05-17-2008, 06:31 PM | #1 |
E30 Addict
38
Rep 590
Thinking of cutting one coil...
All of the pics of the H&R sports I have seen on 135's have a huge rake. All of the rear are a decent ammount higher than the front. I have a set of H&R sport springs, and I am considering cutting one coil off of the rear only, inorder to even it out. What are your guys thoughts on this? Keep in mind I hear that some aftermarket springs actually work better with a small amount removed.
05-17-2008, 06:33 PM | #2 |
2146
Rep 10,176
Call TC Kline and get some adjustable springs. If you look at the H&Rs, you'll see that cutting a coil will make them sit weird in the spring perches, and they would compress differently. Plus cutting a single coil doesn't get you much height difference.
Another thing to think of is that you'd be lowering the car more than an inch, which is usually the threshold for the stock dampers. |
05-17-2008, 09:28 PM | #4 |
Tech. Certified
11
Rep 309
+1 man...
I would never recommend cutting a coil and larryn was right, too low is baaad on the stockers. |
05-17-2008, 09:32 PM | #5 |
123
Rep 905
Maybe on some old muscle car, but not for this car.
2018 BMW M3 - 12.1 @ 121mph
2014 BMW 335i M-Sport (Sold) 12.4 @ 113mph 2008 BMW 135i (Sold) 12.8 @ 106mph |
05-19-2008, 10:33 AM | #8 |
Happy 1er
32
Rep 137
if you can afford a BMW, spend the money to mod it correctly. cutting springs is not it.
Cutting spring is usually considered because it is supposedly cheap, but only in up-front costs, 3000 miles later you are replacing suspension components. Cutting a spring causes an unknown increase in spring rate. This may cause unknown (usually poor) results in handling and safety of the vehicle. It also increase the stress level put on the spring as well as adversely effecting other related chassis components. Will tend to blow out your shocks much quicker as, so in the long run, not cheap anyway. |
05-19-2008, 10:40 AM | #9 |
Totally Add1cted
17
Rep 503
Drives: X1 Xdrive23d
^^+1
No to mention reduce braking effectiveness Don't do it.
Proud new owner of a X1 23d in Jet Black
05-19-2008, 10:46 AM | #10 |
470
Rep 988
didn't you learn your lesson from back in the day with Honda's and Acura's?
Cutting springs is a BIG BOUNCY MISTAKE!!! I remember when people would cut, vs melt, and even clamp the springs. My buddy clamped his springs and the clamps broke off a few days later... the car jumped up like it had hydraulics. Another buddy decided to just take out the springs... thing rode stiff like a skateboard. Oh welll that was 15 years ago and we all learned are lessons since then. |
05-19-2008, 11:45 AM | #12 |
4449
Rep 7,594
Drives: '19 M2C
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
05-19-2008, 02:18 PM | #14 |
Rep 15
Please don't this!!! You're going to ruin your car, there are alternatives! Spend the money and get it done properly. If height is all you're concerned with, I would look into KW Variant 1.
05-19-2008, 04:10 PM | #15 | |
2146
Rep 10,176
05-20-2008, 06:22 PM | #18 | |
Rep 11
05-21-2008, 01:26 AM | #19 | ||
E30 Addict
38
Rep 590
Anyways I just wanted to see your guys thought on it. I am aware of all ofthe affects of changing spring rates and what not. Quote:
05-21-2008, 01:35 AM | #20 | |
E30 Addict
38
Rep 590
Also you do not cut shocks, it is springs. Please read the thread, before you criticize people within it. It is stated very clearly that the subject is springs, and the reasons why it was brought up. And please do not put down civic drivers. There are many people who own civics that are huge automotive enthusiasts, and who make very nice cars. Cars that are very fast, and nice looking. Civics make excellent cars in every aspect, reliable, quick, safe, moddable, very capable in races, etc. And please do not sterotype people, you may offend someone.
05-29-2008, 10:59 AM | #22 | |
16
Rep 355
k = spring rate constant G = material rigidity n = number of coils D = Diameter of wire Consider 'G' constant; but, it is really not because you will get a lot more consistency from OEM then you will from some of the after market springs. It probably has to do with the temporing process. It is also easy to calculate your resultant ride height. It is true that you will need to have your shocks revalved for your new spring rate; but, if you are going to change springs to a stiffer spring, you should have your shocks revalved anyway. Read any of the ___ to Win series -- Engineer to Win, Tune to Win, Design to Win or Fred Puhn's, How to Make Your Car Handle. Every H&R, Tokico, or Eibach that I have installed has sagged. Hint: Don't cut your springs with a torch, that will surely create some unusual spring characteristics.
Alan
08 135I (AW/Coral Red - delivered 3/15/08 -- 13 Audi S4, 83 SC (trackster), 90 C2 (Sally's Carrera), 04 Avalanche Blingmobile |
