04-26-2008, 11:24 AM | #1 |
Rep 75
Underrated at 300hp/300ft-lbs?
MWERKS dyno'd a stock 135i and got 280hp and 295ft-lbs AT THE REAR WHEELS.
I've heard approximately 20% of the power from the engine to the rear wheels is lost to the drivetrain. Based on MWERKS numbers and 20% loss, the 135i puts out 350hp and 369 ft-lbs at the flywheel. 350/369 is a stretch; but I wouldn't be suprised if 300/300 is underrated considering the car does 0-60 in 4.8 and the 1/4 mi in 13.3. |
04-26-2008, 12:04 PM | #2 |
123
Rep 905
I can't see the video here from work, but what type of dyno is it? They all measure differently, some high, some lower. Plus, whoever is operating it can change settings to get higher or lower numbers. Not necessarily saying that is what happened, just stating it is a possiblity. For me, it's all about the change from stock. I will use the same place to dyno, and make sure no other settings are changed. Just try to keep the variables to a minimum.
2018 BMW M3 - 12.1 @ 121mph
2014 BMW 335i M-Sport (Sold) 12.4 @ 113mph 2008 BMW 135i (Sold) 12.8 @ 106mph |
04-26-2008, 12:05 PM | #3 |
Santa Fe Concorso
103
Rep 2,984
That seems optimistic in my expierence, probably more like 15-17% drivetrain loss in the 1-Series. And the same car's output can vary widely on different dynos and different days.
04-26-2008, 12:07 PM | #4 |
54
Rep 1,015
My guess is that we are seeing around 12% loss with the manual tranny ..
Crowley
The last words on the powerplant should go to a clearly overwhelmed Hormazd Sorabjee, editor and publisher of Autocar India: “There is something simply magical about BMW’s in-line six. It has a creamy smoothness that makes velvet feel like sandpaper.” |
04-26-2008, 01:30 PM | #8 | |
76
Rep 5,970
The only way they could know actual crank HP is by pulling the engine out of car and putting it on an engine dyno. It's entirely possible that they did that, but I can't seem to find anything that confirms it. I suspect they're using a standard drivetrain loss and a chassis dyno like everyone else, considering that they're giving the numbers at the crank and at the wheels. It seems like they just used a loss calculation. |
04-26-2008, 03:23 PM | #9 | |
Rep 75
There also may be a difference between the new HP rating system and the numbers most equipment put out. It's not necessarily peak HP and torque that makes a car fast; the power curve is critical. The 135i has a nice FAT power curve....no waiting for the turbos to spool up or for it to wind up into the power curve (i.e. V-Tec). |
04-26-2008, 04:37 PM | #10 |
103
Rep 2,626
its about the same as the s54 in the e46 m3 in terms of peak output on most dyno, maybe a bit more powerful
'08 Black Saphire/Black Z4 M Coupe
RIP Gretta: Blue Water/Lemon 135i. Died to save me. -ChuckV |
04-27-2008, 06:49 AM | #11 | |
13
Rep 610
This is not really news, for it has been known for several years that the N54 produces about 320hp. Secondly, it has also been known that the tranny loss is not static but variable based on RPM and does not exceed 13.5% Again, Dinan has done extensive bench testing & research on this engine and all the data can be seen on their web-site. There is/was no need for speculation. |
04-27-2008, 04:16 PM | #12 |
50
Rep 657
Turn off TC
They need to turn off the traction Control, When we were playing with mine on the dyno turning the TC Off, gave me wonderful results. Thinking about the chip upgrade thou any suggestions
-135i BSM, CRBL ,custom front lip/Indianapolis red fade, blacked out tail lights/corner headlights, golf tee, BMS Air intake, SSTT, CF spoiler,Powdered coated OEM rims gunmetal high gloss,custom Rear diffuser Black/Indianapolis red fade |
04-27-2008, 05:45 PM | #14 | |
54
Rep 1,015
Looks like they are using something under 12% loss then ... pretty efficient.. Crowley
04-27-2008, 05:46 PM | #15 | |
54
Rep 1,015
Is that the auto? I just can't see the car loosing any more than 12% (Manual) .. My 2004 cobra was around 12% .. I can't believe this car wouldn't be as efficient or more so with the rear ... Crowley
04-27-2008, 07:55 PM | #16 |
81
Rep 1,075
I agree.. can't be much more than 12% on these cars with a manual. AWD Audi's are assumed to have around 18% loss.
Ordered 4/7/08, Delivered 5/15/08, Sold, but not forgotten.
04-28-2008, 12:46 PM | #17 |
103
Rep 2,626
Crank HP is kinda worthless anyways. WHP is a more accurate measure.
05-07-2008, 10:54 AM | #19 |
81
Rep 1,075
The difference is your supercharger setup was most likely maxed out due to compression ratio, unless you used race gas or water injection. The 135i dyno is bone stock and has plenty of potential to go up from there with software.:biggrin:
05-09-2008, 02:30 PM | #20 |
Rep 309
Those are still impressive numbers nonetheless.
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car 1989 Honda Civic Si-R Current Project 2002 Corolla CE Daily Driver www.TheTunerSource.com |
05-09-2008, 03:33 PM | #21 |
Rep 9
With that said, it looks to be around 320bhp.
2003 Corvette Z06: Vara-crap Intake, B&B Exhaust, Kooks Catless 1-7/8" LTH w/ 3" X-Pipe, B&M Short Throw
2007 Cobalt SS S/C: GM Stage 2, GMPP Exhaust, GMPP Manifold, ZZP Catless DP, 2.9" Pulley, Torque Dampener, 8000K HIDs, AEM Airbox Mod |
05-09-2008, 05:42 PM | #22 |
386
Rep 1,660
Nope. I had the smallest ESS S/C in there. Only 6.5 PSI.
