06-20-2008, 05:09 PM | #1 |
81
Rep 1,075
You guys left out a key piece of info regarding oil change.
I just changed my oil for the first time today (at 1,526 miles).
I pulled the front end of the car up on the rhino ramps and removed the small door from the underbody panel located below the oil drain plug. When I removed the drain plug hot oil shot straight across at a 30-45 degree angle. The oil shot so far over it went across the door opening and hit the panel on the other side. It created a mess on the top of the panel. The oil drained down hill on the top side of the plastic panels and ended up dripping on the floor from the middle area of the car. The next time I *will* have some sort of deflector plate to keep the oil from making a mess. I poured the old oil back into quart containers and measured 6-1/2 quarts removed. I could've spilled up to 1/2 quart so 7 quarts total capacity sounds about right. This is the biggest mess I've ever had changing oil in a car.
Ordered 4/7/08, Delivered 5/15/08, Sold, but not forgotten.
06-21-2008, 09:41 AM | #3 |
81
Rep 1,075
Maybe 10-15 minutes. I plan on cutting a piece of pvc pipe in half to use as a deflector for the next oil change.
06-21-2008, 10:21 AM | #4 |
79
Rep 1,597
Wow that sounds like a pain in the ass. I wonder if it happens to everyone or if it's just something with your car. Anyone else who has changed their oil care to chime in?
06-21-2008, 10:42 AM | #5 |
34
Rep 1,002
Mine shot out some, but not all the way to the other side of the pannel. I had it on a full lift though so that could have made the difference.
"Don't run, you'll only die tired" ~ Gunship Pilot
06-21-2008, 12:57 PM | #6 |
Rep 92
Did the same thing on my Z4 when I changed the oil a couple months ago; tremendous mess. I haven't thought of a good solution yet for when I change the oil on my 135i. I'll need a solution soon, though; break-in is almost over (1038 miles so far).
135i Black Sapphire, Lemon, High Gloss Black, 6MT, pretty much loaded
Performance Center Delivery was awesome! |
06-21-2008, 03:17 PM | #7 |
81
Rep 1,075
I thought about cutting some pvc pipe inhalf length-wise and use it to direct the oil to the pan. It would be faster than removing the entire undertray. Besides.. white pvc plumbing pipe is cheap.
06-21-2008, 03:45 PM | #8 |
Rep 14
Oil Change
I did an oil change today and did have a little bit shoot out but it wasn't bad. I had the car on ramps so that might have made it easier. When I pulled the drain plug the glove I had on got covered with oil so that might have reduce the stream flow some.
06-21-2008, 04:19 PM | #9 | |
4449
Rep 7,594
Drives: '19 M2C
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
06-21-2008, 04:28 PM | #10 |
289
Rep 1,201
I feel bad for all of you. (But I laughed on inside )
Btw, where is the oil filter located on the 135? |
06-21-2008, 05:08 PM | #11 |
Change for a Nickle?
14
Rep 875
I had a similar issue on my Subaru, so I just assumed that this one would do the same thing... and it did. In anticipation, I stuffed a couple of shop rags along the edge of the door opening. It was just enough to deflect the overshoot.
Mike
"I tasted death many times on the river today. Do you want to know what it tasted like? Do you REALLY want to know? Well I'll tell you then: it tasted like BEEF JERKY." - unknown paddler 8/1/09
06-21-2008, 05:42 PM | #12 | |
28
Rep 1,340
Drives: 2008 135i SGM MT
Garage List 1995 Acura Integra SE [0.00]
2008 BMW 135i [0.00] 2006 Porsche Cayman S [0.00] 1999 Toyota 4-Runner [0.00] |
The filter is on the top drivers side of the engine compartment in front of the air filter box.
2008 135i SGM |
06-21-2008, 08:49 PM | #14 |
21
Rep 469
I used the oil change door to drain the oil and it worked fine for me. Thanks to an earlier thread, I had my oil pan a little bit towards the passenger side to catch the stream shooting out the side, but it definitely didn't go as far as hitting the side of the panel.
135 Monaco Blue - ED April 19th 2008
6spd, Sprt, Prem, Cold, Ipod, Comfort, HD Radio |
06-21-2008, 09:15 PM | #15 |
Digital Cerebrum
18
Rep 408
Drives: 05 330ci ZHP
Interesting - I did not have this prob, up on rhino ramps, and car was cold but warmed up until oil temp hit 160/170 mark - oil was pretty frickin' hot still........
10-26-2008, 08:17 AM | #17 |
81
Rep 1,075
Update: I'm getting close to my next oil change (at 5k miles) and I still plan on rigging up some sort of oil deflector plate. FWIW, I'll take some pics. I believe some of you guys didn't have as much of a problem because your oil wasn't as hot as mine.
10-26-2008, 07:19 PM | #20 |
Alpine Master
109
Rep 1,310
Word. Or less, especially in a performance engine with synthetic oil. This ain't a Ford V6... .
Alpine White with Taupe Leather 135i, Sports Package, Heated Seats, Comfort Access, iPod Adapter
Fastness: http://www.1addicts.com/forums/showthread.php?t=252727 |
10-26-2008, 07:43 PM | #21 | |
81
Rep 1,075
BTW, I'm not wasting it. It gets recycled.
10-27-2008, 09:50 AM | #22 |
Ninja
14
Rep 335
I read the previous thread and used the access door to the drain plug area as my deflector plate. I just wedged it in the opening appropriately and it worked great. Just wiped it off afterwards and no spilled oil. :smile:
SGM/Coral
