6 MT limitations
07-13-2006, 02:09 PM | #1 |
20
Rep 345
6 MT limitations
i'm just learning how to drive stick. i've been driving some of my friends cars to practice and they said u shouldn't downshift into 1st gear while moving. obviously u shouldnt downshift to 1st when ur above 25 mph or so but what about when coming to stop? does BMW's mt have the same limitations. is there anyhing else i should know before driving my e92 off the lot in a few months?
07-13-2006, 02:18 PM | #3 |
990
Rep 6,381
BMW is the only car I've driven that actually even lets you put it into first gear when you're not at a complete stop. You should only use first to get going, and if you're coming to a stop you can put it into first as you slow down to about 15 mph but leave the clutch engaged.
Nikki
07-13-2006, 02:22 PM | #4 |
Rep 74
You may need 1st for some ultra slow corners if you're racing, but in everyday driving its only really needed for getting going, or perhaps in stop-and-go traffic.
I've never heard of a car that actually prevents you from going into 1st while moving, my VW GTI had no problem with it. -Tim |
07-13-2006, 02:24 PM | #5 | |
From Russia With Boost
36
Rep 1,076
But with a beemer, im sure you could go up pikes peak in 6th. |
07-13-2006, 02:26 PM | #6 | |
990
Rep 6,381
Nikki
07-13-2006, 02:26 PM | #7 |
517
Rep 18,858
I occasionally downshift to 1st. You have to be real good at rev matching though, and 1st is a tough one to get... I obviously only do so on some serious hairpin cornering... Even second gear is geared low enough to handle slower speeds...
Here is my general rule for my downshifts... take it for what its worth... 1st - 15mph or less 2nd - 40mph to 15 3rd - 60mph to 40 4th - 80mph to 60 with each of those, your at or about 4k rpm, and optimal for some get up and go... If your just downshifting while decelerating, then you can take each of those down 10mph or so... |
07-13-2006, 02:27 PM | #8 | |
517
Rep 18,858
I believe once your above 20mph, it is real hard to shift into first... not that ive tried to engage at that speed, but ive noticed it to be much more challenging ... |
07-13-2006, 02:31 PM | #9 | |
990
Rep 6,381
Nikki
07-13-2006, 02:33 PM | #11 | |
11
Rep 186
07-13-2006, 02:37 PM | #16 | |
517
Rep 18,858
Funny you say that... My ex from college used to drive a manual jetta... You certainly could get it back into first after moving... I found out the tough way... in hers, 1st and 3rd were VERY close to each other... I accidentally money shifted into 1st once after accelerating through 1 and 2 ... But who cares... we are not together anymore :rocks: |
07-13-2006, 02:39 PM | #17 |
990
Rep 6,381
Yeah, I don't want anyone to misunderstand, when I say put it in 1st gear but leave the clutch engaged, that's not downshifting. You need to make sure you're still on the clutch the whole time. I just don't feel like waiting to come to a complete stop before I shift into first, and also that way you won't forget and then go to start in like third or something.
Nikki
07-13-2006, 03:26 PM | #19 | |
24
Rep 453
Synchronizers bring the two meshing gears to the same speed as the gears are engaged. Down shifting into first gear at any significant speed forces the two meshing gears to reach the same speed very quickly (as soon as the shifter is placed into 1st and before the clutch is let out). This causes excessive wear on the synchronizers. An MT will typically have double or even triple synchronizers on first gear for this reason as 1st is the most susceptible gear to the problem. Downshifting into first should really only be done with a well executed double clutch shift or at very slow speeds as one is coming to a stop. Unless you feel like paying for a tranny rebuild at some point in the car's life. Last edited by goldminer; 07-13-2006 at 03:55 PM.. |
07-13-2006, 03:35 PM | #21 |
990
Rep 6,381
I don't do that anyways, I coast in neutral but I didn't realize going 10mph with the clutch in and putting the car in first was bad.
Nikki
07-13-2006, 04:57 PM | #22 | |
Smiling politely
165
Rep 7,931
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
