H&R Sport Pictures
02-05-2009, 02:15 PM | #1 |
67
Rep 549
H&R Sport Pictures
I took a couple pictures after letting the car settle for a few days. These are the non-xi H&R sports, which we now know work on xi's and will give you a drop similar to the non xi cars. The ride is better than expected honestly, Ive had cars with springs before and I was afraid it would be bad. I don't think I've even bottomed the struts yet, and the roads around here are horrible. Im really happy that I decided to do this, the car looks much lower in person compared to a stock xi and the ride didn't suffer much at all...
Sorry the car is so dirty, but the roads are still a mess and its way too cold to clean it yet |
02-05-2009, 02:19 PM | #2 |
663
Rep 26,878
Drives: 2-325 330 2-335 2-Z4 2-135 X5d
Looking good man!
02-05-2009, 02:55 PM | #4 |
167
Rep 1,734
02-05-2009, 03:28 PM | #5 |
313
Rep 8,050
Drives: E92 M3
looks great!
08 E92 M3/Melbourne Red/6MT/Exec Pack/MDrive/EDC/PDC/19" 220M
Mods: VRS Front Lip, HID Angels, KW V3, Stoptech BBK, SS lines, 18" TE37SL, Bastuck Exhaust, MS Air Filter, OEM Aluminum Padels, LED Interior Light 07 E92 328i/Jet Black/Cream Beige Leather/Premium/Step/Heated Seats...check garage! |
02-05-2009, 03:36 PM | #6 | |
67
Rep 549
I couldnt really tell you, I just use this car to commute so I never really push it. It seems like it corners much flatter and the average person would say the handling is improved, but in reality it's probably worse as with any other aftermarket springs by themselves because of the change in roll center, camber curve, suspension travel, etc... |
02-05-2009, 03:58 PM | #8 |
152
Rep 2,461
actually in your pics the car looks evenly dropped. I normally prefer a stance where the rear is slightly higher in the rear (very slightly). But BMWs for some reason always seem to sit lower in the rear, even when you lower on springs, unless your dropped on coilovers.
Your drop looks just like mine (on XI springs). I run HR sports for the XI except during install, I removed the .5'' thick steel plate which attached to the bottom of the strut top hat. Removing that plate lets the front sit lower thereby also eliminating the 'rake' loook |
02-05-2009, 08:48 PM | #11 | |
Rep 50
tell me more about the thick steel plate??? is it dangerous to take out..!! is it stiffer..? do you have pics of your car without the plate..? Thanks sorry for all those questions..! cheers |
02-08-2009, 12:12 AM | #12 | |
109
Rep 1,801
02-08-2009, 04:43 PM | #14 |
167
Rep 1,734
02-09-2009, 01:07 PM | #15 |
Chief Executive
300
Rep 2,886
Drives: 2008 335xi 6spd Coupe
Looks very nice! Keep us posted on the ride quality.
02-11-2009, 04:15 PM | #16 |
109
Rep 1,801
This is what a fellow forum member (digitalinkartist) PM'd me earlier today as I was interested in buying his H&R non-xi sport springs...
"Springs were sold a while back. Just so you know, You cannot install regular (rwd) e90/92 springs on an awd xi. the strut height is longer with the xi's. you will end up damaging the undercarriage or suspension if you install them. GL with your search, Chris" |
02-12-2009, 04:00 PM | #17 | |
152
Rep 2,461
The only reason I think they are taller however, is because they sit lower on the hub. The XI struts sit higher up because there is a front CV joint/boot obviously since the cars AWD. However, the 335i struts drop down farther and wont fit the XI because they will hit the CF joint/boot blocking the bolt holes from matching/bolting up!! So side by side the I is taller, however its POSSIBLE once installed the XI sits higher |
02-12-2009, 04:52 PM | #19 |
29
Rep 556
Does anyone else think that H&R sports and eibachs looks very similar in drop??
people say that the H&R has a lower front the eibach but it looks the same on pictures I see. BTW those CSL reps looks great on AW, what kind of wheel is it? |
02-12-2009, 05:15 PM | #20 |
G.O.A.T.!
1000
Rep 74,998
Exclusive was offering for awhile thru us but no longer.... we can get the Miro or VMR though now if you like!!!
02-12-2009, 09:14 PM | #21 | |
El Presidente
278
Rep 6,962
