03-30-2009, 09:58 AM | #1 |
Rep 165
Dice Silverline is in...
Two birds with one stone....
I finally removed the ULF module to retrieve my Bluetooth code and followed it up with the Dice install. Overall....after digging the 3 and 6 pin connectors out from under the plastic glove box and running the Ipod cable under the same box took 30 minutes. The Ipod cable and connector head could have been a little bit smaller....but I am sure DICE has their reasons. Also, I wish the male 7 pin connector had a clip to hold it in place...it is pretty loose when inserted into the dice module and I recommend that you fasten it with a tie-down when trying to get it placed next to the ULF module while placing the carpet back in place. I had a funny moment after the install when the radio went dead and I couldn't start the car. I thought the Dice module had high-jacked my computer and was shutting the system down. Duh...just a weak battery! Whew.. I have ipod nano sound but I don't have artist/song on the radio display. I am sure I don't have it correctly configured. Is everyone using the default dip switch positions...both up on left and both down on right?
'06 Z4 ///M Roadster: Silver Gray Metallic; Gray soft top. Zeckhausen CDV. ESS VT1 445 Supercharger. APEX ARC8's. Dunlap Direzza Star Spec's. Strong Struts. Royal Purple. RPI Exhaust w/ DKF hangers.
04-18-2009, 09:38 PM | #2 |
Rep 165
Update: I had some scratching or interference in the unit while playing and idle. Returned module to Dice and waiting on a new unit. Also had some minor trouble with repeating songs. No regrets. I like having the controls on the stearing wheel. Dice service has been great so far.
04-19-2009, 07:44 AM | #3 | |
112
Rep 1,262
