BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      02-25-2009, 12:43 PM   #1
jlapicki
jlapicki's Avatar
Drives: 2020 M340i
Brake Ducts
Does anyone have specific knowledge about whether they exist on the e90M3.........I had to open up the fender lining, install ducts and open up the grille on my e39M5 for track use...........thanks, Joe
2022 M440i Convertible - San Remo Green / Cognac
2021 Mazda 6 Signature - Machine Grey / Parchment
2020 M340i - Mineral White / Black - SOLD
2017 M2 - Alpine White / Black - SOLD
2001 e39 M5 - Titanium / Caramel - A "Keeper"
      02-25-2009, 01:07 PM   #2
lucid
lucid's Avatar
Drives: E30 M3; Expedition
No, there is no ducting for brake cooling on the E9X M3, and that's a product opportunity...
      02-25-2009, 02:53 PM   #3
jlapicki
jlapicki's Avatar
Drives: 2020 M340i
Thanks........no one seems to be mentioning cooling as an issue......I guess that track pads and fluid is all that is needed to prevent fade. Of course the M5 is much heavier and really worked the fronts......Joe
      02-25-2009, 03:12 PM   #4
lucid
lucid's Avatar
I don't think the stock E9X M3 brake system has been pushed that hard on the track by most enhusiats who post on these forums, so I'd say it's too early to say if there is a fade issue or not (with proper pads), and if brake cooling can help. We'll probably know a lot more by the end of the summer. Call up Turner or Bimmerworld and ask. I know Turner has a project car--I have seen it at the track and it had stock brakes at the time--and James Clay has been posting about his PF upgrade on the brake section of the forum.
      02-25-2009, 04:05 PM   #5
Dascamel
Dascamel's Avatar
48
Drives: 2008 e92 M3, 2010 e91 328i
Turner car was at Buttonwillow running the stock brake system last spring. Before I even knew who he was, asked him about the brakes. He said fade wasn't much of an issue. This was on a 100+ day.
Most others seems to be focusing on pads and fluid first.
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options
2007 Montego Blue 335i (retired)
      02-26-2009, 11:46 AM   #6
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
i am making my own kit ... should be ready pretty soon ...
      02-28-2009, 06:47 AM   #7
m_parade
7
Drives: 08 Jet Black M3 Coupe
I have been thinking of doing the similar thing too. Let us know how it goes!
      02-28-2009, 04:55 PM   #8
ScheerSpeed
ScheerSpeed's Avatar
Drives: '13 F30 Estoril M-Sport 335i
i just got home from tracking my E90 M3 at Homestead Speedway, and let me tell you, these brakes need some proper cooling!!! the fade was sooo bad after about every 5 laps i would have to do a slow cool down lap to let the brakes cool! even after the last session of the day after my cool down lap, when i parked in the pit, my brakes were smoking!
      02-28-2009, 09:28 PM   #9
lucid
lucid's Avatar
What run group were you in? What pads were you using?
      03-01-2009, 01:14 PM   #10
ScheerSpeed
B group, using OEM pads. would track pads make a big difference?
      03-01-2009, 01:22 PM   #11
lucid
lucid's Avatar
Yep. If you did experience fade, track pads would make a significant difference to the extent that your problem would most likey be resolved. That won't bring the temps down, but it will take care of the fade issue as track pads are rated to operate at much higher temps.
      03-01-2009, 01:33 PM   #12
ScheerSpeed
i will give that a try then before i spend $ on a BBK. how about fluid? should i put a higher temp fluid as well?
any recommendations on pads?
      03-01-2009, 02:58 PM   #13
lucid
lucid's Avatar
Yes, the BBK issue has been discussed in some detail. You should be really be fine with track pads in terms of fade; the stock rotors are fairly large and should be fine for people doing HPDEs in relatively stock cars. However, some claim BBK will result in better pedal feel at the track. I haven't heard anyone who knows what he's doing confirm that yet after a BBK upgrade. Changing the fluid would be a good idea. Mine boiled and spray out a little through the relief valve in the cap.
      03-01-2009, 07:35 PM   #14
doba_s
doba_s's Avatar
lucid which fluid you would recommend ?
how often the fluid needs to be changed ?
      03-01-2009, 09:03 PM   #15
Dascamel
Dascamel's Avatar
48
I'm not Lucid, but a popular one is Motul RBF 600. It has a higher boiling point, looks close to stock and runs approximately $15 a bottle.
      03-01-2009, 09:40 PM   #16
lucid
lucid's Avatar
I heard good things about Motil 600, but have not used it. I currently have ATE type 200 in the car. I had super blue in there earlier. I change it twice a year.
http://www.turnermotorsport.com/html...kes#BrakeFluid
      03-01-2009, 10:46 PM   #17
doba_s
doba_s's Avatar
what is so special about Castrol SRF ? why does it cost so much ?
      03-02-2009, 08:13 AM   #18
lucid
lucid's Avatar
I have no idea, but it's safe to say we don't need it.
      03-02-2009, 09:44 AM   #19
ScheerSpeed
wow, i didnt think brake pads would be so expensive....
      03-02-2009, 11:21 AM   #20
Gearhead999s
Gearhead999s's Avatar
812
Drives: RR Velar R=Dynamic M2C R1200GS
If you were running with the MDM on,you will have a lot higher brake temps than with all traction aids turned off.
      03-02-2009, 09:16 PM   #21
doba_s
doba_s's Avatar
elaborate please
      03-02-2009, 09:27 PM   #22
Gearhead999s
812
elaborate please
With the DSC or MDM activated by the car sliding (understeer or Oversteer)the individual wheel brakes can be applied to control the slide.When the electronic nannies are turned off the brakes are only used for slowing the car,not trying to control the yaw angle which means that the brakes have more cooling time between applications and that means they will run cooler.
Search this Thread:
Advanced Search
m3post
