M-Force Design Delivers Again ;^)
03-05-2009, 06:28 PM | #1 |
205
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
i recently ordered a set of M-Force Design Scoops after seeing a write up on the forum. see attached: http://www.e90post.com/forums/showthread.php?t=232099
i know there are several scoops out there for our BMW's, and most operate on the same principle. i choose these scoops for price, availability, and customer service. i had questions for Mach @ M-Force design. i wanted to know what the scoops were made of, and how they would adapt to an air induction system i may add at a later time. all questions were answered the same day. in less than a day, i knew they (the scoops) were made of aluminum, wound never rust, and since they attached to BMW's snorkel in front of the radiator. no matter which system i up graded to, they would still provided more air under the hood where it is needed most. the scoops were delivered that same week, and the install, took less than 5 minutes. with the use of a torques screw drive and small pliers. it was a win / win situation. if i used an upgraded air induction system that took air in thru the existing BMW snorkel, the air supply was increased. if i went with a system, such as a dual cone air filters under the hood, the cool air supply still needed under the hood would still be increased. so all 3 scenarios worked. 1. factory system, 2. upgraded system, utilizing BMW's air supply or 3. upgraded independent air supply system. once these M-Force Design Scoops are installed they can stay put, and continue to increase that cooler air to the engine. *** the bonus is, they are dealer friendly, and never need to be taken out for a service call to the dealer. can't go wrong here, M-Force Design delivers ! Thanks Mach. Last edited by Spydeputy; 03-06-2009 at 05:33 AM.. |
03-07-2009, 03:55 AM | #3 |
184
Rep 2,320
i am also waiting for my scoops from Mach@M-Force_Design, hope soon to write good feedback i am bone stock, hope scoops will help a bit for future performance
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
03-07-2009, 06:55 AM | #4 |
53
Rep 886
I received my scoops ~3 weeks ago. There were some problems with shipment (tracking info claimed that scoops hadn't been sent; scoops arrived in 3 weeks), but it was USPS's fault.
Mach replied all the PMs, was helpful.
Mods: RB turbos, JB4, BMS DCI, Scoops, Forge DVs, ar design catless DPs, Milltek exhaust system, Helix FMIC, Quaife LSD, VK MotorWerks OC Kit, Bilstein B16 PSS10
03-07-2009, 09:39 AM | #5 |
184
Rep 2,320
i also got this:
Status: Electronic Shipping Info Received The U.S. Postal Service was electronically notified by the shipper on March 3, 2009 to expect your package for mailing. This does not indicate receipt by the USPS or the actual mailing date. Delivery status information will be provided if / when available. Information, if available, is updated every evening. Please check again later. but as u said USPS has probs with tracking info, hope to get it after 3 weeks
04-21-2009, 03:07 AM | #6 | |
91
Rep 1,601
