:19 PM | #20 | |
548
Rep 6,563
Thanks for the encouragement post...but I am not touching this with a 10feet poll. |
07-24-2006, 02:28 PM | #21 | |
46
Rep 1,445
Glad I'm not the only one. HAHA |
07-24-2006, 04:51 PM | #22 |
16
Rep 80
OK, so let me get this straight...You did all this just to get your clown nose to blink when your car is locked?
So now when people ask me what that thing is for I can now tell them that its not part of an alarm system that I don't have but instead its just a blinking light that comes on when my car is locked. |
