      04-30-2008, 04:32 PM   #1
IDBMW
IDBMW's Avatar
Drives: 2019 X3 M40i
Great fuse device for adding 12V accessories
Here is a little device that makes for a clean install for additional fused 12V power from the fuse panel like a radar detector.
You remove the original fuse and Install the Add-A-Circuit. One of the fuses in the Add-A-Circuit replaces the original fuse and the other one has the wire connected to it for accessories use.
I use this for my radar detector. On my Z4 the fuse panel is behind the glove box. I run my radar detector power wire from the fuse panel up the A pillar, across the top of the windshield at the headliner. The wire is hidden out of the way.
You can tap power from the overhead lights to make a shorter run to the radar detector but it is not fused from the accessorie and could cause problems if you get a short
2019 X3 M40i - Black Sapphire Metallic - Mocha Lather - 21" 718M wheels - Every option except Sun Shade
      04-30-2008, 09:26 PM   #2
Lester
295
Drives:
Add-a-circuit
Where do you get these? Can someone mail me a couple?
2008 135i, Jet Black, 6 spd, Canadian Sport package, black leatherette, manual seats, aluminum glacier trim, PDC.
1983 E21 Delphin, M10, 5 speed, LSD, MSW wheels, recaro seats, Hartge strut brace, rear sway bar.
[SIGPIC][/SIGPIC]
      04-30-2008, 09:40 PM   #3
cmd
Drives: 135i
Amazon would be glad to, I bet. You can probably find them locally.
http://www.amazon.com/Littelfuse-FHA.../dp/B0002BGELQ
      04-30-2008, 10:08 PM   #4
MadMan77
↓↓↓ Ex-Con ↓↓↓
MadMan77's Avatar
Guam
34
Drives: Jet Black '08 135i
If you have an AutoZone in you area, that is where I got one to run gauges in my STi.
      04-30-2008, 10:19 PM   #5
djmBMW
djmBMW's Avatar
Drives: 135
Autozone has two varieties, one for the larger spade fuse and also one for the "mini"spade. Has anyone determined which fuses in the 135 are switched on from the ignition vs on all the time?
      04-30-2008, 11:43 PM   #6
InsaneSkippy
InsaneSkippy's Avatar
79
Drives: 135i
I love those things! I used one when I hooked up the...er...siren... to my car. It makes for a very easy and clean install.
      05-06-2008, 07:21 AM   #7
MZWIE
386
Drives: M2
One comment. I found that in the 1 none of the "big" fused were in the ACC circuitry. I had to use one of the empty "small" fuses for this.
In essence I made my own "add-a-circuit" using a small spade lug.
Search this Thread:
Advanced Search
