07-09-2008, 01:12 AM | #1 |
414
Rep 6,968
Zaino with orbitals
Zaino doesn't require orbital, but can I get same or better result if I use Griot's orbital with zaino? Or would the Zaino compound be too harsh for machine application? I am thinking of buying a Griot's 6" orbital.
- There's nothing in my pocket other than knives and lint
07-09-2008, 06:40 AM | #2 |
12
Rep 468
it will work better...just need to use correct settings...(not sure how they are on the griots orbital)...start with lower setting and move up if necessary...
07-09-2008, 01:15 PM | #3 |
13
Rep 645
Zaino Z2/Z5 wipes on and buffs out easily without an orbital. If you need an orbital to buff, you might be putting on too much sealant. I'd say reserve the orbital for polishing.
07-09-2008, 03:56 PM | #4 | |
42
Rep 890
I have the 6" and the 3" orbital from Griots. I am constantly amazed at how useful the 3" one is for all those little areas, like the bumpers.
2008 BMW 135i Vert!
-Jet Black -6 speed Manual <Who says Vert's are for girls!> -Boston Grey Leather with Black High Gloss Accent -Moonlit Black Top -Comfort Access -Premium P. -Sport P. -Premium Stereo -IPOD/USB -BMW Performance Pedals -BMW Windscreen -Sat Radio Meet Kat! [SIGPIC][/SIGPIC] |
07-09-2008, 05:00 PM | #5 |
Donkey Kong King
89
Rep 1,129
I would use an orbital only for polishing. I would recommend Menzerna products(finishing polish) for use with an orbital.
Follow this with a hand application of Zaino. I see no benefit of using an orbital and Zaino (unless your using the ZP Fusion or maybe the Z-AIO). The Z-2/Z-5 have no abbrasives and require very little product. You would probably end up with way to much product if using an orbital.
[SIGPIC][/SIGPIC]
07-09-2008, 07:00 PM | #6 |
19
Rep 709
From: http://www.zainostore.com/Merchant2/...Q&Store_Code=Z
Q: Can I use an orbital polisher to apply/remove Zaino polish? A: Yes, you can use an orbital to apply Zaino Z-2, Z-3, or Z-5. I don't recommend it because you waste too much polish that way. The pad on an eleven inch polisher can absorb almost enough polish to coat your entire vehicle. Each time you use an orbital to apply Zaino polish, you are probably wasting as much polish, if not more than you actually applied to the car. Zaino polish applies easily by hand, especially if you dampen the applicator pad with water and spritz it with Z-6 before applying it. If you use an orbital to remove the residue, you should place a white, 100% cotton towel between the pad and the paint, and keep it turned and refolded often so that you are removing the residue with a clean section of towel all the time. Note: A single orbital pad WILL NOT remove the polish residue from an entire vehicle. You will have smears if you don't use a towel and turn and refold it frequently.
07-10-2008, 05:32 PM | #7 |
414
Rep 6,968
Thanks esses, I should have thought of checking zaino's webpage first.
I have this small blemish on the hood because my water hose went over the hood when I was washing it and I am dying to get it off. (micro scratches on the clear coat.)
07-10-2008, 06:39 PM | #8 |
19
Rep 709
I know how that goes. I had a small mark on my roof when I received the car - looked like someone threw something plastic against the roof and it scraped. No one else ever noticed, and I didn't notice until I got the car home, but once I did I SAW IT EVERY SINGLE TIME I CAME NEAR THE CAR. Claybar was the answer.
07-10-2008, 11:27 PM | #9 |
13
Rep 645
In this case polishing with an orbital will be appropriate before Z2/Z5. Without polishing, Zaino can actually make those little scratches more visible.
07-28-2008, 07:27 AM | #10 |
Rep 40
I've tried putting on Zaino with a PC7424 and it really is a waste. Takes as long plus you have to clean the pads, etc. The only exception to that is Z-PC Fusion (their only abrasive product) which is fantastic when machine applied. It cleaned up and polished out my GF's black TSX to a swirl free mirror, followed up by Z-5 and Z-2 PRO/Z-6 by hand. But, I use the Zaino applicators and MF towels from DD's for Z-5/Z-2 and Z-6 buffing. Can do the whole car in 30 minutes by hand after it's washed. Read the website instructions carefully and don't use too much product. You really want the thinnest layer you can apply and it'll dry then buff off quickly and easily.
