View Poll Results: Will you be doing additional oil changes? | |||
No, BMW knows best | 55 | 30.73% | |
Yes, I will be paying to have additional oil changes done | 124 | 69.27% | |
Voters: 179. You may not vote on this poll |
05-25-2008, 02:27 PM | #1 |
12
Rep 128
Is anyone ONLY doing the included oil changes?
Just curious how many people are going to stick with the 15k mile oil intervals only. It's concerning to me to feel like BMW is more concerned about their bottom line than the longevity of my engine.
05-25-2008, 07:46 PM | #3 |
18
Rep 511
I think the overriding decision here is based on whether you are leasing or buying. If leasing (and plan to turn the car back in at 2-3 years) then follow BMW's schedule. It's their car. If buying, and planning on keeping long term, probably should consider some extra maintanence.
05-26-2008, 03:22 PM | #5 |
Uber-Lee7 Member
47
Rep 1,440
i voted BMW, but i will be doing a 3000 mile clean out initially. Its a lease, so screw em...
05-26-2008, 04:04 PM | #6 |
Rep 33
I own, extra oil changes for me
Oil analysis at some different intervals is a great idea - if anyone does it let's hear some results. If I have time, I'll get a kit from these guys and do it myself:
http://www.blackstone-labs.com/index.html Regardless of the analysis, I'll probably change the oil myself at 1,500 or 2,000 and then again at 7,500 or 8,000. Here's my thinking on this: My last car was a 2004 B6 S4, the last year that those cars came w/ included maintenance. So, since Audi was paying for the service, Audi had long service intervals. I bought that car used, right after the first service was done. I waited the full "recommended" interval (15k, I think) before changing oil. The motor sounded very different and felt much smoother right after the oil change than it did when it went in for the service. (No, it was not low on oil before!) Again, no oil analysis, but I just didn't feel good about that. I felt that even with a naturally aspirated motor, my oil was not in good shape after 15k and I have to think the hot BMW twin-turbo will be just as hard on oil. Just for peace of mind, I'll be changing oil at about 7,500 miles on my 135 as I hope to keep it a long time! |
05-26-2008, 05:38 PM | #7 |
125
Rep 404
Drives: 16' X5 M-Sport / Space Gray
dont you think that if you change your oil too soon before the first scheduled interval, you would not have given enough time for your engine to break loose the engine's metal shavings from the factory?
change at 1500 miles then at 7500 seems excessive, no? |
05-26-2008, 06:54 PM | #8 |
968
Rep 3,323
Good point. I plan on keeping my 135i a long time and plan on getting the oil changed every 7500. Course BMW will be doing every other for free. But, my intial oil change after break-in should be when? 1,000 1,500 2,000... when would be the best interval for the first break-in oil change?
05-26-2008, 07:49 PM | #9 |
2146
Rep 10,176
05-27-2008, 01:21 PM | #11 |
58
Rep 1,201
Drives: 2015 M235i, 2017 Tundra
i found us some good reading....with tests
http://neptune.spacebears.com/cars/s.../oil-life.html http://neptune.spacebears.com/cars/stories/mobil1.html they tested syntheic oil...getting an oil sample tested every 1k miles...mobil1 made it to 18k miles with a filter change at 12kmiles on a camaro. |
05-27-2008, 02:13 PM | #12 | |
124
Rep 5,627
BTW, for anyone paying for a dealer 7,500 mile change; make sure you request only an oil/filter change, not what was known on previous models as an "Oil Service" - The oil/filter change will be significantly cheaper (ca. $100 for 7 quarts of BMW synthetic, OEM filter +labor). Tom |
05-27-2008, 03:16 PM | #13 |
8
Rep 226
If you want to treat your engine well, do an initial oil change by ~2000 miles. If you have your green eye shade on (and are leasing or plan to sell it before the warranty expires), then use the BMW maintenance sked.
Engines don't "know" about miles. Engines understand 'hours' and 'load'. New non-turbine aircraft engines I've broken in spec'd a first oil change at 25 hours. (Take-off and climb-out are max rpm affairs, not unlike an extended autobahn run). Marine engines I've broken in - diesels - all spec a 50 hour first oil change. BMW was - before it started paying the bill - no different, recommending a first oil change after ~ 30-40 hours of operation (approx. 1500 miles). So back to the first sentence: If you want to treat your engine well... BTW...BMW says you have 'lifetime' differential gear oil. Those gears initially spin off machining residue, as well. And then there's the transmission... Jack |
05-27-2008, 05:37 PM | #14 | |
16
Rep 282
I think I would be doig intervals oil changes with mobil. For some reason Porsche, Evolution, Corvette and others sports cars use them... |
05-28-2008, 08:49 AM | #15 |
54
Rep 1,015
You bet I'll be doing many in between changes!!
Crowley
The last words on the powerplant should go to a clearly overwhelmed Hormazd Sorabjee, editor and publisher of Autocar India: “There is something simply magical about BMW’s in-line six. It has a creamy smoothness that makes velvet feel like sandpaper.” |
05-28-2008, 09:53 AM | #16 |
29
Rep 1,340
Drives: 2008 135i SGM MT
Garage List 1995 Acura Integra SE [0.00]
2008 BMW 135i [0.00] 2006 Porsche Cayman S [0.00] 1999 Toyota 4-Runner [0.00] |
I did my first at 1800 miles.....
Plan to do one in between the recommended 15k by BMW. So every 7.5K for me, and I pay for every other one. An extra $100 per year is well worth it in my opinion.
2008 135i SGM |
05-29-2008, 02:12 PM | #17 |
269
Rep 4,470
http://neptune.spacebears.com/cars/s.../oil-life.html http://neptune.spacebears.com/cars/stories/mobil1.html Holy moley. Their final conclusion is that, following an initial oil change after 3000 miles (when most of the wear occurs), it might be possible for an engine to forgo any other oil changes provided they were using a high quality synthetic oil, a bypass filtration system and changing filters regularly. Maybe that isn't so surprising if you're a chemist and know how how advanced these formulations are. It's quite possible that, with the exception of doing the first oil change relatively soon, BMW has it right in stretching the other oil changes out. |
05-30-2008, 09:26 AM | #18 |
19
Rep 337
might b a dumb question, but if i choose to change the oil in b/w intervals, could bmw refuse to do their oil changes b/c i messed with it myself,...since they will b able to tell from the oil filter
b/c i just think 12-15k for an oil change is just wayyy to long specially for a higher end vehicle |
06-01-2008, 12:35 AM | #19 | |
27
Rep 932
You can change the oil and filter daily, and it won't have any affect on your maintenance warranty. If you break something while you're doing it, that's a different story. Buy the filter adapter (the part number is posted somewhere in the DIY forum), torque the drain plug and filter cap to 25 N-m with a torque wrench, and you won't have any problems.
06-04-2008, 10:22 AM | #21 |
One Fast 1
53
Rep 747
Ditto...Took my 135i in around 1600 and plan to take her back around 7500.
