ZPOST
  TireRack
      01-25-2009, 08:48 PM   #1
Kream
10
Drives: 07 M Coupe, 11 GLK350
Front bumper misaligned
I think I scuffed the bottom of the front bumper while pulling into an inclined parking lot and now the passenger side bumper is not flushed with the side panel. I tried to force the bumper up towards the side panel to see if it would snap on but i'm having no luck. I'm thinking the support for the side panel/front bumper broke. ( http://bmwfans.info/original/E86/Cou...1/ill-51_5960/ ) part 17
How easy is it to remove the front bumper and replace the side panel support? I'm sure someone here has damaged their front bumper before, right? Hopefully I'm not the only dummy.
      10-13-2009, 03:54 AM   #2
schloemoe
Drives: 2004 Z4 3.0i
Hey there,
The front bumper itself is pretty easy to remove, you just need to pop out some of the reusable plastic rivets in the wheel wells, and then a few more torx screws and you should be able to remove it. Also remmeber to disconnect the headlight washers if you have them.
Search this Thread:
Advanced Search
zpost
