6MT Drivers - coming to a stop...
07-17-2006, 10:56 AM | #1 |
100
Rep 1,013
Do you gear down through every gear when approaching a stop or do you put it in neutral and just apply the brake?
Pros / cons of both?
Paul
07-17-2006, 11:07 AM | #3 |
442
Rep 4,838
Both, although no matter how lazy I am, I downshift to at least 3rd before kicking in the clutch pedal and braking. I only put it in neutral when I'm completely stopped.
Pro of downshifting is that you're always in the right gear to accelerate if need be. Con is more clutch wear I guess. Neutral coast is opposite. |
07-17-2006, 11:07 AM | #4 | |
275
Rep 9,218
This is called engine braking and using this in conjunction with your brakes will slow your car more efficiently and with improved control. You will also avoid unnecessarily heating up your brakes giving you a performance advantage. |
07-17-2006, 11:10 AM | #8 |
12
Rep 552
does gearing down have any affect on gas milage?
Delivered: 10/21/08 | 09 e92 335i|AW|CR|PP|SP|NAV|PDC|CA|6MT|iPod|Logic7
Sold: 06 330i/Mystic Blue|Terra|PP|SP|NAV|CA|6MT|Butt Warmers|Rear Shades|Fold Down Seats |
07-17-2006, 11:19 AM | #9 | |
275
Rep 9,218
This isn't really an 'optional' thing - the RIGHT way to drive a manual is to engine brake. Not only to ensure that you don't fry your brakes - but also to make certain that you are always in an appropriate gear. You don't need to go all the way down to 1st and nothing will explode if you miss a gear - but seriously - don't brake from 80mph to a standstill without changing down from 6th. You have to drop the clutch anyway or it will stall - so why not go a bit further and ride the gears down. Even auto's are set up to take advantage of engine braking - so it can't be bad. |
07-17-2006, 11:22 AM | #10 | |
890
Rep 7,047
As my speed slows I adjust the gear. The reason for this is that I want to be in a viable gear in case I need to move out of there quickly, like if a car is barrelling down on me from behind. To reiterate, I do not go down sequentially engaging every lower gear on my way to a complete stop. And, I do not coast with the gear lever in neutral, I coast to the stop with my foot on the clutch pedal and the gear lever in a proper gear. |
07-17-2006, 11:25 AM | #11 | |
Rep 59
06 330i TS/ZSP/Steptronic/CA/Burl/Gray Leather/Fold-Down Rearseats/Power Sunshade
07-17-2006, 11:26 AM | #12 |
100
Rep 1,013
Personally, I do gear down, and was doing it on the way to work this morning and thought I'd find out what other e90 6MT drivers were doing. Saves the brakes, but more importantly, reduces that pesky brake dust!!!
Paul
07-17-2006, 12:18 PM | #13 |
Moderator
7515
Rep 19,368
I definitely never put it in neutral while moving, but don't go down through every gear either. Almost never drop to fourth or fifth. Usually drop to third initally, but sometimes go all the way to second. It depends on my speed, how much stopping distance I have, and how close people are following behind.
07-17-2006, 12:33 PM | #14 | |
14
Rep 710
07-17-2006, 12:35 PM | #15 | |
2432
Rep 11,667
This I agree with this ^^; You should always be in a gear ready for action. My previous point was that the emphasis should still be on using the brakes. The original post was on coming to a general stop... eg at a traffic light. JMO, but other comments about frying brakes are completely unfounded. |
07-17-2006, 01:04 PM | #16 | |
890
Rep 7,047
Engine braking is good when going down a mountain and you need to check your speed and not overheat your brakes and maybe lose them. But, when coming to a stop light and a complete stop, USE the brakes. That is what they are for. And, if you learn to use them properly they will last a good long time. I prefer using the brakes for coming to stop rather than transferring forward motion into trans gear wear and driveline wear. |
07-17-2006, 01:12 PM | #17 |
Black Sapphire 330i
32
Rep 362
Interesting there's nobody who's posted heel-toe braking yet. I single clutch (rev-match 1st) always when slowing (double's no longer needed thanks to synchro). This is fine for relaxed or daily driving. In more spirited conditions, heel-toe is much better for faster downshifting and maintaining the car's balance when entering, apexing and accelerating throgh corners.
Either way, I always shift when decelerating. The type of downshifting changes depending... |
07-17-2006, 01:36 PM | #18 |
Smiling politely
165
Rep 7,931
I think I drive like most MT drivers -- if I were going 80mph in 6th and needed to slow to a complete stop, I would push in the clutch and pull the handbrake as hard as I could.
Just kidding. I would definitely gear down, but how I geared down would depend mainly on how quickly I needed to stop. Also, I don't usually bother engaging 2nd gear as I'm stopping; 3rd is usually as low as I need to go.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
07-17-2006, 01:42 PM | #19 |
990
Rep 6,381
Neutral, my foot hardly reaches the pedal and it doesn't reach the floor so I have to "float" which is strenuous if I leave my foot on the clutch all of the time.
Nikki
07-17-2006, 01:43 PM | #20 |
1590
Rep 2,411
Drives: E30 M3 Cecotto, F85, G05, G07,
If you rev match properly, there should be no concern for premature clutch / engine / sychros / headlight / rear lip spoiler wear.
07-17-2006, 03:08 PM | #21 | |
442
Rep 4,838
07-17-2006, 03:42 PM | #22 | |
Law Enforcer
25117
Rep 22,290
Drives: '22 Chalk Gray Porsche C2S
Same here. |
