11-13-2008, 12:53 PM | #1 |
Doc Brown
1176
Rep 2,174
Needed an Alignment
Well, I guess that I hit one to many pot holes here in NY. Some harder than others. But the other day I noticed that my steering wheel was crooked and the car pulled to the left and when I tried to straighten out my wheel the car jutted to the right. So I took it into BMW this morning, they told me that the procedure was not covered under warranty but they would check it out for me. So I just got a call back, they said that it was out of alignment but nothing was damaged. So $179.00 should fix it. I will pick the car up later and let you know.
11-18-2008, 07:17 PM | #5 |
223
Rep 1,565
Call a few tire shops and see what kind of machine they are using. If they have a John Bean or Hofmann machine, go there. Should cost you ~$100 for an alingment that's just as good if not better than a BMW alignment. Front camber is a PITA, but everything else on the 135 uses eccentrics.
