      07-22-2008, 05:18 PM   #1
M2point5
9
Drives:
Passanger Window won't go all the way up!
My 135i's passenger window will only go up 95%. The window's used to also roll down a tiny bit upon entry and exit and it has stopped doing it as well (must do it to take off cabin pressure?). Anyone have any ideas?
      07-22-2008, 05:26 PM   #2
amybang
... and Orca too!
amybang's Avatar
Drives: 128i Convertible (AW/CR)
I'm not sure if this is it exactly, but there's a problem when you don't roll the rear windows up first. The front windows get out of alignment.
I think one of the problems then is that it won't go all the way up. But maybe that was only the convertible?
amy!
      07-22-2008, 05:44 PM   #3
Mad Dragon
Mad Dragon's Avatar
Drives: 2010 GTI
SI B51 06 08
Body Equipment
June 2008
Technical Service
This Service Information bulletin supersedes SI B51 06 08 dated May 2008. designates changes to this revision
SUBJECT
Window Short-drop or Anti-trap Malfunctions
MODEL
E82, E88 (1 Series) produced up to 3/2008
SITUATION
One of the following conditions may be intermittently present, but no relevant faults are stored:
  1. When opening the door, the window does not short drop and contacts the surrounding window trim.
  2. The anti-trap feature of the window activates when no obstruction is present.
CAUSE
Software error in the Footwell Module (FRM)
CORRECTION
It is not necessary to replace any parts. A software update is available to address this situation.
      07-25-2008, 05:00 PM   #4
Skulinex
Drives: '4 M3/'5 M3CS/‘18 M3CS /‘21M2C
2015 Toyota 4Runner  [0.00]
2021 M2 Competition  [0.00]
2018 M3 CS  [0.00]
2004 M3  [10.00]
2005 M3 Competition  [0.00]
I can see the future already, we'll be doing "Service Packs" a couple of times per year to fix software issues ala MS Windows ..
      07-25-2008, 08:18 PM   #5
Mad Dragon
Mad Dragon's Avatar
Drives: 2010 GTI
It's already been that way for years.
      07-25-2008, 09:07 PM   #6
hansenc
1addict, and proud
hansenc's Avatar
16
Drives: 128i
2008 128i  [0.00]
I have noticed an issue with the anti-trap on my driver window. its done it so far about 5 times but i will hit the buttons to roll both windows up and it will go up a few inches and back down. my car was produced in June...
      07-26-2008, 12:14 PM   #7
warmtoes
31
Drives: EBII 435i xDrive
And, it's not limited to BMW's.
2014 EBII 435i xDrive M-sport
Gone: 2011 TiAg F25 X3 xDrive35i M-sport
Gone: 2008 TiAg w/Coral Red E88 135i Cab M-sport
      07-27-2008, 05:26 PM   #8
jeremyc74
Drives: '08 135i Montego/Terra
It sounds like the window is staying in the door open postion. Could be the software glitch posted above, or it could be that the door switch isn't working right and it thinks the door is open all the time. The windows will only roll up about 95% of the way with the door open.
      07-29-2008, 10:44 PM   #9
M2point5
9
Drives:
Thanks, I'm about 4.5 hours from a dealer, so I'll have them investigate when I bring it in for its first service.
