Zaino Experts Needed
06-15-2006, 08:56 AM | #1 |
Rep 135
So I took the plunge and got all of the Zaino products I need. Before I begin however here is what I plan to do:
Wash with Dawn Dry with leaf blower No Clay (New car PITA) Apply Z2 with Zaino terry applicator 3 coats with Z6 in between Finish with Z8. Here are some questions for the experts. 1) Is skipping clay a big deal for a one week old car? 2) Is drying with the blower a bad idea for any reason? 3) Is the terry applicator by Zaino safe and should I apply in staright lines only? Should I apply to the whole car before buffing off? 4) When buffing off, is a MF towel safe to use, and should I only buff in straight lines? Should I use a separate MF towel for each layer of Z2 I buff off? 5) Should I use a separate MF towel for Z6 and yet another for Z8? Phew!! I'm tired thinking about this PITA! Expert advice would be appreciated. Thanks, |
06-15-2006, 01:04 PM | #2 |
28
Rep 581
1. It's not a big deal, but I would recommend doing it. a new car can accumulate a lot of crap on the paint from the ride over from Germany.
2. Leaf blowers are fine for drying 3. The Zaino applicator is fine. For the hood, roof, and trunk, apply in front to back motions. For side panels apply in an up and down motion. Yes, apply to the whole car and let it dry before removing. Depending on the temp, it could take 10 - 30 minutes for it to dry. 4. MF is fine, buff in straight lines, and use the same MF until it becomes too saturated with residue (if it does at all). 5. Use one seperate MF for both Z6 and Z8. Hope this helps. |
06-15-2006, 04:45 PM | #4 |
44
Rep 436
don't skip the clay, ESPECIALLY if your car is parked outside.
clay is where it's all at. the rest is just polish/wax/whatever the hell you wanna call it that goes on top of the paint. clay takes out all dirt that you cant' see in the paint. |
06-15-2006, 06:23 PM | #5 |
Lack of charisma can be fatal...
94
Rep 365
Drives: 2006 330i
Here's my 2 cents after learning how to Zaino about a month ago.
You said you were applying 6 coats total. The instructions say to wait at least 6 hours between coats of Z2. I have 2 coats of Z2, Z6 and Z8. Over 3 weeks. The first took me all day to do just one coat of Z2 - Z8. Approx 4 1/2 hours of back breaking wax on and wax off. Good luck with the 3 coats in one day! 1) Skip the clay. Your car is brand new. 2) Dry with whatever you want, I use a Chamois. 3) The Terry applicator is just fine. Apply in one direction... Although its hard to do once your arm starts getting tired. I went in a couple of different directions and my car turned out just fine. 4) Use 100% white cottton towel to buff. You'll need several. 5) I used separate towels for Z6 and for Z8. The car looks fantastic! I mean really fantastic and it stays so clean in-between washes. I get tons of compliments. Good luck! Don't forget to ice your arm afterwards.
Protect Me From What I Want...
_____________________________ |
06-16-2006, 06:48 AM | #6 |
Rep 210
I have had good luck with Zaino products Z2, Z5, ZP-C, ZPX, Z6, Z7, Z8 and clay bar.
I did not clay the 06 325i. I have about three coats of Z5 and one of Z2 on it over six months time. I will try the new Z5 pro soon. I found excellent result using the full procedure including clay on my daughters 2002 Honda Civic which was a mess-hardley washed, never waxed, scratches, 100,000 miles of college road trips, etc. Car looks great-took me two days. Also great results with my wife's black 2005 VW beetle. Again full treatment with clay. Nice thing about the beetle-the black has no swirls and dust does not stay on the car. Quick use of Z6 or Z8 in between works wonders on the black beetle and monaco blue BMW. Meguiar has some very soft cotton towels and applicators available on line. |
06-16-2006, 08:14 AM | #7 |
7
Rep 349
Make sure you use the ZX with the Z2 - especially if you are doing more than one coat in at day.
I've had great results with their products. Make sure the car is really clean when you apply. Anything on the surface after you apply will be under the coating and really impossible to remove.
2011 328xi black on black. Nav, connect, apps, Sirius.
06-16-2006, 08:30 AM | #8 | |
Rep 135
Thanks David and thanks for the great Sticky. That info is amazing. A couple of quick ones for you. Can you advise on the best way to apply Z6 and Z8? How and with what to apply etc. Also for the interior I use a small dry MF towel to lightly dust, I add some moisture when needed. How do you recommend cleaning the very sensitive clear plastic covering the instrument cluster? |
06-16-2006, 09:30 AM | #9 | |
28
Rep 581
In terms of applying Z6 and Z8, just sray onto the paint and immediately spread around/wipe off with a quality MF towel. Use 1/2 to almost 1 squirt per panel for Z8 since it is highly concentrated. For Z6 you can use a bit more. Only use Z8 on a totally clean surface after washing. I would do the same with Z6. Be careful with the plastic covering as it can scrath very easily. I usually use a dry MF towel and dust ever so lightly, so light the MF is just touching. |
06-16-2006, 02:55 PM | #11 |
28
Rep 581
I have not used P21S, but I have used another wax that is similar. And yes, waxes like P21S are nice, but they are beauty waxes that offer limited durability and protection. If you want to rewax your car every 2 weeks, then go with P21S, otherwise use a good sealant like Zaino.
06-16-2006, 08:54 PM | #13 |
28
Rep 581
Theoretically you could use P21s over Zaino, however I would not do this. You won't be able to add more zaino after. Also, the solvents in the wax may eat away at the Z and, and lessen its life span.
I know you saw your friends car and was impressed with P21s, however you have to realize that 99% of a paints look and feel comes from prep work before waxing (claying, multi step polishing), and not from the wax itself. What prep did your friend do? What prep do you do before applying Zaino? What is the age and condition of each car, your's and his? |
06-17-2006, 12:18 AM | #14 |
323
Rep 8,091
Our cars were pruchased within a month of each other
He has hardley any swirls, I have tons I use higher quality washing equipment too and am more carefull I am going to give p21s a spin |
06-21-2006, 06:12 PM | #15 | |
Rep 135
06-22-2006, 12:17 PM | #16 | |
28
Rep 581
06-29-2006, 10:28 PM | #17 | |
Rep 135
Thanks again, |
