      02-16-2009, 02:33 PM   #1
mynew135
assistant to the regional manager
mynew135's Avatar
Drives: 135i
2009 135i  [0.00]
Adding Chrome Emergency Brake Handle
You can read Andy's DIY on how to remove the emergency brake boot.
It's fairly simple, just be careful not to break any of the plastic tabs.
Once you have the boot pulled back, get a pair of wire cutters and cut the plastic zip tie that holds the handle on.
Once the zip tie is off, you can completely remove the boot. The stock handle is on pretty tight, so I used a screwdriver and hammer to lightly tap the handle off.
Once you slide the Chrome covered handle on, replace the leather boot and put a new zip tie on and pull tight.
Pop the boot back into place and enjoy your new handle.
      02-16-2009, 06:51 PM   #2
BSM 135i
BSM 135i's Avatar
206
Drives: 08' BSM E82
looks good...flows more with your trim and pedals.
      02-19-2009, 11:41 PM   #3
FOXYCaymanS
_
FOXYCaymanS's Avatar
Drives: Cayman S / Rover
Looks good, doesn't this "toy" with your warranty?
      02-22-2009, 01:36 PM   #4
mynew135
mynew135's Avatar
Drives: 135i
2009 135i  [0.00]
I don't get what you are asking. I guess if my emergency brake goes out and they can prove that changing the handle caused it to go out, then I would be out of luck. Guess I'll take that chance.
      02-27-2009, 11:48 PM   #5
montreal red
chris
montreal red's Avatar
278
Drives: White Boat
this is one of the most minor mods you can do... i am pretty sure this does not void your warranty in anyway... heck if this voids it then switching out trim pieces, shit knobs, aluminium pedals should all void your warranty as well.
btw, good DIY op!
Current: 2013 F10 M5 & 2016 Mini JCW
2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone)
      02-28-2009, 09:00 AM   #6
shawshank772
shawshank772's Avatar
Drives: 08 135i and 16 M3
stupid question because I cant remember. Is the handle the same as the 3 series?
      02-28-2009, 11:52 AM   #7
mynew135
mynew135's Avatar
Drives: 135i
2009 135i  [0.00]
I switched out my e46 handle years ago and if I recall, it was not the same.
