      06-15-2008, 02:44 AM   #1
WAY
Australia
458
Drives: Fast ones
Oil temp
I have been watching my oil temp. Even on a cold 10 degrees night, I am getting up to 115 celcius without pushing the car too hard. Are others getting this high? This is a worry for the track. What can I do??? Are we aussies missing out on any cooling devices?
      06-15-2008, 02:47 AM   #2
Kris
123
Drives: m3
I've seen 120, and around 90 too. I was told at the dyno my oil temp was some 15degrees lower than jeff & joe's car - weird!
Get a bigger oil cooler if you're worried !
      06-15-2008, 02:47 AM   #3
jcw2006aus
Drives: 135i
Yep i can get around 120 as well, i have heard the n54 runs hotter than "normal", I just did my first oil change, already at 1986 kms....
      06-15-2008, 02:53 AM   #4
WAY
Australia
458
Drives: Fast ones
I just edited my original post. I was meant to say that I am at 115c WITHOUT pushing too hard. Yeah these engines sure runs hot!
      06-15-2008, 02:56 AM   #5
professor
Drives: Z4 M40i
enter FMIC....
      06-15-2008, 03:08 AM   #6
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
Same here..normal driving 115 to 120 degrees..
      06-15-2008, 03:14 AM   #7
WAY
Australia
458
Drives: Fast ones
Originally Posted by professor View Post
enter FMIC....
Already in the plan. :smile:
However, I am not so sure if FMIC is going to really help it. Those more experience in mechanical engineering may want to help me with this, but a FMIC will help getting cooler and denser air, but what is it's roll in terms of getting the oil temperature down?
      06-15-2008, 03:24 AM   #8
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
Wayne the FMIC will help to some extent.
If you can find some where appropriate to mount it.
It will increase your volume of oil, so in doing so will keep the temp down as in your volume is greater, so will stay cooler longer..
Is that what u are asking??
      06-15-2008, 03:27 AM   #9
Kris
123
Drives: m3
Na, FMIC won't help. You mean a larger oil cooler Joe.
FMIC will only decrease your charged air temps (ie compressed air out of the turbo) because it's cooler, it's therefore denser so that increases your power figures or at least stops power from being robbed due to heat.
      06-15-2008, 03:30 AM   #10
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
Ok..I stand corrected by Kris....
I think I will have another glass of red..:drinking:
      06-15-2008, 03:31 AM   #11
Kris
123
Drives: m3
I'm eating chocolate, an entire block right next to me! *laughs*
      06-15-2008, 03:32 AM   #12
professor
Drives: Z4 M40i
this is a $67000 question and i don't know the answer apart from the little i have read which all seems to suggest that the quality of the fmic matters a lot.
it seems that two effects are at work. the more the volume of cold air you provide the engine the cooler it will run (and consequently lower oil temps) however this increased efficiency should also make the engine run hotter! this then explains why some people report hotter temps with an FMIC.
it would make common sense that the ecu should need to be reprogrammed to understand a completely different flow rate and to adjust for these two compensating effects.
anyone know this stuff? please chime in.
      06-15-2008, 03:33 AM   #13
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
Just lace the chocolate with protein powder Kris..:biggrin:
      06-15-2008, 03:34 AM   #14
professor
Drives: Z4 M40i
see what i mean?! kris is refering to the net effect from both the compensating effects...
      06-15-2008, 03:35 AM   #15
Swift135
Australia
23
Drives: 330d, M3 DCT E92
Mine settles the needle width past 110 so 112, on a hot afternoon with some hard driving it went to about 118 the drops back to 112 at cruising speed. I must say I don't seem to get full power unless I am about 110-112, even at 100 if I wind it out in 2nd it doesn't feel as strong as at 112. Maybe the car only gives full power when it thinks the engine oil is at peak operating temp.?
      06-15-2008, 03:35 AM   #16
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
For $67K I have already put my 20 cents worth in already Prateek...hehehe
      06-15-2008, 03:37 AM   #17
professor
Drives: Z4 M40i
ha ha joe! 334,999 posts more on this one then please!
      06-15-2008, 03:42 AM   #18
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
hahaha..Prateek..have you a calculator sitting in your lap..lol
      06-15-2008, 03:43 AM   #19
Kris
123
Drives: m3
ha joe! I told kel to get the natural ON stuff - she got the other stuff! :/
professor, I have no idea. But I've not heard of a FMIC lowering oil temps because the engine runs cooler..
      06-15-2008, 03:56 AM   #20
professor
Drives: Z4 M40i
kris my 101 on this tells me that a car's engine has two methods of cooling - crankshaft, camshaft, etc cooled by oil and the rest of the engine cooled by the radiator coolant. so an engine oil cooler and an FMIC should therefore have impacts independently from each other but both affect the engine's running temperature. in fact, i once read about a system in PM that used the FMIC to cool oil as well as the turbo air using ambient air temperature which seems to reinforce this. correct me if i am completely off target here?!
      06-15-2008, 04:02 AM   #21
Kris
123
Drives: m3
News to me but sounds on the money!! I don't think an engine will ever run 'cool' as such though.. even if the air temp drops by 30degrees Im not sure the engine itself would cool by any measurable amount!?
      06-15-2008, 06:30 AM   #22
AussieRacer
AussieRacer's Avatar
Australia
24
Drives: 2008 135i
More power ALWAYS equals more engine heat output. So if the intercooler made the engine produce more power, the engine would also have bigger cooling demands.
WAY, with good airflow at higher track speeds you might not have too many cooling issues. If using a stock setup, the brakes will probably give up before cooling will be an issue.
