02-14-2009, 01:17 PM | #1 |
silver bullet
20
Rep 148
service engine soon whats this
what goes in here? when you open it can you see the fluid. the reason i ask is because my service engine soon light came on and i checked all other caps and they all look good but not sure on this one. thank you
02-14-2009, 01:42 PM | #2 |
218
Rep 4,726
Muffler bearing fluid goes there. Autozone has some but it's behind the counter so you have to ask for it. Anything DOT approved works.
02-14-2009, 01:47 PM | #3 |
silver bullet
20
Rep 148
thanks, can you see the fluid in there when you open the cap?
02-14-2009, 01:57 PM | #4 |
218
Rep 4,726
Muffler bearing fluid is pretty clear, it's hard to see. That's why there should be a little thing floating in there to indicate the level. If the little stick like thing is floating about flush with the top of where the cap screws on your good, if it's not then you need to refill it immediately.
Regular distilled water will work temporarily like from CVS (NOT TAP WATER), but if it was low you need to go to autozone some time soon and get the fluid. Can you take a pic with the cap off?
02-14-2009, 02:03 PM | #6 | |
218
Rep 4,726
Again taking the car to Autozone and they can scan the code for you through the OBDII port and tell you what it is for.
02-14-2009, 02:05 PM | #7 |
silver bullet
20
Rep 148
i hope thats what it is. i checked it and it doesnt seem like any is in there at all...... once i put it do you think the service light will turn off ? thanks again
02-14-2009, 02:10 PM | #8 |
218
Rep 4,726
Holy shit, that is bone dry man, that might actually be the cause of your SES light, I would fill it up with distilled (again NOT tap water or any type of mineral water) if you have any on hand in your house before even going to get any fluid.
BMW actually recommends only using their fluid but distilled or generic fluid from autozone works to correct just a little low level. But since you have to add so much I might go ahead and use the BMW fluid.
02-14-2009, 02:13 PM | #11 |
218
Rep 4,726
See above post, BMW recommends their fluid. You might just go to the dealer and get a jug of it, mix it 50/50 with distilled.
02-14-2009, 02:26 PM | #15 |
218
Rep 4,726
It needs to be a 50/50 mix.
02-14-2009, 06:39 PM | #16 |
218
Rep 4,726
I figured someone would tell you by now.... That's for your coolant, and you're low, empty really, which is really bad. The muffler bearing thing was a joke, but everything else I told you was true, just replace "muffler bearing fluid" with "coolant".
02-15-2009, 10:03 PM | #19 | |
218
Rep 4,726
So long as you never overheated it's OK, but it's not a condition you ever want to drive around with.
