BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      02-19-2009, 10:24 PM   #1
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
Arrow Light weight Braille battery swap DIY
Harold at HP Autowerks supplied me with this great, small, light weight battery, so I and decided to give it a shot today ...
DO IT AT YOUR OWN RISK. I AM NOT RESPONSIBLE FOR ANYTHING THAT MIGHT HAPPEN TO YOU OR YOUR VEHICLE.
You can get your Braille Battery here:
http://www.m3post.com/forums/showthread.php?t=233196
You need these tools:
10 mm socket
13 mm socket
Torque wrench + extensions
Magnet pen
Small flat head screwdriver
Rubber gloves
1. Your battery will be in the trunk on the RT side
2. Uninstall the black bracket on top of the battery first ( 2x10mm bolts)
one here
and one here
3. Disconnect the Negative (-) terminal first (10mm socket )
make sure to put the Negative (-) terminal away from the battery so it will not be touching anything.
4. Then you can disconnect the top box with the fuses (optional, but it makes it much easier to remove the battery) - 13mm socket
Press on the two metal tabs on the sides and pull it out ... You need to play with it a little ...
5. Now you can disconnect the MAIN Positive (+) terminal - 10mm socket
Now move the Positive (+) to the side and secure it there by using a zip tie
6. There is a little rubber tube on the LT side of the battery that have something to do with the acid going into/out of the battery. Use rubber gloves to disconnect it. Just pull it to the side and it should pop out right away. Don't worry, nothing is going to leak out from that tube. It is just a precaution to use a rubber gloves.
7. Now you need to look at the RT side on the battery and you will find metal bracket kind of deep inside. Use 10mm socket to remove it. Use a magnet pen to pull it out
8. Now you is the hardest part. Use two little handles on the battery and put it out. It is pretty heavy, so you might want to ask somebody to help you with that.
9. Now you can clean that empty area and put the New Braille battery.
10. Adjust it so it won't move and use that metal bracket to tight it down. You will have to move that metal bracket to the LT.
11. Install the MAIN Positive (+) first, then Negative (-), then the box with the fuses on top of the battery and screw it back to where it was before
Install the factory black bracket back if you want. It is optional but I decided to put it back.
Start you car and make sure everything works !
You are done !
Stock - 58lb
Braille -21lb
Weight savings - 37lb
A few pics Stock vs Braille
I hope it helps
      02-20-2009, 01:10 AM   #2
Cab5er
Cab5er's Avatar
China
79
Drives: 09 E90 M3 (Sold) 13 A1
Tks for the write up This will come handy in the future.
E90 ///M3/ AW/ Fox Red
      02-20-2009, 01:35 AM   #3
808MGuy
808MGuy's Avatar
218
Drives: 2009 E90 M3
You dropped about almost 2/3 of the weight but also 2/3 of the electrical capacity (from 90A/h to 31A/h). Careful when loading up on electrical accessories.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
      02-20-2009, 07:22 AM   #4
Technic
Technic's Avatar
2258
Drives: 2021 i3S, 2024 i4 M50
Yeap...
      02-20-2009, 07:42 AM   #5
lucid
lucid's Avatar
Drives: E30 M3; Expedition
Thanks for the writeup. Please keep us posted as to how the new battery holds up.
      03-22-2009, 03:08 PM   #6
MMAJNKE
MMA Changed My Life!
MMAJNKE's Avatar
Japan
316
Drives: e92 m3 & f30 328i
awesome
      04-03-2009, 02:09 AM   #7
swamp2
swamp2's Avatar
Drives: E92 M3
Finally went for this mod. Good DIY it helped me. A couple of additional comments:
  1. The fuse holder is a bit tough to remove. Just keep pressing on the steel tabs and then you can slide and rock the assembly off one side at a time.
  2. The base of the HP aluminum frame is not the right thickness to fit perfectly. Even when fully tightened the assembly could rattle a bit. I fixed this by using a thin ~1/16" strip of aluminum double sided taped to the floor of the batter compartment about 1/2" away from the tang that secures the front end of the assembly. You will see this tang after removing the battery. I initially tried to simply bend the tangs a bit but then decided a simple spacer was better.
  3. The battery is a bit too tall. The rubber coated bracket that runs over the top of the battery barely fits but it will without breaking anything. In fact it helps secure the fuse assembly since that no longer can mount to the side of the new battery.
P.S. doba_s: In your last picture, install complete, it appears that your negative terminal binder is on only about 1/2 way!
      04-03-2009, 08:20 AM   #8
lucid
lucid's Avatar
Interesting. I am about to go out the door to pick up the Braille battery that I ordered last week, so I am going for it as well. Thanks for the additional comments.
Which holder did you get? The Braille or the HPAutowerks one?
      04-03-2009, 10:04 AM   #9
doba_s
doba_s's Avatar
Originally Posted by lucid View Post
Interesting. I am about to get out the door to pick up the Braille battery that I ordered last week, so I am going for it as well. Thanks for the additional comments.
HPA holder works ok ... I have no problems with it ...
Harold sent me the battery with two positive terminals and that is why my negative in the picture is 1/2 down ... (+) and (-) are different in size. Later on he sent me the correct one and everything fits perfect !
      04-03-2009, 11:14 AM   #10
swamp2
swamp2's Avatar
Drives: E92 M3
Cool. You'll like it. Nice mod IMO. I got the HP holder, simple, stout and anodized/machined aluminum. It could be lighter out of a fiber reinfornced plastic or delrin or something like that but it is a very nice part.
      04-03-2009, 04:26 PM   #11
lucid
lucid's Avatar
OK guys. I'll go with the HPA holder as well then.
      04-03-2009, 05:14 PM   #12
HP Autosport
Supreme Allied Commander
Drives: F80 M3
      04-03-2009, 10:04 PM   #13
doba_s
doba_s's Avatar
it would cost probably twice as much ...
      04-03-2009, 10:09 PM   #14
swamp2
swamp2's Avatar
Drives: E92 M3
In general plastic <$ than metal (and lighter too).
      04-03-2009, 11:26 PM   #15
mvagusta
16
Drives: 2008 m3 coup
Isn't the reason Bmw made the battery heavy for the handling to get to a 50/50 weight?
      04-04-2009, 02:20 AM   #16
swamp2
swamp2's Avatar
Drives: E92 M3
No. They made it heavy so you can park, stop, listen to the radio with the lights on for 30 minutes when it is -10 °F and then crank her right up. These batteries won't do that. However, the reason it is in the rear left of the car is for F/R weight balance. If BMW could find a battery that did the former with the wieght of the Braille it would be much cheaper and would be OEM.
      04-06-2009, 02:58 AM   #17
HP Autosport
Drives: F80 M3
except the tooling and mold to make a plastic tray will cost a lot of money.
      04-06-2009, 01:00 PM   #18
swamp2
swamp2's Avatar
Drives: E92 M3
Yes, absolutely for a molded part. Machined plastic could be an option as well. That being said I certainly like your design. Stout simple and attractive.
      04-16-2009, 08:22 PM   #19
GTM
GTM's Avatar
Drives: E92 M3
Please think carefully about changing out to smaller capacity battery on E9x M3
because...
S65 engine DISCONNECTS alternator while full throttle...
Which means the engine only runs on battery power on full throttle.
I am sure alternator will kick in when it is under the required power to run the motor...but then what's the point of having lighter batt?
I honestly do NOT know how long will this Braille battery will stand, but I would be very careful switching into smaller capacity than stock just because of above reason.
      04-17-2009, 11:13 PM   #20
GMWNashville
Drives: 19 G05, 16 F80, 10 E70x5D
let alone how sensitive these cars are to battery voltage...
      04-17-2009, 11:20 PM   #21
mvagusta
16
ah!!! ^^^^Everyone Quiet now..GTM might be right. Thanks GTM..lol.
      04-18-2009, 01:59 AM   #22
swamp2
swamp2's Avatar
Drives: E92 M3
because...
Unfortunately, we did not get the Brake Energy Regeneration thing (bad name by BMW - but it is the system you describe above...). The EU and other regions did get this feature. As well, I bet the system has a feature that overrides the disconnect if the battery level is too low.
Search this Thread:
Advanced Search
m3post
