      07-14-2008, 02:51 PM   #1
My135
85
Drives:
Best suspension mod?
What is the best bang for the bucks? Just spring first then sway bars later, or sway first then spring, or both at the same time? Will most of the sport spring lower the 135's M suspension by another 1 inch drop? Thanks for the help.
      07-14-2008, 03:06 PM   #2
S54dan
I no longer work for United BMW!
S54dan's Avatar
307
Drives: E46 M3, E46 330i ZHP, E36 325i
1994 BMW 325i  [8.50]
2005 M3  [9.66]
2005 325i  [8.00]
2003 330i ZHP  [9.00]
It all depends on your taste. There is no "best." Best is determined by the driver. I prefer a 1.4 drop in the front and .75 in the rear
BMW CCA, PCA, & CHIN Motorsports Instructor.
      07-14-2008, 05:37 PM   #3
ModBargains.com
Drives: JB E92 335i
Question is what are you trying to pull off? Performance? Looks? Both? Biggest bang for your buck...You go with KW coilovers. I know they're not just springs, but I guarantee KWs will be way better than any set of springs.
How great is the KW Coilover? Well like I'm sure you've read around, the M3 CSL that had the Nürburgring time record has been using the Bilstein coilovers for 2 years...Last year, they switched over to the KW coilovers, and they finished "The Ring" ~30 seconds faster than with the Bilsteins...what does that mean? The Bilstein Coilover that they had record time on was beaten by a whopping 30 seconds just by switching over to the KWs.
Sure, KWs aren't as expensive as other coilovers, but who says that more expensive means better performing?? :biggrin: Plus, with coilovers you get all sort of adjustabilities, including height, so you can your own individual look that you're going for.
As for sway bars, I would probably get that second after the Coilovers, unless you have the ability to get both at the same time--then you can expect an ultimate setup in suspension!
      07-15-2008, 10:55 AM   #4
adc
Drives: 2018 F80 M3 ED
I have a really hard time believing that was the only change. It sounds more like KW advertising than anything else.
But I'm open-minded enough to get educated about it - and if true, a set of KW would be my first mod. So where did you get this info?
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      07-15-2008, 11:12 AM   #5
My135
85
Drives:
I am more performance orienated. How much is the KW coilover? So, you don't think sway bar is important and you think the stock sway bar is good enough?
      07-25-2008, 02:02 AM   #6
BerkTechnology
BerkTechnology's Avatar
223
Drives: Fast
Using a bang for the buck method:
1. tires
2. rear sway
3. front camber plates
4. KW Coilovers (I highly reccommend the V3's)
      07-25-2008, 05:45 AM   #7
Evolution Racewerks
Evolution Racewerks's Avatar
Drives: 20 M340i,15 M4,12 328i,08 135i
Word, I agree. Stock tires are junk. About the worst tires I've driven on (el cheapo tires not included).
1. tires
2. rear sway
      07-25-2008, 09:58 AM   #8
My135
85
Drives:
You mean just thicker rear sway and leave the front sway remains stock? So, you think spring will do nothing other enhance the look? I heard the rear sway is pain in the butt to install. Can I just do the KW coil over and how difficult to install? Would it be the same effort as replacing the springs? Thanks in advance for your help.
      07-25-2008, 12:28 PM   #9
WAY
Australia
458
Drives: Fast ones
1. tires
2. rear sway
What rear sway should I be getting? I am going to get KW Clubsports so I don't need additional camber plates.
      07-25-2008, 12:52 PM   #10
TazioNYC
37
Drives: BMW 135i
Start with replacing the tires and see how that feels. It makes a *big* difference.
      07-25-2008, 01:21 PM   #11
Steve135i
Steve135i's Avatar
Drives:
1. tires
2. rear sway
^^^^^EXACTLY^^^^^
      07-25-2008, 09:13 PM   #12
Heinzftw
Heinzftw's Avatar
295
Drives: 2000 Civic+2008 Accord
Love the mind of professionals!! When will the seminar of "Cars 101" start? Very interested! :biggrin:
Originally Posted by Javi335 View Post
saw you comment and i'd lay on my bed and cry, then i put some Yulio Iglesias music, no more problem.
      07-25-2008, 10:09 PM   #13
coco_m3
coco_m3's Avatar
Drives: Supercharged E90 M3
2008 BMW M3  [0.00]
2010 BMW E90 335i  [0.00]
why not just some H&R Sport springs?
      07-26-2008, 10:08 AM   #14
tjockey
Drives:
Got the H&R coilovers, stay tuned....Got to get them on first:biggrin:
      07-27-2008, 04:34 PM   #15
WhiteOne
Drives: 2008 AW 135i
How about adding some negative camber for 0 dollars.
Adding spacers to the front wheels for under $100.
Might be best bang for the buck.
      07-27-2008, 05:22 PM   #16
SlickShift
SlickShift's Avatar
323
Drives: '11 BMW E90 M3 ZCP, '21 X5 ZMP
If you're looking for the most noticeable difference in handling I'd go with a set a swaybars. I just got some for my 325Ci and the handling is greatly improved.
-Nick
2018 BMW 440i - M Sport, Exec
Glacier Silver Metallic/Coral Red Dakota
Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i
      07-31-2008, 04:46 AM   #17
BerkTechnology
223
Drives: Fast
Yes, rear bar only. Stiffening the rear bar will reduce understeer. It's actually a royal pain to install. It's not something that I would recommend you do at home.
Stiffer springs (lowering springs) will also improve handling as well (lower CG, less body roll, etc) but most of you guys will do it for the looks, the improved handling is a bonus.
Yes, you can install just the KW coilovers only. It's a virtually identical install for springs only vs. coilvers (V1, V2, or V3).
      07-31-2008, 09:28 AM   #18
My135
85
Drives:
Thanks for the answers and this is exactly what I was looking for.
      08-02-2008, 05:03 PM   #19
Upgrade+
Good life
Upgrade+'s Avatar
130
Drives: 2008 E90 M3 AW
I did a bigger rear sway and stiffer endlinks on my old Subaru STI and the handling was night and day. Since this is a rear wheel drive car, would going with too thick of a bar bring the tail end out more since you making it stiffer? What size bar would be perfect for the rear? And would you also recommend endlinks? Just seems like it would help even more.
Current: 08 E90 M3 Alpine White Former: 11 135i Msport Space Gray -Former: 07 335i Titanium Silver E92- Former: 08 135i Alpine White E82- Past: 06 Subaru STI WRB- Past: 04 Audi S4 Imola yellow- Past:97 Honda prelude Ice blue
