04-21-2008, 06:33 PM | #1 |
123
Rep 2,295
Anyone interested in a GB for the Performance Brake Rotors?
More the merrier... Getting some pricing now, looks like $100 USD per disc...
These are the slotted/drilled puppies as seen here: |
04-21-2008, 07:00 PM | #2 |
457
Rep 4,822
It does look good mate. Any idea what the size is? Is it actually better for track application? I know it is 3.1 pound a corner lighter, which is not bad given it is unsrpung weight. I am potentially interested...
04-21-2008, 07:04 PM | #3 |
123
Rep 2,295
Size will be identical, because if theres a size change then the calipers would require new brackets.. Only difference is a lighter rotor and a better cooling rotor..
Theres a big diff in weight saving! Especially for you WAY who wants to make a CSL 135i :P |
04-21-2008, 07:17 PM | #5 |
BMW ONE
15
Rep 630
Drives: 93 RX-7 R1, 135i
3.1 lbs savings per corner is the hotness!!!!!
135i - Alpine White - Black Leatherette - 6-Speed - Sport Package - Aluminum trim - 6FL
04-21-2008, 09:47 PM | #12 |
Rep 66
Help me out here... what are the benefits of these brakes? That is, what difference will I notice and does the 3.1lb. weight savings transalate into improved 1/4 mile times?
135i Coupe .. Titanium Silver .. Coral .. 6 Speed .. Sport .. Cold Weather * Ordered: April 7 * Production Completed: April 16 * Delivered: May 10th |
04-22-2008, 03:23 AM | #13 |
13
Rep 356
In my experience drilled rotors are weaker and more prone to cracking. I've found the best option if you plan to track the car is to go for slotted only.
I wonder if these BMW performance rotors are really up for some track punishment or if they are really just for 'show'... |
04-22-2008, 05:17 AM | #14 |
123
Rep 2,295
spdrcr: you've never had a Porsche then
It depends on the method used to make them. Cast rotors with drill holes are perfectly fine, drilled rotors after making them are prone to issues like cracking.. That said, you'd have to be doing some real thrashing to crack a good set of BMW rotors. The M3 has them and various other M cars all with much success If only for the weight saving, these are fantastic. 3.1lb per corner is BIG |
04-22-2008, 05:56 AM | #16 |
123
Rep 2,295
Jeff, alot more. Alum rotor hats and drilled discs is better again.. these rotors look semi-two piece, not sure if you can see the studs?
This, combined with a light weight wheel setup would be great! |
04-22-2008, 08:24 AM | #21 |
16
Rep 282
04-22-2008, 05:06 PM | #22 |
123
Rep 2,295
WAY, I highly doubt it will suit heavy track abuse like what you're talking about. You're best with a proper 2 piece, lightwheel setup from someone like AP, Wilwood or Porsche.
