TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Zsp's on xi
      03-21-2009, 08:48 PM   #1
clickclickboom
78
Drives: Rust Bucket
Zsp's on xi
I put a zsp spring on the front of an xi. It did fit, but I ended up with zero drop. I was trying to get the look and rake of stock sport springs.
Visually the zsp were ~1/2" shorter than the xi's. I figured if a xi is .8" higher than a non-zsp and a zsp is .6" lower than a non-zsp, I would have ended up with about 1.4".
Fender-to-ground 25 7/8"
Fender-to-center 14 1/4"
I'm a little disappointed with the results. Looks like I'm going to order an Eibach kit. Anyone have on the want to sell?
      03-24-2009, 12:14 PM   #2
Omni
Omni's Avatar
Drives: E90 335xi 6MT
You may want to drive it around the block to get the shocks/struts to settle after the car was off the ground and remeasure.
      03-24-2009, 01:32 PM   #3
clickclickboom
78
Drives: Rust Bucket
Been driving it for three days....nothing. Eibachs are on their way.
      03-24-2009, 03:15 PM   #4
S_M
Drives: Many
I have determined springs are the same for both cars. OEM or aftermarket, even if you buy xi specific h&r's, they have a different part number on the box, but the part number on the springs is the same.
If you want to get rid of the rake there is a .5 inch solid metal spacer on the strut top hats in the front that you can remove, and this is why even though the zsp looked shorter, they didn't end up giving much of a drop...
      03-24-2009, 04:51 PM   #5
clickclickboom
78
Drives: Rust Bucket
Where is this spacer? When I disassembled it went as follows...
- rubber cushion
- spring hat
- small washer
- mount with bearing
- 1/8" thick ring
Was it still in the shock tower?
      03-24-2009, 05:20 PM   #6
S_M
Drives: Many
Mine was right on top of the strut hat, it should come down with the whole assembly. Its just a solid metal plate with 3 holes for the bolts that go through the strut tower...
Should be number 3 in the picture
      03-24-2009, 05:29 PM   #7
clickclickboom
78
Drives: Rust Bucket
I did not take notice that 1 and 3 were separate pieces. Does the i series just omit #3, or do they use something different?
      03-24-2009, 06:29 PM   #8
S_M
Drives: Many
Im not sure but i assume its just not there, which is why the xi's have the front rake that i's don't
      03-24-2009, 06:56 PM   #9
clickclickboom
78
Drives: Rust Bucket
Found this. E92 335i. No spacer.
http://www.realoem.com/bmw/showparts...67&hg=31&fg=10
I don't see what it would hurt to remove it.
      03-24-2009, 08:48 PM   #10
bolty
/r/trees
bolty's Avatar
50
Drives: 08 e92 335xi
So when you say they are the same... do you mean the xi springs are the same as non zsp springs?
Also, If I remember right, the non xi zsp have the "D" springs, but when I checked the front springs on my xi, they were the "T" springs.
And Iam assuming that if you remove the spacer (#3), the bolt pattern on #1 will match the holes on #6?? (You can see another set of bolts on the spacer itself)
      03-25-2009, 07:06 AM   #11
S_M
Drives: Many
The OEM springs may me slightly different, but aftermarket springs, at least h&r appear to be the exact same part.
      03-25-2009, 08:44 AM   #12
mstnggt66
18
Drives: MINI Clubman JCW (306hp)
Seriously. Why not remove the spacer and get exactly the drop you (and everyone else) is looking for without going down the road of aftermarket springs and shocks. Just my 2 cents...
I'm tempted to try this myself now.
2008 BMW 328xi coupe, 6MT
Ordered 7/16/07 | Production Started 8/27 | Production Complete 9/2 | On board COURAGE, departed 9/10 | Arrived SC 9/29 | Arrived CLE 10/6 | Picked up 10/8
1966 Ford Mustang GT, 425hp
2005 Nissan 350Z, StopTech brakes - SOLD | 2002 Acura RSX Type-S - SOLD
      03-25-2009, 01:42 PM   #13
BDMBimmer
18
Drives: 2008 3 series
Does the H&R springs take in account the spacer (part#3) or does it also drop with the front end being higher?
      03-25-2009, 02:26 PM   #14
bolty
/r/trees
bolty's Avatar
50
According to realoem all the e90's whether xi or not have the spacer. The e92's dont.
      03-25-2009, 02:37 PM   #15
BDMBimmer
18
It states "Items pictured but not listed are not installed on your vehicle." Part #3 is not in the list on either the xi or i, according to realoem.
      03-25-2009, 02:46 PM   #16
bolty
/r/trees
bolty's Avatar
50
Yeah, but if you go by that logic, it doesnt exist at all
I've tried diff combinations of years, models, engines but so far I cant find any reference to that #3.
Very confusing.
      03-25-2009, 03:00 PM   #17
BDMBimmer
18
I have been doing the same thing.
What makes the car bouncy, the springs? Than the OEM i and xi's should not be the same, since the i isn't bouncy at high speeds.
      04-02-2009, 11:54 AM   #18
eyeteaguy
Soldier
eyeteaguy's Avatar
Drives: F30 328xi
Interesting...I wonder if the springs are the same for the E90 (x or xi) as well? If so I'd like to get eibach springs as well because I've read that the ride is less harsh as the drop is less aggressive. Have you installed your springs yet? How is the ride quality??
      04-02-2009, 12:10 PM   #19
matts335
8
Drives: 335ixdrive
Does anybody know if this is actually a feasible option? Would it harm the suspension in any way? I'm guessing the part is there for a reason.
      04-02-2009, 08:11 PM   #20
clickclickboom
78
Drives: Rust Bucket
I have the eibach's. I only had time today to put on one spring. (Wife works 7p-7a). The car did not have the spacer #3. I was thinking about just removing it, made my decision to put the Eibach's on easy. I took a quick ride. Doing a comparison to the bumps I was hitting with the Eibach side vs. Oem sport spring side, I thought the Eibach was smoother.
I will post pics when I get the the other spring on and give it a day to settle. I will be running Eibach's up front with Oem sports on the rear.
On a side note my VMR713 came yesterday and I just put the on. As I said pics to come.
      04-02-2009, 08:36 PM   #21
J.P.
Close to bein Bannned
J.P.'s Avatar
Drives: Pussy Magnet
I have the eibach's sitting in my garage waiting to be installed. let me know how they ride.
Originally Posted by sexye92 View Post
JERRYS MOM= BEST HEAD OF MY LIFE
      04-02-2009, 08:38 PM   #22
deletedelete
deletedelete's Avatar
Drives: m
So does the xi have a separate spring then the sport/nonsport? Seems odd that the sport spring doesnt lower the xi any.
