      05-05-2008, 02:51 PM   #1
woodman650
Super Couper
woodman650's Avatar
Drives: TBD
reapplying badge?
I've seen a lot of posts on removing badges but I'm sort of curious as to what you'd use to reapply a badge.
What kind of tape or adhesive does the manufacturer use that would make that strong yet removable bond? I wouldn't want to try to reapply a badge with some whimpier double stick tape only to have it fall off when I'm washing my car, haha.
      05-05-2008, 06:03 PM   #2
Neo187H
Drives:
Your best bet would just be to buy another badge I would assume.
      05-05-2008, 06:41 PM   #3
RobLS
29
Drives: M3 Coupe
I thought badges were a push pin design, where you pop it in and it sorta locks itself, things have changed I assume?
      05-05-2008, 06:59 PM   #4
woodman650
Super Couper
woodman650's Avatar
Drives: TBD
sorry, I am refering to the model # (135i characters)... each letter is held on with some sort of foam and adhesive. I've seen a lot of people recommend 3m mounting tape but that doesn't seem like a decent solution at all.
Anyone know what kind of adhesive is used? It's not something exclusive to BMW, it's glue. I shouldn't have to buy new characters just for the adhesive on the back, haha
      05-06-2008, 09:13 AM   #5
BMW Dreamer
BMW Dreamer's Avatar
72
Drives: Modded 06 TL Manual
I have debadged and re-applied badges b4. Autozone sells 3M two sided door trim foam tape. It takes time to trim around the numbers with an exacto, and make sure they are straight. I used painters blue masking tape to make a straight line, then re-applied the numbers/letters. Easy but takes time.
      05-06-2008, 12:41 PM   #6
SlickShift
SlickShift's Avatar
323
Drives: '11 BMW E90 M3 ZCP, '21 X5 ZMP
If you plan on reapplying the badge later you should make a template before you remove them. Lining them up perfectly is extremely difficult without one.
-Nick
2018 BMW 440i - M Sport, Exec
Glacier Silver Metallic/Coral Red Dakota
Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i
