04-13-2009, 08:26 PM | #1 |
BMW Novice
69
Rep 237
Drives: M Coupe
RPI Skid Plates?
Where can I get them, for how much, and how is the installation???
Thanks
04-14-2009, 02:28 AM | #3 | |
BMW Novice
69
Rep 237
Drives: M Coupe
Installation isn't that difficult, right? How much do you think it will cost at some average auto shop??? I'm asking b/c, for the first time, today I left my M at an auto shop. They are supposed to fix the dent in my lower bumper that happened to me at a local car wash (the car wash is paying for it). If they do a good job, I'll order the skip plates
04-14-2009, 08:40 AM | #5 |
Rep 165
How many would recommend these skid plates and do they fit both the coupes and roadsters? Seems like a good idea...
'06 Z4 ///M Roadster: Silver Gray Metallic; Gray soft top. Zeckhausen CDV. ESS VT1 445 Supercharger. APEX ARC8's. Dunlap Direzza Star Spec's. Strong Struts. Royal Purple. RPI Exhaust w/ DKF hangers.
04-14-2009, 02:00 PM | #7 | |
BMW Novice
69
Rep 237
Drives: M Coupe
So, do you fit the plates to the very edge of the bumper, or the bolts will show you where it's supposed to be?
04-14-2009, 02:13 PM | #8 |
Rep 165
Sounded good enough that I ordered a set. They are configured for both models (as we would assume since they have the same undercarriage). I would also like to add the clear bra to keep the front end as clean as possible. Maybe next month after my contribution to US treasury.
It takes at least one curb to figure out the safe parking distance!!! thanks to nmulax for the link
04-14-2009, 09:48 PM | #9 |
BMW Novice
69
Rep 237
Drives: M Coupe
Just ordered mine, too
04-14-2009, 10:30 PM | #11 |
BMW Novice
69
Rep 237
Drives: M Coupe
I think I have that, LOL
04-18-2009, 09:34 PM | #12 |
Rep 165
Plates went on fine tonight. Getting the car lifted was the tough part. I had hoped they would habe been slightly bent up (rounded) along the leading edge but this will do. The center spoiler could also use a strip....
05-23-2009, 11:14 PM | #14 |
Hooligan
55
Rep 680
I heard the skid plates are worthless as they don't sit flush against the underside of the bumper.
2014 Porsche Cayenne Turbo S 2011 X5 5.0 Dinan - SOLD 2007 Imola Red Z4 M Coupe -SOLD 2004 Navy Blue BMW 325Ci |
05-26-2009, 07:26 AM | #15 | |
112
Rep 1,262
http://www.zpost.com/forums/showthre...&highlight=rpi |
08-13-2009, 04:34 PM | #16 |
World Traveler
Rep 12
The skid plates do lay flat on the car or else they would plain out break off.
Their main design is to take the scrapes the body of your car would anyway. You can drive slow around every bump but you won't be able to avoid all of them.
Michelle Hodges
Race Precision, Inc. (RPi) For optimal performance, aesthetics, and sound, shoprpi.com!!! |
08-13-2009, 09:06 PM | #17 | |
CarbonFiber Engineer @ ZeroMassMotorsports
40
Rep 1,481
Also..a slight 90 degree bend as a leading edge would have been using some product foresight. The customer can always re-spray with paint as needed to keep cosmetically nice. |
08-14-2009, 04:06 AM | #18 |
168
Rep 1,792
What kind of paint should I use if want to "refresh" my plates a bit? Better, where can I have the plates made in delrin (most motorcycle frame sliders are made of delrin)
08-14-2009, 04:37 PM | #19 | |
40
Rep 1,481
There are a few types of Delrin....some white,some blk but I believe its called something else..slips my mind. A piece of Delrin would slide fine over concrete or asphalt...but would also allow a faster cut-in that could eat away at the fasteners. I've got a thin sheet of Titanium back at the Lab...I should make some from that so I can freak others out when scraping at the track with the pretty colored sparks that will fly !! |
08-18-2009, 06:39 PM | #20 |
Custom User Title
141
Rep 661
Tip on appearance of skip plates
I like the plates, but the powder-coating on them is thin and fragile. The plates are bright aluminum underneath. My alignment guy bent one plate pulling onto his lift, so I bought a second pair and use the remaining good one as a spare. The plates are symmetrical and fit either side of the car by turning them over.
I found that the cheap door-edge molding in black sticks nicely over the front edge of the skid plates and usually prevents taking off the black powder-coating in the event of a scrape. It's nearly invisible and it's easier/cheaper to replace the molding than repainting the skid plates every time it happens. Overall I recommend the plates - much cheaper than a new bumper. Last edited by blender; 10-01-2010 at 09:46 PM.. |
08-20-2010, 03:56 PM | #21 |
91
Rep 1,546
so...i was looking today and it seems rpi doesn't make skids any longer? or am i just not seeing it anywhere.......
also... crfine...how's that little project comin? lol
08-26-2010, 11:03 AM | #22 |
437
Rep 2,747
Slow but sure
LINK TO 07 IR PHOTO JOURNAL:http://www.zpost.com/forums/showthread.php?t=1303735
LINK TO 06 IB MOD JOURNAL:http://www.zpost.com/forums/showthread.php?t=403119 |
