02-01-2009, 04:59 AM | #1 |
Moderator
673
Rep 4,737
Why is the Japanese M3 Lower than the US M3?
Update:
Did a search on realoem.com and here are the findings: 1) US and Euro shocks/struts w/ EDC are the same 2) Japan shocks/struts are different compared to US and Euro 3) Springs' part numbers are not available 4) Based on my rough "eyeballing", all other suspension components are the same Conclusion: 1) BMW altered the strut/shock rate for the Japanese springs, hence this may show that when you change springs, it is best to alter the shocks accordingly as well to maintain the performance Questions: 1) How exactly are Japanese shocks/struts different? 2) How exactly are Japanses springs different? Are they stiffer and shorter like most aftermarket springs? ---------------------------------------------------- As illustrated below, the Japanese M3 sits about 0.4" (10mm) lower than US versions. Wonder if we can simply order the Japanese market spring and lower our car? Can someone do a comparison between part numbers? Last edited by rzm3; 02-02-2009 at 01:19 AM.. |
02-01-2009, 08:42 AM | #3 |
8
Rep 426
Drives: '09 E90 M-DCT M3
If this is true, it would make me a lot more comfortable with new springs not voiding the EDC warranty. Good find.
AiB LEDs///MS Filter///Hardwired V1///VentureShield///F1 Pinnacle 35%///IND Reflectors///BMW Performance Grills
02-01-2009, 08:56 AM | #4 |
Moderator / European Editor
1502
Rep 6,755
Japanese M3 has different spring struts, so the shocks might be identical.
Best regards, south
02-01-2009, 11:32 AM | #5 |
98
Rep 1,043
the roads in Japan are some of the nicest in the world... you can cruiz there with race suspensions like sooper slammed. and be just fine...
so BMW took that into consideration... thats pretty cool... |
02-01-2009, 11:53 AM | #6 |
Critical Care Anesthesiologist
481
Rep 8,828
Drives: SMB F83
+1, even in Hokkaido where it snows pretty heavily in the winter, the road surface is as smooth as a baby's bum. Compared to what we have in Massachusetts, our roads are like gravel road to them, only suitable for 1-2hp buggies.......
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist" |
02-01-2009, 12:08 PM | #7 | |
40
Rep 788
from what i saw, some road in Hokkaido have the hot spring nozzle built in. It uses natural resource to melt away snow. |
02-01-2009, 01:23 PM | #8 |
432
Rep 4,567
Soaristo has an M3 in Japan, and just by eyeballing some of the pics on his homepage, his M3 does look a little lower than US spec ones:
http://www.soaristo.jpn.org/ Is it just me? If not, someone should send him a PM and introduce him to this thread. Update: I sent Soaristo a PM with a link to this thread...
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem Last edited by aajami; 02-01-2009 at 01:29 PM.. Reason: Typo |
02-01-2009, 02:37 PM | #10 |
2281
Rep 12,997
Could it be just easier to order, cheaper or even better to get the Dinan springs with almost the same drop (12.5 vs. 10mm)?
02-01-2009, 03:19 PM | #11 |
Moderator
673
Rep 4,737
If springs were the only difference, then I think it would be a cheaper/easier/safer solution than Dinan. Now we just need to verify if this is true.
02-01-2009, 04:23 PM | #12 | |
2281
Rep 12,997
That's a lot of ifs... These Japanese springs remind me of the Euro springs for the MKV GTI which were lower than the USA's for 2 model years by about the same 10mm. |
02-01-2009, 09:12 PM | #14 |
50
Rep 783
I'd say the European Spec M3 is lower than US Spec, not just for the Japan market. Here in New Zealand the car is just as low as shown in that picture of a Japanese spec M3.
02-01-2009, 09:50 PM | #15 | |
236
Rep 3,303
Cheers, e46e92
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan. |
02-01-2009, 10:06 PM | #16 |
Moderator
673
Rep 4,737
02-01-2009, 10:15 PM | #17 |
521
Rep 5,483
wow...some of you guys amaze me...do you know how much it would probably cost to buy 4 springs from BMW, Japan or anywhere in Europe?
If you want lower....why not get aftermarket springs? What are you so scared of? Warranty? I just don't get it, if your that scared to put "aftermarket" springs, then leave it as it came from factory! I mean...to spend tons of money to be 10mm lower? Really?
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather 2020 Range Rover HSE - Black/Black 2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black |
02-02-2009, 12:27 AM | #18 | |
Moderator
673
Rep 4,737
2. The suspension components are engineered to work with each other. By changing the length and stiffness of the springs, we don't know if the aftermarket springs would still work in harmony with the other OE components. From the amount of information that is given by most aftermarket spring companies, they don't provide us enough details regarding how, for example, the life of the shocks would change, or how the front/rear balance of the car changes (most springs drop more in the front), or if the front/rear effective spring stiffnesses are proportioned correctly to not cause any understeer (Orb has a lot to say about this), or how riding on the bumpstops changes the force/displacement curve (as preached by Lucid)... But we DO know that BMW did their homework on this. Hence, by switching to the Japanese springs (assuming that springs are the only difference between US and Japan M3's suspension), we would be able to maintain the proper performance/balance of the suspension and achieve a lower stance that looks better. So, why not? Warranty may be one of the concerns because we care about the longevity of our beloved M3, but more importantly, many of us who mod our cars care more about maintaining (or even improving) the performance of the car. That's why we would like to make sure that the modified components will not only work, but work properly on the M3. |
02-02-2009, 01:14 AM | #19 |
Moderator
673
Rep 4,737
Update:
Did a search on realoem.com and here are the findings: 1) US and Euro shocks/struts w/ EDC are the same 2) Japan shocks/struts are different compared to US and Euro 3) Springs' part numbers are not available 4) Based on my rough "eyeballing", all other suspension components are the same Conclusion: 1) BMW altered the strut/shock rate for the Japanese springs, hence this may show that when you change springs, it is best to alter the shocks accordingly as well to maintain the performance Questions: 1) How exactly are Japanese shocks/struts different? 2) How exactly are Japanses springs different? Are they stiffer and shorter like most aftermarket springs? |
02-02-2009, 07:55 AM | #20 |
///M Fan
366
Rep 2,159
Drives: '09 E92 M3 IB/'17 f85 X5M LBB
If the struts and shocks are different, I'm willing to bet the bump stops are different too.... Can anybody provide p/n for the Japan bump stops? They might be shorter....
'09 E92 ///M3 Interlagos Blue,6MT,Silver Novillo Leather,CF Trim,Premium Package,Technology Package,Cold Weather Package,Premium Sound,19"Wheels,Moonroof-Toy/'17 X5M, Long Beach Blue, Executive Package,Technology Package, Lighting Package, Driver Assist, Full Mughello Red Interior, 21" wheels-Toy/'14 535i with M Sport and 19" wheels-Daily
02-02-2009, 08:54 AM | #21 |
374
Rep 8,033
Wow, lots of good info here. Thanks rldzhao.
It might be worth making a call to a dealerships that has some motorsport friendly techs (there are such dealerships). They might be able to say if such a "suspension" swap would be logistically feasible, and cost effective.
02-02-2009, 11:21 AM | #22 |
Moderator
673
Rep 4,737
I checked last night and they were the same. The struts might have a different geometry to provide more travel.
