06-20-2008, 10:55 PM | #1 |
10
Rep 119
DIY Request: Ebrake handle swap
Aside from a few other mods I've been trying to accomplish, I can't figure out how to change the ebrake handle. I've read through bimmiman.com's how to and it doesn't make sense since the how to is written for a 3 or similar, not the 1 and the 1's ebrake base is wider at the base. I clipped the OEM ziptie and removed the leather housing to try and figure out how to remove the handle but no luck. I couldn't find a screw. Maybe I'm just not cut out to try modding. Any support would be greatly appreciated. Thanks.
06-21-2008, 01:50 AM | #2 |
18
Rep 214
There are two small metal tabs, one on either side of the brake arm. The handle itself has two small openings into which the tabs attach to hold the handle in place. You need to slide a flathead screwdriver in between the arm and the handle, then twist the screwdriver such that the flathead creates a gap to separate the hole away from the tab. Do this on both sides while pulling hard on the handle.
When you slip on the new ebrake handle you got to push in real hard to clip on the tabs into the holes. Good luck.
2012 135i | AW on Blk | 7DCT | M-Sport + Premium | Nav | Harmon Kardon | BMW Performance Exhaust & Kidney Grilles
