      07-08-2008, 03:53 PM   #1
SV Concepts
SV Concepts's Avatar
Drives: Vorsteiner E60 M5
Location: 1460 White Oaks Rd. Suite F. Campbell, CA 95008
Jlevi SW | Active AutoWerke Performance Products
Hi guys,
OK. So here’s the situation: BMW builds this incredible go-bot called the 135i. But you’re not content with merely “incredible”. You’re chasing “stupendous”. And your friends at Active Autowerke have just the ticket to help you get there.
We are proud to announce that we're now carrying Active Autowerke's products for the E87 1 series. Below are some performance products for the 135.
Active Autowerke 135i Blow Off Valve Kit
Key Features
High-efficiency single displacement BOV – takes place of two smaller plastic valves
Large opening can handle maximum boost, provide high flow
Proven and tested to handle 600+ HP
All aluminum venturi design with factory-style throttle clamp
CNC machined flange
Durable black powder-coated wrinkle finish
Illustrated instruction manual & installation guide for easy “Plug ‘n Play”
Active Autowerke Processor: BMW 135i
Key Features
-Proven HP and torque gains measured at the rear wheels
-Verified & tested on numerous manual and Steptronic 135i’s
-Does not throw "CHECK ENG" faults or create annoying limp conditions
-XEDE unit is small, compact and easily attached to the factory wiring harness by any competent technician
-Full control over Fuel and Boost parameters and Ignition
-System is fully-reversible, leaving no trace
-Programmable for future revision upgrades; easily transferable to another 135i
-Optional feature: VALET/RACE switch to easily control power & boost with the flip of an in-glovebox switch
Performance Specs
-Power : 55+ RWHP
-Torque : 75+ Ft lbs of Torque
-1/4 Mile : 11.8-12.9 sec
Active Autowerke 135i Intercooler Kit
There’s an old saying: “If you can’t stand the heat, get your intercooler outta the engine!”, Or something like that.
Factory intercoolers work well on factory 135i’s, but with added boost comes added heat load. To overcome this, Active Autowerke’s unit stands tall and way up front, catching more air with the help an 88% larger core and a specially designed shroud.
Our tests show an air temp drop of close to 30° F in the intake manifold, with a gain of 12 usable rear wheel HP on a Mustang MD250 dynamometer. btw: the ambient temperature in our shop measured a scorching 92°F during the session. This thing works.
Please don't hesistate to ask us any questions you may have.
Thank you,
JleviSW.com
      10-07-2008, 03:21 PM   #2
SV Concepts III
375
Drives: BMW Duh
We also now have the Active Autowerke Short Shift Kit available for your 135!
      11-20-2008, 01:09 PM   #3
SV Concepts III
375
Drives: BMW Duh
Can't wait to order these up for my car!
      11-20-2008, 03:34 PM   #4
frimmelnojerz
frimmelnojerz's Avatar
Drives: Montego blue 135i
Originally Posted by squeak View Post
i went on AA website and didnt see the short shift for the 135i just the 335i.
also how much are you doing to your car when you get it? it seems like everything!
the 335 short shift kit fits the 135.
08' 135 in much need of some TLC.
But after that... Watch out.
AA/Berk/ER/UR/CP-e/Snow/ESS
      11-20-2008, 05:05 PM   #5
SV Concepts III
375
Drives: BMW Duh
Correct, the SSKs are compatible between the two models.
Joel...you'll have to wait to see the complete list but it's a long one
      04-01-2011, 04:59 PM   #6
SV Concepts III
375
Drives: BMW Duh
Thanks guys!
