04-22-2008, 11:43 PM | #1 |
Rep 83
Strut Brace
do you guys think that installing a Strut brace would postitively affect the body role? I am definatley replacing the rear sway bar, maybe the front, and i am going to lower the car as well. thoughts?
04-23-2008, 12:09 AM | #2 |
Rep 45
No. Body roll is affected by the anti-sway bars and the spring rate.
A strut tower brace is to brace and "stiffen" the chassis, reducing flex. Unless you really track your car and have a track oriented suspension setup, that brace will be bling. |
04-23-2008, 10:58 PM | #4 |
322
Rep 1,804
I doubt a strut brace would be anything on a 1er. The chassis is so strong out of the box. The E92 M3 doesn't have one, so I doubt that the engineers thought the car needed one.
-Nick
2018 BMW 440i - M Sport, Exec Glacier Silver Metallic/Coral Red Dakota Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i |
04-23-2008, 11:08 PM | #5 |
Rep 77
The strut tower bar effectively boxes the chassis up front at the strut towers thereby reducing body flex. This body flex can be felt as less-than-instantaneous direction changes if you do a sudden lane change for example....
You should consider a strut tower bar strictly as chassis reinforcement. Tighter body = less flex and less body fatigue over the years plus sharper reflexes when you fling the steering wheel at speed. It should have NO adverse effect on a car's ride comfort since it doesn't change suspension geometry or the suspension's compression/rebound rates. But there are some people who think they know better and falsely blame it for perceived harshness that can easily be attributed to any other part of the car's suspension or wheels/tires... Anyways, it's one of those very few mods that gives good results with almost no downsides... Just remember to use a torque wrench when installing it. |
04-23-2008, 11:10 PM | #6 |
Rep 77
04-23-2008, 11:52 PM | #7 |
Rep 185
I put a strut brace on a Mustang once. It definitely made for sharper stearing. More immediately responsive. Was worth doing, at least on that car. I don't remember that it worsened the ride at all. But the 135i is a totally different car so I'm not sure if it would have as much effect or not. Only way to find out is for someone to try it out and report back.
04-24-2008, 11:18 AM | #8 |
322
Rep 1,804
True, I forgot about that. I just remember reading a quote from Steve Dinan saying how strut brace help a lot on E30's and E36's...a little bit on E46's...and "look nice on E90's."
-Nick
04-24-2008, 11:11 PM | #10 |
I no longer work for United BMW!
306
Rep 3,330
Drives: E46 M3, E46 330i ZHP, E36 325i
Personally, unless you're tracking the car it's not even worth it to buy one. I picked one up about 3 years ago in my E46 and I never did notice a single thing.
BMW CCA, PCA, & CHIN Motorsports Instructor.
04-25-2008, 02:49 AM | #11 |
Rep 45
I agree with Doolab
Honestly, I wouldn't pay 200+ for a strut brace for this chassis unless I actually tracked the car regularly or just want to that bling factor. However on my Civic chassis, I have a rear strut brace that helped but I got that for 30 bucks and I couldnt go wrong. Just another note, moving endlinks = less effective brace. Also triangulated braces are even more effective ( 3 point ) |
