BMW M3 Forum (E90 E92)
      01-31-2009, 10:34 AM   #1
dean_g
dean_g's Avatar
Drives: MW F80 M3
DIY hood and trunk roundels??
aanyone know how to do this ?? i should be getting my carbon fibre ones this coming week and have no idea on how to install ..
thanks in advance
      01-31-2009, 10:55 AM   #2
Kev
Critical Care Anesthesiologist
Kev's Avatar
Hong Kong
481
Drives: SMB F83
thanks in advance
Do you have one these plastic wedge tools?
http://cgi.ebay.com/ebaymotors/Parts...4506.m20.l1116
If you do, it's very easy to do the front. Slide a piece of thin card like your insurance in between your hood and the roundel. Wedge the plastic tool in between and lift up. It should pop out. You'll see two rubber grommets in the back of the roundel or they might be left behind on the hood. Remove the grommets and place them back into the hood and press the new roundel down on to the grommets.
The back is the same for E90. For E92/3, it's a little more tricky. The rear roundel has both tape and rubber grommets on it. So you have to wedge and pry around the clock and put it straight out.
You can also do it with a flat head screw driver, but it'll be a little more risky since you can slip and scratch the paint underneath.
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist"
      02-01-2009, 10:43 AM   #3
dean_g
dean_g's Avatar
Drives: MW F80 M3
thanks kev i have something very similar to those tools i believe and with ur explaination i should be fine =]
thank you !!
      02-01-2009, 11:35 AM   #4
pepper
16
Drives: M3
^ yeah for the front, I used a small flat head, and used a mechanic glove right behind the flat head, so a visual you would think a teeter totter , then that gives you good leverage to push the flat head handle, and protects the paint...
Search this Thread:
Advanced Search
m3post
