BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      02-26-2009, 06:25 PM   #1
Blake
752
Drives: Chevy Aveo
inexpensive things i can do to keep temps down?
going out to a bmwcca track weekend in about a month's time, but taking my car into the shop to get some things installed next week...what are some inexpensive things, like fluid swaps, etc., i can do to try to keep the operating temperature a little better under control? last time i tracked it, temps got a little higher than i wanted them to be, and i know i can't fully remedy that, but just looking for things to improve it a little. thanks!
      02-26-2009, 06:28 PM   #2
Dascamel
Dascamel's Avatar
48
Drives: 2008 e92 M3, 2010 e91 328i
Brake fluid upgrade is an easy one.
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options
2007 Montego Blue 335i (retired)
      02-26-2009, 06:30 PM   #3
Blake
752
Drives: Chevy Aveo
already done that. running motul 600.
      02-26-2009, 07:30 PM   #4
lucid
lucid's Avatar
Drives: E30 M3; Expedition
get proper track pads. that won't keep temps down, but stock pads are not meant to be operated at high temps, so you'll be using pads that were designed to be operating at the higher temps.
      02-26-2009, 07:32 PM   #5
Blake
752
Drives: Chevy Aveo
i'm more or less talking about engine fluids, etc.
      02-26-2009, 07:45 PM   #6
lucid
lucid's Avatar
engine related things have enough cooling. there is nothing to modify.
      02-26-2009, 07:47 PM   #7
FStop7
I like cars
FStop7's Avatar
Vatican City State
329
Drives: M6
Reduce weight
      02-26-2009, 07:59 PM   #8
Blake
752
Drives: Chevy Aveo
Originally Posted by FStop7 View Post
Reduce weight
not until the warranty is up then i'll get the wrench out
      02-26-2009, 08:32 PM   #9
TUNEDM3
Stay Ripping
60
Drives: 1M
What kind of temps are you seeing?
      02-26-2009, 08:48 PM   #10
tszene
Drives: M4
Dont worry about your engine temps. I have aftermarket pulleys in and the temp gauge still didn't cross the 250 f line. i've seen M5's running 250-265 on the track with no problem.You'll be fine.
      02-26-2009, 08:49 PM   #11
Blake
752
Drives: Chevy Aveo
It would get as high as about 260.
      02-26-2009, 08:53 PM   #12
tszene
Drives: M4
its absolutely normal. after a session as soon as you get back to the paddock just pop the hood to give a little extra help to cool off, but like i said, you're fine.
      02-26-2009, 10:10 PM   #13
TUNEDM3
Stay Ripping
60
Drives: 1M
I have yet to have the opportunity to track my E90, but my E46 M3 used to see similar temps at the track. Its nothing to worry about.
      02-27-2009, 07:35 AM   #14
lucid
lucid's Avatar
Several forum members, including myself, have reported temps in the 255-260F range on the track--even on hot July days. As others have said that is completely normal. But, I'd watch out for those "scoops". They do block a part of your radiator.
      02-27-2009, 08:39 AM   #15
Gearhead999s
Gearhead999s's Avatar
814
Drives: RR Velar R=Dynamic M2C R1200GS
The engine temps that you are experiencing is the same range as I am getting which is nothing to concern yourself with.My Z06 used to see over 300f in long track sessions.The transmission has its own cooling system with a dedicated electric pump & cooler,so that is a non issue.I have problems with my diff getting too hot & clunking on a track where it was a lot of second & third gear stuff with a fair bit of wheelspin on corner exit so that is something that I will have to keep an eye on.
The only other thing is brakes and that can be rectified with proper track pads & fluid. Go & Enjoy!
      02-27-2009, 12:16 PM   #16
Blake
752
Drives: Chevy Aveo
sounds good then, i'll keep rippin it up
      03-16-2009, 07:45 PM   #17
jml
jml's Avatar
128
Drives: X5M, GT3RS, GT4
I wish there was a water temp gauge. I was seeing ~260-280 degrees at TWS in 50 degree weather, which is about the same as the E46. Seems a little high, I hope that this reflective of a closed loop decision to maintain this temp rather than a capacity issue like it was on the E46. 110 degree summer track days may not be possible in the E90 otherwise.
      03-16-2009, 11:44 PM   #18
rob612
rob612's Avatar
Drives: e92 - m3
drive slow hehe
m3post
