02-18-2009, 07:30 PM | #1 |
405
Rep 6,107
MOVIT Brakes - What do you know about this brand ?
I was looking at MOV*IT brakes and it looks like they make good solid brake systems. I don't know too much about this company and want to see if you guys have had any experience with this company. The have brake kits for e9x M3s in a few different sizes.
Front: Steel Rotors 370mm with 6 piston caliper 342mm with 6 piston caliper Rear: Steel Rotors 342mm with 4 piston caliper They are offering CERAMIC kits as well and rotors can be made in any size. http://movitbrakesusa.com/ |
02-18-2009, 09:09 PM | #2 |
20
Rep 293
I was thinking about the CC breaks that they make but I ran into the same problem you did no one has delt with them.
They are a small German based company with QC thats out of this world(so they say) all 16 employees are engineers. I talked to them on a few occasions and they seemed to know what they were talking about but I wasn't going to drop 12k on something no one knew anything about. After research the same people that make there CC rotors make Stop Techs and Koenigsegg or how ever the hell you spell that cars name. |
02-18-2009, 09:15 PM | #3 |
Critical Care Anesthesiologist
481
Rep 8,828
Drives: SMB F83
They also make the Brabus 12 pot BBK
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist" |
02-18-2009, 09:47 PM | #5 | ||
405
Rep 6,107
here is what i got from Tom Frederico@MOVIT Quote:
02-18-2009, 10:18 PM | #7 |
481
Rep 8,828
Drives: SMB F83
Yes sir. MOVIT makes kits for Brabus
02-19-2009, 02:34 AM | #10 |
135
Rep 1,825
WOW! Thats expensive but sick.... the corvette zr1 has CC's same brakes as the enzo....
The original Hid angel eyes for sale now on ebay
User name lmims526894rou Or contact me at chrism9551@aol.com |
02-19-2009, 12:48 PM | #11 |
405
Rep 6,107
02-20-2009, 01:51 PM | #12 | ||
13
Rep 101
The Brembo kit is 380x34mm which is a generous increase in maximum heat capacity, as well as a dramatic improvement in heat management. The Brembo system consistently runs cooler under both street and heavy track use, and will undoubtedly last longer than ANY other option out there. Quote:
This may sound like marketing, until you talk to anyone who has owned a Brembo system in the past. The only people who seem to disagree are the ones selling their own product. |
02-20-2009, 03:06 PM | #14 |
100
Rep 1,035
Isn't the rear rotor 380x28?
02-20-2009, 03:28 PM | #15 |
13
Rep 101
Yes, the rear is a lightweight 380x28mm disc.
That disc is specifically developed for rear applications which require less heat capacity. Again, the 380x28mm is a huge improvement in heat capacity and heat management for the REAR brake kit. The heat capacity is dictated by the mass of the disc. The temperature management comes from it's ability to absorb the heat created during aggressive driving, and it's ability to efficiently dissipate that heat while keeping the operating temperatures at a reasonable level for the brake pads, calipers and fluid. Other aspects that add to this efficiency of the Brembo discs are the vein design which directs the flow of air through the disc, and more importantly, the superior metallurgy which is directly related the discs ability to process extreme heat cycles without DTV, rapid wear rates, and premature cracking. It's all in the quality! |
02-25-2009, 07:30 AM | #17 |
374
Rep 8,033
The question is does anyone on this forum actually need the additional heat capacity? Surely not on the street, and even on the track, it would probably take a brutal track and an excellent driver to necessatitate it.
Has anyone actualy monitored rotor stock temperatures on the track on this forum? If this is not an issue for your dedicated enthusiast here, then I don't see the point of having additional heat capacity and the additional mass that goes along with it. I will try to monitor my rotor temps this year at the track. I didn't last year.
02-26-2009, 12:14 AM | #18 | |
405
Rep 6,107
02-26-2009, 06:09 AM | #19 |
481
Rep 8,828
Drives: SMB F83
According to RealOEM, the front rotors are 360X30, and the rears are 350X24
Front: http://www.realoem.com/bmw/showparts...23&hg=34&fg=05 Rear: http://www.realoem.com/bmw/showparts...72&hg=34&fg=10
02-26-2009, 11:07 AM | #20 | |
405
Rep 6,107
