11-08-2008, 10:50 AM | #1 |
94
Rep 1,245
E90/92 COILOVERS
I want to know if kw or other brand e92/ e90 coilovers fit the e82, yes i am aware that they make e82 specific ones but i want to know if ones for a e90/92 will fit and if the spring rate is even much different.
i search and found that "1mor" is running bilstein pss10's.. i took this from his thread "I got them from Turner Motorsports. Part is the same for the e90/e92. I posted a pic of the Bilstein manual that shows the coilovers are the same for both cars." "Spring rates are the same as the e90/e92, the back is stiffer by 5lbs, which is less then 1%" |
11-08-2008, 03:11 PM | #2 |
Santa Fe Concorso
103
Rep 2,984
I think they would be compatible, but you might want to contact one or more of the vendors in the Commercial threads and ask them.
